Need to change thermal compound? How not to do it!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Well had 2 cards come in today for repair... First was a GTX 780 that was shorted to ground... Blatantly obvious where it had gone as had 3 vaporized ceramic caps and a very burnt and cracked inductor. Swapped them all an all working
    Next was a HD 7970 that failed to display.. So off I go strip the card down ready to pull the GPU and reball and I find this :
    Took me some time to clean that off I can tell you!
    So anyone who needs to apply thermal compound and has never done it before... The above is NOT how you do it!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8682
    Re: Need to change thermal compound? How not to do it!
    <sarcasm>MORE IS BETTER!</sarcasm>
    BTW your picture's not showing up for me... I'm just guessing what the picture looks like...
    • blasterboomer
      • Dec 2013
      • 135
      • United Kingdom
      Image is dead, shows the missing image icon for me.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Added link to post
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8682
          Re: For the love of god do not do this
          :o
          I suppose Zinc Oxide thermal compound was made for people who do this... (since it's not electrically conductive.)
          • ddscentral
            • Mar 2008
            • 151
            • Lithuania, EU
            OMFG...
            Did you fix that card ?
            • Joe Black
              eager to learn
              • Sep 2015
              • 173
              • southeastern europe
              Wow, that's impressive at least.
              stay classy
              • newtothis
                • Mar 2013
                • 1556
                • england
                Yes both working now.
                Took some time and a lot of IPA to clean the card down though!
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Yes that must of been an entire LARGE tube of TIM!
                  GPU has been reballed and reworked onto the card = All working
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    http://imgur.com/1EgQEZV
                    It would of been good if you also posted the pictures after you clean it up and re-pasted it correctly.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Still can do... I only apply cheap compound after a reball for testing then change it for mx-4 or 5 for final application.
                      So when I clean the cheap stuff off later I will take some pics
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3264
                        • Singapore
                        man wtf is this? thermal paste shaving cream? no surprises why the gpu failed there from too much thermal paste!!!
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          Non conductive, it was a BGA connection fault - Reball sorted it out.
                          I think it was more of a case of the owner thought it would fix it by changing the thermal compound (Seems a lot of people auto think that changing it will somehow bring the card back to life :S ) and had no idea what they were doing! I have moaned before when finding a mess under the heatsink but this took the biscuit! I ended up just dropping the entire card into a bowl of IPA and getting the toothbrush on it.. bloody messy job!
                            • 30953
                            you say non-conductive, but it has a capacitance.
                            you cant use it on high voltage parts!
                            • ChaosLegionnaire
                              HC Overclocker
                              • Jul 2012
                              • 3264
                              • Singapore
                              no, im talking about the way how applying too much thermal paste acts as a thermal insulator instead. the ideal proper way to apply thermal paste is as thin a layer as possible. too thick of a layer just acts as an insulator instead of a conductor. that is the proper way!
                              • blasterboomer
                                • Dec 2013
                                • 135
                                • United Kingdom
                                holy fuck... That reminds me of my friends laptop that he used to bring to college, It would overheat and get really hot so that it would shut itself down. He told me he put a few new tubes paste in it. immediately i was like "a few tubes?!?!", so i took it home and opened it up and there was literally thermal paste spread over the entire motherboard and all over the casing, i dont know how it even managed to boot still, cleaned it with water and let it dry for a day infront of a fan, reapplied paste the correct way. The next day when i saw him i asked wtf he had done and how many tubes he put in and he said 12 tubes so then i had to teach him how thermal paste is meant to be applied. The laptop still works to this day since i cleaned it up
                                • clearchris
                                  • Dec 2013
                                  • 687
                                  A little is good, a lot is better, right?
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    • Bulgaria
                                    WOW!
                                    That is quite a bit of thermal compound on there.
                                    I would have scooped it and saved it for non-critical re-use. There's enough to last you for a year worth of repairs with this!
                                      • 30953
                                      i was waiting for someone to say that!
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        12 tubes!?!?!?!?!?!?!?
                                        Permanently Retired Systems:
                                        Kooky and Kool Systems
                                        sigpic
                                        • Gcnewbie
                                          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                          by Gcnewbie
                                          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                          I opened the...
                                          03-29-2024, 06:55 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • caspian
                                          Can thermal paste cause corrosion?
                                          by caspian
                                          Dear members,
                                          I have got an ordinary gray thermal paste that has no name/model on the box.
                                          I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                                          I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                                          Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                                          Is it safe to leave the thermal paste on the pins?
                                          I guess the thermal paste...
                                          06-19-2020, 10:47 AM
                                        • Verlengsnoer
                                          Bios splash/logo change
                                          by Verlengsnoer
                                          at firs, i hope this is the right place to post my question.
                                          Im looking for a tool to change the bios logo.
                                          everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                          i know that HP has a build in option to change the splash logo.
                                          but i want to change the manufacturer logo to an own logo.
                                          I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                          10-28-2022, 09:52 AM
                                        • nobbnobb1
                                          Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
                                          by nobbnobb1
                                          I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
                                          There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....
                                          09-08-2022, 09:58 PM
