This topic has been answered.
  • aaronkatrini
    • Mar 2023
    • 22
    • Italy
    - Autorange
    - DC volts up to 30V
    - Accurate Resistance
    - Diode test (Beep mode)
    - Frequency up to 200MHz
    - Capacitanze up to 5000uF
    - as cheap as possible
    Other functions are not needed but those which are needed are essential, even if one is missing then it doesn't suit me. If you know of anything please let me know. Thanks in advance!!
  • Answer selected by aaronkatrini at 05-07-2024, 05:29 PM.
    stj
    • 31612
    the only meter i know that can read 200MHz is the unitrend UT61e
    • Loulou31
      • Mar 2024
      • 5
      • France
      • Home work, diy
      Please could you detail "accurate resistance " ? 1% 0.2%.....
      Usually multimeter are not very good for frequency measurement : accuracy, sensitivity...
      Jean-Louis
        • 31612
        • aaronkatrini
          • Mar 2023
          • 22
          • Italy
          Loulou31 it doesn't have to be super accurate, its for hobby work, so I guess 1% should be fine. Thanks
          stj thank you for the recommendation, I checked briefly and seems to tick all the features I'm looking for and has reasonable price, will check out some reviews in the upcoming days. Thanks
            • 31612
            there is a new v2 version, i dont know about that - i'm looking at the original one.
            • clearchris
              • Dec 2013
              • 687
              You can also get dedicated boards to do frequency counting, they are very cheap. Check aliexpress.
                • 31612
                yes, i have a 2.4GHz 8digit frequency counter from ali that cost me about €10 a few years ago
                • dj8452000
                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                  by dj8452000
                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                  02-18-2025, 08:28 AM
                • yayayee
                  ASUS GU502GV not powering on - 1285A hot
                  by yayayee
                  I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                  So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                  I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                  01-08-2024, 11:04 PM
                • trex66
                  Craftsman 82345 Multimeter broke!
                  by trex66
                  My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                  03-04-2025, 04:26 PM
                • shovenose
                  Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                  by shovenose
                  Got this one for free because, well, it no worky.
                  A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                  Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                  08-11-2021, 01:26 PM
                • daigs
                  what microcontroller they use for this Cheap LED controller ?
                  by daigs
                  Someone know what microcontroller they use for this Cheap led controller? I’m Triyng to buy it on aliexpress or Made in china website asking if I can reprogram it with my code. Chinese people are very bad in communication. No answer or confuse one. I need 1000 part and I think I’m forced to do my own pcb with attiny85. I alredy done it with esp32 but I need a very small pcb with rf receiver like this to control a ws2812b strip
                  03-31-2026, 11:54 AM
