best cheap/free scores 1.1
This is a sticky topic.
    • 31289
    Re: best cheap/free scores 1.1
    the humax HD pvr's all fail, you need to put a heatsink on the cpu.
    • retiredcaps
      • Apr 2010
      • 9271
      #1702
      Originally posted by mikay786
      2 weeks ago I scored a humax PVR for £4.50, sold it for £120
      Excellent profit margin. Did you have to do something to the humax in terms of repair or recapping?
      --- begin sig file ---
      --- end sig file ---
      • mikay786
        • Aug 2014
        • 765
        Just sheer luck to be honest, was going to pass up at £5 lol, then she agreed to £4.50
        No it was working fine, it came stock with a 320GB HDD but I threw in a spare 500GB HDD that I had, which are not exactly expensive.
        Also picked up this Hinari CD player today with built in amp for £2
        Hinari DPA2
        Now I was being a bit judgmental when I bought this, was from some eastern European chaps at market and I usually avoid bying stuff from them as I find a lot of times they've already had a go at repairing and are basically selling electronic waste.
        Along with being covered in mud and rain, but to my surprise works perfectly, both channels and playing cds like a champ.
        • mikay786
          • Aug 2014
          • 765
          I've not much experience with them to be honest, although humax are more a premium brand compared to most. Only started looking out for PVRs recently as usually its no loss kind of deal. If they work score, if they don't you get a free hard drive + remote. So as long as you are only paying a couple of quid youre not going to lose out.
          PVRs I got today are luxor tutv2500
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            #1705
            What I've scored:
            -ASRock K7VTA4+ - need to reflash
            -ASRock 775V88+ w/P4 3.00GHz Prescott - need to reflash
            -ASUS K8V SE Deluxe - won't post,see text below
            -Winfast A7300GT TDH 256MB - DOS mode works fine,VGA has artefacts - anybody know a simple fix?
            Now,regarding the K8V SE Deluxe:
            I've got this board that was looking cool,has 4 SATA ports + RAID - 2x VIA8237R (standard) and 2x Promise PDC20378+IDE RAID port). I loaded it up with a Sempron 2500+ (test CPU,if it's possible to get it working then daily CPU for it is Athlon 64 2800+),1.5GB RAM and a "Speeze" (Spire iirc).
            Problems with it:
            -CPU stays cold most of the time,regardless of what I put in (Sempron 3000+,Sempron 2500+ or Athlon 64 2800+)
            -MB turns on as soon as PSU switch is flipped (this is with my beefy Deer (not going to explain it again...),my FSP has a 1 second delay)
            -does not POST
            -does not beep
            -SB is near stone cold - MB wouldn't turn on if SB was dead
            What does warm up on it are the Network chip (Marvel 88E8001-LKJ),the Promise controller (Model number listed above) and the Winbond W83697HF,with the last one being less warmer than the NIC and SATA/RAID chip.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              Crappy ones, freeview with just scart (no hd or hdmi) 250GB cant complain though for a quid each.
              (Ill edit post in a bit with brand)
              Love this thing though, looks so cool. Also portable but takes 10 huge batteries!!
              Anyone had to change drive belts on cassette decks?
              I have serviced drive belts on tape drives. Not a big deal if you've got the right size belt. If a belt is just slipping on pulleys and not stretched, cracked or broken a little non-slip fluid (like RS used to sell) works well. Don't get any in the feed and takeup reel hub clutches though.
              • mikay786
                • Aug 2014
                • 765
                No its doing absolutely zilch, no movement what so ever so reckon they are dead / turned to goo (around 35 years old)
                Any suggestions how to measure up correct size belts and where to source?
                ebay belts worth looking at?
                  • 31289
                  can you hear the motor running?
                  i had to replace a few motors in the past.
                  • mikay786
                    • Aug 2014
                    • 765
                    No cant hear motors, pressing buttons does nothing
                      • 31289
                      time to get in it then - put a meter across the motor wires.
                      if it's got power you need to see if the shaft is stuck.
                      there is a pcb inside the back on most motors that contains a speed regulator btw.
                        master hoarder
                        • May 2008
                        • 12175
                        #1711
                        May not seem like big score but some little things like that make a world of difference.
                        Totally!
                        I regularly find broken earbuds on the street (usually near parked cars), and I always pick them up. May seem like a waste of time, but those 3.5 mm jacks always come in handy for audio projects. My latest kludge is a 3.5 mm to "speaker terminal" output adapter. Basically, I have a PC with a sound card that has a TEA2025b amp IC in it. It can be used to drive bookshelf speakers directly. I tried it, and I got pretty decent sound from a pair of Sharp 10 Watt speakers.
                        Originally posted by clearchris
                        A 5$ mobile phone plastic disassembly toolset makes all the difference in the world. I have fixed my Samsung s3 two times already. I wouldn't even bother without plastic wedges and pry tools.
                        Even with proper tools (borrowed from a friend before), I still dislike working on small stuff like that. Strains my eyes too much.
                        (2x Geforce 250 SLI'd).
                        I said decent, not "gamer".
                        IMO, even one of those is decent enough for most needs.
