best cheap/free scores 1.1
This is a sticky topic.
    master hoarder
    • May 2008
    • 12175
    #1361
    Re: best cheap/free scores 1.1
    The benchmarks beg to differ.
    Well, yes, the 9500 does have higher benchmark numbers, but when it comes to games, it's not a night-and-day difference from the HD3450. I guess it all depends on what games you plan to play on it (if any?).
    however the 9500 has a bad fan so it's "on blocks" for now (I ended up nabbing a PNY 9800 PE 1gb from a buddy anyway)..
    Dammit, I knew it! That cheap-looking aluminum heatsink was asking for trouble. So far, I've only seen MSI, XFX, and PNY use those cheap fans on some of their lower-tier video cards, and they never ever last.
    Is the fan just seized or is the rotor hub starting to melt too? If it's the latter, then it's one of those cheap fans.
    I feel bad now for giving you the link to that card :\ .
    By the way, I have a question for everyone.
    There is someone on my "local" Craigslist selling a pair of oldschool Sony SS-U230 floor speakers for $10. I'm wondering if they are worth the drive or not (it's not exactly close to where I live). I can't find much info online on these things. Going by what I found, they have the following specs:
    8 Ohms impedance
    200W max
    2-way system, ported design. Probably made in early 90. They look a bit cheap and similar to my Nova-18 - big when viewed from the front, but not very deep when viewed from the side. That makes me think small subwoofer magnet and probably small subwoofer voicecoil (i.e. boomy bass in the upper range and nothing in the lower range :\ ). Subwoofer cone looks about 10", but that's all a guess based on the pictures. Here's the link:
    http://washingtondc.craigslist.org/d...739461730.html
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      I tossed the fan. The sleeve bearing rattled and it was sealed (no plug).
      If I can find a cooler that fits, I'll add it and put in my parents box (they currently have a poly modded 7600GT)
      sigpic
      (Insert witty quote here)
      • Compgeke
        • Feb 2014
        • 524
        Originally posted by Compgeke
        Picked up a free 1200W Champion generator with a screwed up carb.
        Not sure what the engine is based on. It sounds like a Honda and looks like a small Honda GX120 but 80cc. If it ends up needing more than $50 in repairs I'll probably try and swap something like a Honda GXH50 or GX100 into it for shits and giggles....
        After looking around it seems this here's the exact same as the Predator 79cc engine, same parts location, size, carburetor, etc. I believe it's a Briggs clone but don't quote me on that.
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          #1364
          Re: Your Best Dumpster Finds
          What I found in the dumpster today....was a ATX case in almost PERFECT condition.
          Just the front has a crack (which can be masked away with superglue anyways) but otherwise it's good. I've already moved my Pentium 4 rig to that case.
          It sadly doesn't have any company name,however a CD cable that was in it seems to say "BEST" on it.
          Main rig:
          Gigabyte B75M-D3H
          Core i5-3470 3.60GHz
          16GB DDR3-1600
          Samsung SH-224AB DVD-RW
          Delux MG760 case
            • 31287
            dont use superglue, it interacts very badly if you use spraypaint on the front later.
            i found out the hard way.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              #1366
              Don't worry, I won't spraypaint the case since it's one of those retro beige cases that I like.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • Heihachi_73
                • Jun 2012
                • 713
                Found a complete Core 2 Duo (I think) system in Cooler Master ATX case a few days ago, haven't tried it yet. It has an ATI video card with two DVI connectors (and no VGA) and an Antec power supply (which I will check later to make sure it doesn't have the Fuhjyyu plague). For some reason it also had a floppy drive, but it was not hooked up. IIRC it was a Gigabyte board from 2008 (according to the few ICs I could find without taking everything apart).
                • Behemot
                  • 4845
                  • CZ
                  #1368
                  Just found Electrolux Ergorapido hoover the other day. Most likely only batteries are bad, we do them all the time. Pity there was not the charging dock.
                  • C152Heavy
                    • May 2014
                    • 66
                    • CA
                    #1369
                    Originally posted by C152Heavy
                    And the count continues.....another Samsung, this time a 920NW.
                    This time it was a bit more challenging, not caps but intermittent connection at one of the CFLs in the backlight but thanks to those who have gone before me, the legwork was done and posted up here (Thanks!) and "all" I had to do was a bit of soldering plus a few choice words putting the panel back together.
                    And the watch continues.
                    D
                    Answering my own post LOL! The watch didn't take long to bear fruit again, another 2220WM rescued from the recycling and after a quick re-capping it's back.
                    There are still a bunch of them to go.
                    D
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      #1370
                      Alright,here's a pic of the PC case. Sorry that the crack on the case isn't seen.
                      The other one in the background is my sig rig.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • Behemot
                        • 4845
                        • CZ
                        #1371
                        Mediocre at best, does it at least have some rear fan positions?
                        • SuperDuty
                          • Mar 2011
                          • 299
                          • France
                          #1372
                          This is the kind of case I keep around only to have a reason to go to the recycling center to pick up more interesting stuff
                          One of my first dumpster find was a complete Pentium 4 system in a cheap case like that in mint condition, no yellowing, no scratch, no dust, so it houses my brothers computer now.
