best cheap/free scores 1.1
This is a sticky topic.
    • 31185
    Re: Your Best Dumpster Finds
    that would probably pull good moey on ebay.com from collectors.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: best cheap/free scores 1.1
      ^look at topcat's smoke removal thread. Your DIMM contacts are probably fouled. clean the board as per that thread and try again.
      sigpic
      (Insert witty quote here)
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        #2563
        Actually I've encountered that with a clean Deluxe variant (clean as in no nicotine residue or anything like that) of the P4P800, where it would exhibit the same issues as this board - some RAM sticks simply won't work with it.
        Oh, and there's no Simple Green here where I live, and I don't know what can I use instead.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #2564
          Use anything you like as long as you properly rinse it afterwards.
          I've used YES in the past, it's a simple washing detergent...
          Board is working fine almost 10 years after so I'd call that a success
          • mikay786
            • Aug 2014
            • 765
            Anyone in the UK want some free kit that needs repair?
            Asus a8v deluxe motherboard (leaky caps)
            AMD Athlon 64 chip
            Matrox GPU g55+mdha32db
            Adapted 29160lp controller (physical damage to resisters)
            2GB Kingston DDR 400
            IDE dvd drive
            I only bought system for the case, I don't need hardware and I doubt it would fetch much on the bay. I know some you guys like playing with older hardware so you are welcome to have. I assume everything apart from board and adapted card work, board should be a easy fix for someone.
            Just request p&p be paid for.
            • hikaruichijo
              • Aug 2015
              • 123
              • Spain
              #2566
              I'm not planning on sell it, at least now, I'm curious if it really works, the monitor has a male DB9 and the keyboard is a 6 pin DIM but I can't find any technical information about it to try to create an adapter for the screen and the keyboard, also I can't find any info about the software it used.
              It is like they made only two or three of this machines...
                • 31185
                well trace the monitor pins back and draw a shematic
                i suspect it is gnd, video and H/V sync
                it could be colour - but i doubt it.
                  • 31185
                  the athlon64 may be handy - what's the part number? so many damned sockets on those!
                  • mikay786
                    • Aug 2014
                    • 765
                    Ada3000daa4bp
                      • 31185
                      off the asus board?
                      • mikay786
                        • Aug 2014
                        • 765
                        Yep, everything from same pc
                          • 31185
                          dont need it then, i think i have a 3200 or 3400
                          • Curious.George
                            • Nov 2011
                            • 2305
                            • Unknown
                            #2573
                            Probably CGA video -- one bit per color (R, G, B) and one bit of "intensity". I.e., 15 colors and black. My Compaq Portable 386 has a similar video interface (but, then again, with a plasma display you're limited to orange, orange, orange and black! )
                            Remember, it's a word processor, right?
                            https://en.wikipedia.org/wiki/Color_Graphics_Adapter
                            Last edited by Curious.George; 12-26-2017, 12:21 PM. Reason: Add reference to CGA overview
                              • 31185
                              it's z80 based, i doubt it's colour and it's probably 25KHz horizonal (medium-res)
                              a frequency counter or multimeter that can read frequency would be handy.
                                • 31185
                                http://home.iae.nl/users/pb0aia/cm/phcomp.html
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  #2576
                                  If it's Z80-based, then it either has a 6845 as a CRTC or (worse!) a homegrown mishmash of tonka-toy logic implementing same discretely. MPU's of that era were relatively easy to share memory with a display device (e.g., frame buffer -- though a word-processor would typically not need that level of sophistication and could just get by with a character buffer) owing to the simplicity of their memory interfaces.
                                  The consolation is that you should be able to reverse-engineer EVERYTHING as the most proprietary devices from that era would be PLA's and even those were "readable" (lacking much buried state). Likewise for the software...
                                    • 31185
                                    registered pal's are not that readable.
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      #2578
                                      Depends on whether or not the register outputs are "buried". Many of the small PAL's/PLA's brought every register output to pins (keep in mind the vintage of the devices in question).
                                      Even in that case, knowledge of the internal structure of the AND/OR array can allow you to probe the device and deduce it's hidden state. I wrote a tool that allowed me to probe a DUT (at bus speeds) to tabulate its responses to various stimuli and then back-fit a set of logic equations to the observed outputs.
                                      • hikaruichijo
                                        • Aug 2015
                                        • 123
                                        • Spain
                                        #2579
                                        It's z80 based for sure, it has two z80a cpus on the main board and another z80a on the bigger dautherboard but I don't see any 6535.
                                        I also thought of CGA and will try if my boos finds his CGA monitor and that's as far as I can go withought info like pin1 red,pin2 green,pin4 hsync... well I lack the knowledge to reverse enginer it.
                                        Looking at the traces that go to the screen conector, or I becoming blind or the board has more than two layers, because I only see four pins conected and two go to ground and another go to a memory chip.
                                        Maybe this thing deserves a better owner because it's seens to be a bit exotic piece of hardware. The last wordprocesor philips produced after the apearance of wordpro.
                                        A shame I can't fully fix it.
                                        • Curious.George
                                          • Nov 2011
                                          • 2305
                                          • Unknown
                                          #2580
                                          A lot of older kit is just that -- older kit! Most folks would gladly opt for "new(er) kit" and toss the old in the tip.
                                          I tend to save older devices for:
                                          • sentimental reasons
                                          • support <something> that I bought that is no longer supported by newer devices (e.g., one of my logic analyzers supports an external XT keyboard)
                                          • support <something> that I designed many years ago (and don't feel inclined to try to move that to newer platforms)
                                          E.g., I have a working "HiFi" VCR that I keep until I can finish transferring all of my video tape onto DVD. Ditto (audio) cassette and laser videodisc. I keep a pair of working Sun workstations to support software that I wrote to run under Solaris -- that I don't consider worthwhile to port to a more modern OS. I recently discarded my last pen plotter after having recovered the last of the drawings that relied upon it.
                                          You have to make your own criteria for what's worth your (storage) space and time... (as you get older, these criteria tend to change remarkably!)
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
