best cheap/free scores 1.1
This is a sticky topic.
    • 31185
    Re: best cheap/free scores 1.1
    i love commodore stuff.
    you should look at this for the amiga.
    https://cortexamigafloppydrive.wordpress.com/
    • Compgeke
      • Feb 2014
      • 524
      Actually not a bad idea.
      I might pick one of those up after I find another monitor. The 1084S there worked for a whole of maybe 2 minutes before it ticked a couple times (a few seconds apart - no screen jumping) and shut off all together. Won't turn back on.
      I assume the flyback blew and took some power supply with it. The squeal from this was horrible but I've known some that just make the noise and work fine forever.
        • 31185
        well they are known for blowing transformers.
        but i'v had them with shorted line transistor (bu508a) before.
        also, most of them have a seperate psu pcb that slides out, you can test it alone on a lamp-load.
        and you should because i think you need to calibrate the output voltage.
        and it probably needs a new startup cap.
        too bad your so far away, i think i have a spare transformer somewhere that was purchased and never used!
          • 31185
          btw, i'm going to hook my amiga's to a vga monitor once this arrives!
          http://www.sintron-hk.com/GBS-8220-a...-P2699965.aspx
          • Compgeke
            • Feb 2014
            • 524
            I'll probably end up getting one of the S-Video adapters to run off the RGB output. A few exist that are supposed to give colour output rather than the monochrome off composite and it'll work well enough until I can find another monitor.
            I've got somewhere I can look for old monitors anyways so who knows what might show up. Now that I'm thinking about it I wonder if there's an Amiga RGB to BNC RGB adapter somewhere...or an old NEC Multisync. Hrm.
            Sadly most things Amiga have gotten insane expensive lately.
              • 31185
              why not get the 8220 i listed and use a vga input on a tv/monitor?
              you can also get a slightly cheaper model from DX with only one output.
              • Compgeke
                • Feb 2014
                • 524
                Not super cheap and not my own personal either - for the living room.
                Picked up a 42" Dell Plasma TV for $125. No burnin, no audio or picture issues, nothing except a slightly wonky front power button (takes a couple pushes to turn on).
                Has the original speakers but for some reason doesn't have the stand. It does, however come with a wall mount which is nice to have.
                At the moment I'm saving up for a new camera lens. My camera got caught by wind and knocked off where it was and screwed up my lens (no infinity focus anywhere, grinding at full zoom with AF, won't zoom out past 28mm and a metal chunk fell out the back).
                  • 31185
                  you should replace that power switch, that's the type of thing that catches fire!
                  • Compgeke
                    • Feb 2014
                    • 524
                    Power switch is a soft power button - not running mains through it. I assume it's just a worn contact under it but if using a remote no one ever has to touch it anyways.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Scored a Belkin Play 600 F7D8302 V1 router for $3... it even had two Ethernet cables with it.
                      DDWRT'd just fine... and even for a belking it seems halfways reasonably build. Dual band broadcom everything. Not much in the way of status lights... But for $3, hell yes.
                      sigpic
                      (Insert witty quote here)
                      • SuperDuty
                        • Mar 2011
                        • 299
                        • France
                        #1431
                        Got this lot of graphics cards for 10€ (20€ with shipping) :
                        http://www.ebay.fr/itm/Lot-Carte-gra...:X:AAQ:FR:1123
                        HD5770 V3 Sapphire
                        HD3650 256Mb DDR3 Asus
                        GTS250 1Gb Asus
                        GT220 1Gb DDR2 Sapphire
                        G100 512Mb MSI
                        9600GT 512Mb (can't find the brand)
                        Sold as not working...well it's not quite true Aside from the HD5770 which was overheating at first and now doesn't seem to be detected properly, they all work flawlessly.
                        Also got 2x2Gb of SO-DIMM DDR3 12800 from a MacBook Pro (cool flat black PCB) for 9€.
                        • Compgeke
                          • Feb 2014
                          • 524
                          Very wet Optiplex 780 SFF. Has a 3 GHz Core 2 Duo, no ram, no HDD. Was free because they stuck it in a plastic bin before the storm and it ended up completely submerged under water.
                          Gutted it and stuck it in a warm spot of the house to dry out. I'll probably try it on Wednesday or so to ensure it's entirely dry. If there's any corrosion starting I'll give it an alcohol bath.
                          The 780s are awesome as you can throw a Core 2 Quad and 8 gigs of DDR3 into them no problem. The SFFs are even nicer as they fit easily under or behind a monitor.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8325
                            I got today a Toshiba Laptop dual core out of the recycling bin that actually worked. Nothing wrong with it!
                            • Compgeke
                              • Feb 2014
                              • 524
                              My brother's laptop is nearly the same way. It was in great shape in ewaste, $10 got it out for me.
                              Surprisingly only thing wrong is a few bad sectors on the hard drive but almost a year later it's still running fine on that drive. Windows wouldn't load but a reinstall wasn't hard anyways.
                              People really have some weird obsession with just throwing out "old" stuff rather than passing it on imo. Maybe it's that "recycling" stuff.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Yeah, it's dumb... look at the dell poweredge 830 I scored awhile back... $20 GW donation. Sure, it took another $50 or so to make run (mainly due a broken CPU cooler latch which I could only get with a $25 mobo)... but with 3 500GB SATA drives (hotswap caddies) and a Perc 5/i SAS card (and a kickass adaptec SCSI host), for $20... hell, just one of the HDDs was worth more than 20... one of the cards more than 20... chucked it like it was a used pizza box almost. Sure linuxed up nice!
                                sigpic
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #1436
                                  Scored an Agilent U1241B in the local ads for $60 CDN shipped.
                                  The thing was grimy as heck (Must have been used by an auto-mechanic), but a little charcoal fluid and an old rag and it cleaned up rather nicely. Came with nice Agilent gold plated test leads (Well the gold plating has worn off for the most part), that detach at the end. Does anyone know where I can get grabbers or spring hook pieces that would be compatible with these leads?
                                  It works perfectly as far as I can tell. I don't have any voltage or resistor standards, but I'm pretty sure it's spot on. Capacitor measurement is good too, not that I'd rely on it for that. The only thing thought was odd was the mV measurement which fluctuates wildly when I wave the leads around, but that's perfectly normal (I wonder why though).
                                  Yay! Finally, I have a normal multimeter.
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    Not bad!
                                    <--- Badcaps.net Founder
                                    Badcaps.net Services:
                                    Motherboard Repair Services
                                    http://folding.stanford.edu/
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      That's actually really cool. My office is in HP Agilent former headquarters...
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Scored 19 HTC/LG OEM micro usb cables for 19 plus tax. All were brand new at goodwill, some having 0.7A lg chargers and two having 1A HTC chargers. .. my family needed micro usb cables bad and our samsung phones and tablet don't like cheap cables (like they ovresized the shells a hair)... won't need cables any time soon.
                                        sigpic
                                        • goontron
                                          5000!
                                          • Dec 2011
                                          • 4108
                                          • US
                                          #1440
                                          scored a waterproof kyocera hydro for null.
                                          Follow the white rabbit.
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
