When your mom is complaining about her new cheap lights
  • evilkitty
    • Nov 2017
    • 299
    My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
    well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
    Click image for larger version  Name:	signal-2024-07-21-22-47-57-562.jpg Views:	0 Size:	178.6 KB ID:	3315038 Click image for larger version  Name:	20240723_145321.jpg Views:	0 Size:	1.76 MB ID:	3315039 Click image for larger version  Name:	20240723_145309.jpg Views:	0 Size:	4.78 MB ID:	3315040 Click image for larger version  Name:	20240723_145537.jpg Views:	0 Size:	4.84 MB ID:	3315041
    lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board
    She also got rechargeable puck lights and complains about there battery life... they have 160 mAh batteries in them
    • Jul 2011
    • 6070
    I have a suggestion for you and that is get a cell phone battery pack and use it to power these things but the issue you might have is that if the stand by current is not high enough then it might not turn on after the first time however if you modify the battery pack a little bit an use a relay then you could have two light levels one on 4,2 volts and one on 5 volts
    One way around this is to reverse engineer this a little bit and power the LED light bulbs on the 5 volts and the motion sensor circuit on the 4.2 battery voltage with it on BMS board these are very inexpensive to buy and very easy to install and use
    Or go to Battery Hookup and buy one of there battery packs and modify it by taking out the BMS protection board and use a BMS board that just protects the battery cells from over and under voltage and just run it on 4.2 volts but make a decent size battery pack for it
    I curious about what the stand by current is for the motion sensor circuit if it is under 100 milliamperes then if you had 10 amp hour battery pack it would run a long time in standby mode for quite some time now of course it depends on how often it is triggered to how long the battery pack would last on one charge
    Now you could buy this a Battery Hookup and just use a different BMS protection board
    https://batteryhookup.com/products/b...1700-50e-cells
    and then glue it back together
    • petehall347
      • Jan 2015
      • 4452
      • United Kingdom
      10 leds thats 43ma each . way over the top in my view .
        • Jul 2011
        • 6070
        Probably but if I were doing this I probably would power the LED light bulb on a lower voltage so you would have lower current draw but not to low that your brightness would suffer and you would not be able see anything
        The one thing that I find with LED devices is that they have a tendency to over current the LED light bulb to the point that it drastically reduces the life of the LEDs or the quality of the LEDs are crap to begin with
        • petehall347
          • Jan 2015
          • 4452
          • United Kingdom
          yes my view entirely . they run them maxed out . they get way too hot .
          • evilkitty
            • Nov 2017
            • 299
            stand by looks to be 0.50 mA, had to use my meter for that one the usb tool can't even close to that low (i think it bottoms out at 0.07A), that said my jank adapter under load only showed it pulling about 250 mA and my usb tool confirmed that, either my jank adapter or multimeter is limiting the current
            • brispuss
              Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
              by brispuss
              Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
              Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
              I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
              12-28-2022, 02:58 AM
              ACER Aspire AspireRevo R3600 + Gaming Pack Aspire 230 Specification for Upgrade or Repair
              This specification for the ACER Aspire AspireRevo R3600 + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire AspireRevo R3600 + Gaming Pack boardview and Aspire AspireRevo R3600 + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
              09-12-2024, 03:28 PM
              MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
              This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              Acer Extensa EX215-31-P8GN + Pack Gold EDG 3 ans 15.6" Notebook 15 Specification for Upgrade or Repair
              This specification for the Acer Extensa EX215-31-P8GN + Pack Gold EDG 3 ans 15.6" Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX215-31-P8GN + Pack Gold EDG 3 ans 15.6" boardview and EX215-31-P8GN + Pack Gold EDG 3 ans 15.6" schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
              09-07-2024, 03:10 AM
              Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook 3 Specification for Upgrade or Repair
              This specification for the Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-58-38H7 + Pack Gold Acer 15.6'' boardview and A315-58-38H7 + Pack Gold Acer 15.6'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
