Ratdude's Main rig V3.5
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's Main rig V3.5
    Built it up before last night's Overnight shift, So far not so good. It BSODs upon bootup from a win7 DVD... and linux disks won't boot either (minus memtest86, whicha passed)
    Also, only the upper of the two PCIe slots yields video on POST... tried a different pair of GPUs I had sitting, no dice. I'll have to do more diagnostics later...
    I suspect it may be a cap issue, as the board is riddled with KZG's and while I trust that when gg1978 told me it was tested working he was being honest, I'm thinking two days in a warm/hot van may not have done them any favors. When my paycheck comes, I'll order caps and do a recap... and see if that helps.
    sigpic
    (Insert witty quote here)
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      I knew this would happen. Some strange firmware bug, software bug, bad driver, wierd quirk is going to do this shit.
      speaking of which, did you go through the board cmos settings? make sure nothing 'strange' is turned on? did the flash the bios on your sata card? get an updated boot driver? Sometimes win7 has a bad default ahci/raid driver (rings true with newer intel ICH's and Non-SP1 Win7 disks)
      maybe you should try to use onboard sata for the DVD? maybe you should try an IDE dvd drive (does the board have ide ports?) maybe you should try a USB adapter on an IDE or sata DVD, or install win7 from a flash stick
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Using the onboard nvidia sata for the dvd. Went through the bios, fixed any odd stuff. Nvidia sata is not in raid mode
        sigpic
        • c_hegge
          • Sep 2009
          • 5219
          Originally posted by shovenose
          Perhaps he should get a REAL computer... with a real, modern motherboard, an up-to-date CPU, a bunch of cheap DDR3, an SSD... and Windows 7 would install THE FIRST TIME with NO ISSUES...
          The occasional use of KZG caps aside, Tyan workstation boards are just about bulletproof. Way more so than even the most upmarket consumer boards, so his build does have an advantage
          EDIT: Looks like the original post was removed.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            research has turned up that people have installed win7 on this board with no problems.
            you just have the worst fucking luck with these things
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I NEED A THANKS BUTTON lol
              • Sparkey55
                • Jan 2010
                • 1523
                Finally... I have a final list of specs and part sources for my next personal workstation build.
                here's a part list:
                From V3, I am resuing:
                -Supermicro EATX case
                -Seasonic 600W PSU (may upgrade eventually, as 600W is kinda on the edge for what I'm doing)
                -2x AMD Opteron 285, 2.6Ghz dual core
                -16gb Kingston ECC DDR400
                -4x 73gb 10K WD raptors, w/ 3ware 9500s-4lp+BBU, RAID 0
                -Mitsumi Floppy/card reader combo, firmware upgraded for SDHC (may swap to a dedicated reader w/usb port if the floppy proves useless)
                -Hauppauge HVR-1600 (currently in a repurposed V2, will be pulled for the build)
                From stuff I had sitting:
                -Liteon DVD-RW, SATA. yes, brethin, this is the drive you traded me ages ago... it's being pulled from a HP D530
                -LG PATA DVD-RW: Found the other day at a goodwill for $4, I may use it elesewhere.
                - Regarding opticals, the future goal will be a DVD burner and a BD drive of some sort, both SATA, and at least one having lightscribe (since I have a buttload of lightscribe DVD+R's, got 60 for $9)
                -2x 120mm Arctic F12 CO PWM 2BB fans: I ended up buying 3 after I messed up and broke one
                -2x Stock AMD 940 coolers with 5k PWM fans added- combo of some spare coolers and the original fans from V2's 604 HP coolers. Very short wires, hopefully they'll reach .
                Sourced from other members:
                -Tyan S2895 Thunder K8WE w/SCSI and universal (flex) SLI bridge: gg1978 happens to both have one, is willing to sell it, and lives not far off a travel route I take almost every weekend. I'll hopefully be picking it up this coming friday...
                -2x Nvidia Geforce 8600 GT(s?), SLI'd- Bought of brethin after negotiating a decent price... I was going to get 9600's but given the relative difficulty of sourcing 9600's at a comparable price (Would have been about 30% more expensive on ebay, and only if I sniped my ass off). I've in the meantime redone the thermal compound/pads and cleaned the dust bunnies out of the heatsink on both cards.