                          I've also found a ginormous badass 2002 Chieftec Dragon full tower three years ago, my rig is in it now
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            #1373
                            Of course. It has 2 of them.
                            BTW I noticed that the only removable panel is the one that covers the innards.
                            The other panel isn't removable as it's used for the standoffs.
                            The parts inside it are a Pentium 4 1.8GHz,2.5GB RAM,80GB WDC SATA HDD,MSI FX5200 128MB PAL,Samsung DVD drive and a 400W Delux PSU. Board is ASRock P4VM800 (aka ASUS P4V8X-MX)
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                            • edgars_ab
                              • Nov 2014
                              • 22
                              • Latvija
                              #1374
                              Recently I got a perfectly good 17" LCD monitor right from our recycling center. As the lcd screen had no cracks, I expected some problems with capacitors, ccfls, or transformers, so I disassembled it without even trying to power it up. I have a bad habit of that, lol, and this time was not the first one, this habit punched me in face - all circuits was in perfect condition - no bulging capacitors, no signs of overheating, NO other defects. Even no dead pixels on the lcd panel. Assembled it back, powered up, worked on it for more than 4 hours - no signs of any defects.
                              Before that day, i was visiting my client to fix his PC. I was surprised, that he was still using a CRT monitor, after all these years.
                              In the same way, i'm actually shocked till right this moment, and i can't understand - why people throw out a perfectly good things, if they can simply give it to others or SELL it to others. Even these days, you can't buy a used lcd screen without 20$-30$ bucks in your pocket. It's not much but it's still a money.
                              • Behemot
                                • 4845
                                • CZ
                                #1375
                                Could have had dozen of 17'' LCDs for couple of bucks a piece but nobody wants it for decent price for the effort of renovating it…
                                • Jooo
                                  • Oct 2011
                                  • 222
                                  • Finland
                                  #1376
                                  I have been trying to sell perfectly working, scratchless 17" - 19" 4:3 LCD monitors including all the cables for 6 to 12$ with not a single person contacting me.
                                  Had around 50 working LCD monitors, and they took so much space,
                                  I ditched at recycling place all of 15" LCD's, monitors with only VGA, and every monitor that had even a single scratch on it. I found that nobody wanted those kind of LCD monitors.
                                    • 31287
                                    you can sell the 19" ones to arcade machine collectors to replace burned crt's
                                    they may need one of these though.
                                    http://www.sintron-hk.com/GBS-8220-a...-P2699965.aspx
                                    • edgars_ab
                                      • Nov 2014
                                      • 22
                                      • Latvija
                                      #1378
                                      This is getting more interesting.. You say, not a single person is interested to buy from you a 19" 4:3 monitor? I think you would have a demand at my country, where minimal salary is only 320 Eur/month. Even with 400-500 Eur / month it's getting pretty uncomfortable to live here, but many people do. Salesman, shop assistants, janitors, even teachers, nurses, policeman and fire fighters, all of them mostly have a salary <= 500 Eur / month.
                                      Many people simply can't afford to pay 100$ or more for a new LED screen (without a loan), because of such a low salary I mentioned before, and big expenses, so in result they are fixing their old LCDs and buying used ones (prices are - $20-$30 for LCD 17" 4:3, $35-$50 for LCD 19" 4:3).
                                      From the other point of view, we have a bit different values here too because of this economical nonsense - even I am working still on a 4:3 19" lcd, but not because i couldn't afford to buy a new one. I simply don't feel a need for a new screen, because the one i have currently works great. Maybe next year when cost of electricity will go up, i will make a decision about changing my LCD-CCFL screens to LED ones .
                                      If it's still a surprise for you guys, please take a look at our local listing (most popular) service and take it as a proof:
                                      https://www.ss.lv/lv/electronics/com...ware/monitors/
                                      Please keep in mind, that prices are listed in Eur. In Riga prices are a bit cheaper than other cities, but as you see, there is even some guys who try to sell their 17" old CRTs for a price of $8-$10, hah.
                                      I would start to think about opening a second hand computer store here in Latvia, if i would have an option to get LCD screens and used computers / computer parts in such a quantity for almost nothing, lol.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #1379
                                        I don't know any 4:3 LCD other than 20''. I gues you mean 5:4?
                                        But anyway, even here the demand is quite low. I got several good S-PVA displays with fancy stuff like repro or USB hub, pivot OFC. Nto being able to sell it for 45 bucks…everybody wants wide (even if that is crap for anythign than watching movies!), they are sold within a week usually, but not old 5:4.
                                        If you want, than go ahead, open the shop, I can supply you with monitors. Latvia is not THAT far away, we can load a van with displays and go to you from time to time.
                                        • popeye
                                          • May 2011
                                          • 155
                                          #1380
                                          the aspect ratio is 4;3 that is what we had before FST and LCD and PLasma
                                          Screen size is a mesurement diagonaly ie: 4" across by 3" up same ratio as 16:9
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