                        Try it with a tape. Some decks may have a switch that disables the capstan/motor from running if there is no tape in the deck. Or at least my Marantz SD4000 has that. When I first got it, I was almost convinced it was bad . Needed fairly little TLC to get it in good working order. Definitely worth the $10 I paid for it (too bad the shipping was twice that ).
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1866
                          #1712
                          Cheap scores yesterday:
                          ECS P6VXAT w/Celeron 1100,284MB RAM,noname Deer/L&C clone and Geforce MX440 64MB (one of the sticks is EDO SDRAM!!)
                          PCChips M952 w/Pentium 4 2.80GHz (Northwood) - one of their quite better built mobos,sadly won't POST
                          MSI KT3V - won't POST,big scratch on traces between Northbridge and AGP slot
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
                          • mikay786
                            • Aug 2014
                            • 765
                            Think I scored big this week, spent about £65 in total though but got a lot of stuff
                            Yaesu Ft-290Rii + mic and Yaesu FL-2025 amp (untested)
                            Panasonic DMR-XS350 Twin Sat HD PVR 250GB + DVD Player / Burner (working no remote)
                            Bang & Olufsen CX50 Bookshelf speakers (foams perished) hope can reform them
                            Yamaha dsp-a592 receiver (untested)
                            Some water cooling gear ek block / dual rad / pump red combo
                            Will update later, got to go out but loads of other stuff too
                            • mikay786
                              • Aug 2014
                              • 765
                              Just tested Yaesu at brother in laws and all working surprisingly.
                              Also got a
                              Xbox original + games
                              Old school Apple keyboard
                              12v / 6v battery charger
                              Sony 6 cd changer
                              Super flower fan master fan controller
                              Tad am us-122
                              And finally a Gaggia Baby Class, works perfectly and in excellent condition.
                              • lbwlow
                                • May 2015
                                • 125
                                • Malaysia
                                #1715
                                My score of the month :
                                - Lenovo ThinkCentre A57 (some badcaps)
                                - Hp Dx2700Mt desktop (a lots of badcaps)
                                - Hp Compaq 4000 pro SFF (no idea what wrong, salvage what i need, sold the unit back for cost)
                                - Dell Precision M4300 (Wifi card semi faulty)
                                - Acer TravelMate 6291 (faulty keyboard)
                                - Custom Dual core desktop complete set (Just the main boot drive was dead)
                                All the item came from local scrape yard in my country, paid $5-$6 each (converted from my currency).
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1866
                                  #1716
                                  Moar scores!
                                  Today I scored a entire PC - quite busted,missing front panel. I removed the components from the case - including front panel wires and such.
                                  Delux ATX-450W P4 PSU - Sun-Pro built,but they apparently wrote Delux's own text - ".DELUX-AY v1.0,20120715". Smallest fuse ever (was the size of a screw),FHY/AsiaX caps. No PI coils but there are spaces for them so I'm gonna install them and see if it works - I tested it briefly with the board below (came with the PC
                                  Biostar K8VGA-M - funny thing,whatever "genius guy" recapped this board,not only he used some no-name ("SHECON" - anybody know them? ) 2200uF 25v caps (I'm guessing some KZGs went bad...),but he also omitted a completely dead KZG - bung popped and vent also popped
                                  Removed the KZG with some pliers and going to recap it with Sanyo WGs.
                                  Powercolor Radeon 9250 128MB AGP - this one is fine. No problems,though there's a "STONE"(I guess it's actually made from stone instead of electrolyte ) cap with a Ruby vent that I might replace in the future since it's sitting next to two diodes.
                                  Maxtor Diamondmax 9 6Y080L0 80GB PATA
                                  1x BTC CD/DVD-RW drive and 1x DVD-ROM
                                  and that's all. I found a Windows 7 Pro install on it.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • Compgeke
                                    • Feb 2014
                                    • 524
                                    Bought a Xeon W3520 for $5 off someone in an IRC channel.
                                    Seems they also threw in a single 1 GB DDR2 laptop ram module and a Core 2 Duo P8400 chip. Not bad for $5.
                                    • fjutrackx
                                      • Oct 2015
                                      • Belgium
                                      #1718
                                      Re: Your Best Dumpster Finds
                                      The best I ever found was a 42" lg flatron monitor / promo display in 2009 (which were sold until 2007 for about 7000 euro). That thing was only 4 years old.
                                      I fixed the screen, connected to a computer to watch movies and play games on. At home they only had CRT TV's, except on my room there was that big size monitor XD
                                      The same year I also found a computer with a Q6600 CPU. But.. speaking of the "belt" from a computer store.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #1719
                                        ^ Nice CPU... but man, 130 Watts TDP (and 224W peak)? That thing is power-hungry!
                                        • Compgeke
                                          • Feb 2014
                                          • 524
                                          Power isn't a huge concern with it. I'll be throwing it in my 2nd Precision T3500 whenever I get around to fixing that up to sell - I'd rather keep the i7 940 from it.
                                          I personally run an X5560 in my desktop being as it's a far lower power chip (95W TDP, 197 max) and I'd recommend the same to anyone else going with a 1366 chip. The 130s double as effective room heaters.
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