                The reason I'm not sure if it's a GT or GTS is the chip's model no. shows as a GTS chip but Brethin told me they were GT. The cards have generic Nvidia branding, so no indication there. Based off google image searching, I actually think the cards are indeed GTS given image searching:
                GTS: http://videocards.productwiki.com/nv...orce-8600-gts/ (mine looks like this one)
                GT: http://videocards.productwiki.com/nv...force-8600-gt/ (mine doesn't look like that)
                It also has nothing but poly caps... so no recap required.
                And FYI, I didn't go for an 8800 GTS or two becuase of power draw, cooling, and reliability issues ( I already have one 8800 GTS 640mb in the junk bin, failed reflow, also takes 2 slots). These cards only use one slot, so combined with my case's mesh bracket fillers (lots of airflow cutouts), the fact there is only one slot between the cards shouldn't be an issue.
                OS wise, I'm going to run 7 x64... I've read of people getting it to work no problems... The SLI may be the only hiccup, as I've never set it up before... to those that have, is it fully HW, or is there a separate driver/SW setting to make it run? Is it part of the GPU driver, chipset driver, or a driver all it's own?
                I've attached a PSU calc. report of the build... I think my 600W will cut it... I think.
                Comments or questions? (Any "you shouldn't build workstations, buy a celeron instead" posts will be deleted, please be constructive).
                Why should anyone comment when you think you have the right to remove a post based on what you think is relevent? It looks like if it is something that you do not agree with out it goes. This mod power is going to your head IMO.
                • Ami Sapphire
                  Extreme Lurker
                  • Sep 2010
                  • 180
                  Seems so. I actually managed to get Windows Vista SP2 working on my Tyan Tiger MPX S2466N-4M board, even the onboard NIC which has no Vista drivers, with no issues... then I installed WinXP Pro SP3 on it. I probably could get Win7 working on my board if I even bothered to do so.
                  Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
                  I have two v2s and one v1.
                  I am still looking at these boards nearly every day.
                  What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    To those commenting on the post number one disclaimer: the job of a moderator is to keep rhreads on topic. This is not a "workstations suck" thread, so my disclaimer was warranted.
                    Any further complaints: pm topcat.
                    sigpic
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      #30
                      thats a 180 degree difference between his and your board. His is a 64-bit opteron server with an nvidia chipset
                      vista probably had your drivers built in cause its such an old board
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        #31
                        its on topic get use to it, we all have!
                        Follow the white rabbit.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Just as much as deer repellant is a hunting aid.
                          sigpic
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Moderators don't take sides.
                            • thesloc
                              Banned
                              • Dec 2011
                              • 587
                              #34
                              ECC Ram = FAIL
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                #35
                                exactly and this moderator power has gone to your head for sure! and if you start to ban any of us for comments stating how your MOD power has gone to your head, we will chat with chris too.
                                (this has happened on the forum i own before)
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5045
                                  • US
                                  #36
                                  yeah rat in memtest did you turn on ECC?
                                  • gg1978
                                    • Dec 2004
                                    • 431
                                    It was running with (8) 1GB sticks of Reg ECC DDR, that were HP server pulls and a pair of Opteron 848's. I did run memtest on it over the weekend before i pulled the board from the system it was in. ECC should have been enabled already. It had one of the 550W AcBel PSU's running it. I never did try the second PCI slot, it had a 9400GT in the top PCIe slot.
                                    • gg1978
                                      • Dec 2004
                                      • 431
                                      might find this helpful...
                                      http://www.tomshardware.com/forum/26...-windows-64bit
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5045
                                        • US
                                        #39
                                        I mean ECC in memtest86+, not in the cmos
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          ECC was indeed enabled. Not sure on Memtest... I knew it reported ECC status but I didn't know there were settings within memtest.
                                          My only other idea is since the upper pci-e wasn't tested... that could be the issue. Lot's of KZGs around there, so I'm still thinking a recap of all the KZGs would be a good idea just to be safe. KZGs make me wanna anyway...
                                          sigpic
                                          • Dobrowol
                                            Dell Latitude 3520 help with bios build/repair
                                            by Dobrowol
                                            Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                            Steps i done and results:
                                            I exported a clean bios from update file via pfs extract.
                                            1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                            Result: Dead
                                            2. Build clean bios with no changes in ME, new PMC, PCH
                                            Result: Dead
                                            3. Build old bios with clean ME, new PMC, PCH
                                            Result: The same
                                            09-22-2023, 02:43 AM
                                            ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                            This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                            09-12-2024, 03:28 PM
                                          • iotaa
                                            How to build this little device please for my campervan security
                                            by iotaa
                                            You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                            I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                            For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                            The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                            This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                            09-18-2022, 09:52 PM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
