NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    • Jul 2011
    • 6070
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery cells that do not have much running time and do not want to use a switching power supply for this purpose which is powered on all time even when not being used
    The BMS board that is on there right now might not be the one I use for the 10 watt version but going to use on the 50 watt version instead but I going to build a much bigger battery pack for this project for this purpose
    The battery pack that was used for testing purposes is going to used on the 10 watt power supply output for small current devices for this size battery pack
    I will be using a switch to turn off the power supply to the Zener Diode circuit board for longer running time because it is not necessary to leaving powered on when not in use
    The reason for this particular post is because I not very good figuring out Ohm law so that is the reason for posting this question
    It also been many years ago that I played around with Zener diode so this is the other reason for this post as well
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    normally these high wattage zeners are not for regulation, rather they are for OV protection...
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8349
      Yep. What eccerr0r said. These are not to regulate as such.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        if you're insisting on using the zener diode to regulate, resistor depends on how much current your device uses. Without knowing the device, it's impossible to tell what resistor is needed.
        If using as a OVP device, you don't need a resistor, making usage easier.
          • Jul 2011
          • 6070
          If I wanted to over voltage protection how would I do this the most efficient solution possible
          If want use it as a voltage regulator controller situation which voltage do I use to calculate the resistor 9.8 volts or 9.1 volts as the voltage used in the voltage calculator
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            OVP, just shunt the output with the diode... Heatsink not required.
            As a regulator, take the highest amount of current your circuit can possibly draw and select R with V=IR where V=(lowest expected source voltage - zener diode voltage). If you get a negative resistance, the circuit is impossible. Then you have to make sure that the wattage of the resistor is at least (highest expected source voltage-zener diode voltage)^2/R and the zener diode wattage is higher than ((highest expected voltage - zener voltage)/R)*(zener voltage) which should be less than 10 since you have 10 watt zeners. Heatsink is required most likely depending on the R that you find you need.
            You probably will find this resistor to be quite silly (usually less than 10 ohms) and it along with the zener will tend to get quite hot, hence this is why this circuit isn't used as a regulator directly without an amplifier. It of course is a linear shunt regulator, and worst case would just be an OVP.
              • 31269
              what are you powering?
              if noise is not an issue, remove one cell and use a boost convertor to 9v.
              if noise matters then boost to 10v and then drop down to 9v with a linear regulator afterwards.
                • 31269
                btw, stop talking about 9.6v
                it's a cell-pack, it has a minimum and maximum range not a fixed output
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  Batteries still have a nominal voltage.
                  Yes looks like this thread seems like a "I must use this" solution to a problem despite there being more efficient solutions out there. Using a zener diode in this fashion is really dumb, alas, if all you have is a hammer...
                    • Jul 2011
                    • 6070
                    I want to stay away from boost and buck converter
                    I was looking for a simple solution to make a 9.0 volt battery power supply
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8349
                      For what do you need exactly 9.0V for?
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        The reason why using a zener this way this is dumb because it actually is even worse than a linear regulator. Using a linear regulator with a transistor is actually more efficient - because a zener shunt regulator, whenever it's on it will consume full wattage whether you're actually using your device or not. At least a linear regulator, it will waste energy only when you're using your device.
                          • Jul 2011
                          • 6070
                          Don’t you have have at least two volts above the linear regulator output of the regulator rating if I remember correctly otherwise you might have low voltage output
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8349
                            Right! But why bother regulating a battery? A regular 9V battery doesn’t have 9.0V either when new. A non rechargeable lithium AA battery has like 1.8V! I don’t get it.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              You can also use an LDO, but knowing the load would be better, many can take the voltage swings from fresh to dead just fine and thus not need a regulator at all.
                                • Jul 2011
                                • 6070
                                I use to Alkaline battery cells that 1.65 new X 6 = 9.9 volts that dose not last very long at that voltage and stays 9.3 to 9.5 volts until falls below 9.0 volts and dies fairly fast at this point
                                Yes I might have fixated at 9.6 but real issue is when this battery pack is fully charged at 3.5 X 3 =10.5 which I not sure if the Blue Capacitor tester can handle this kind of voltage when the pack is fully charged now if it has a 5 voltage regulator in which I do not recall if it does or not but if it does then it does not matter if runs a little high I do remember however you can modify it to run at 5 volts but you have make a couple of changes for it to be able to run at this voltage
                                Zener diode do not come in all voltage flavors I know that 9.1 is one that would work but weather or not you find a higher voltage one is another story
                                But does this hold true for 9 volt multi meters can you run it at a voltage when the battery pack is fully charged this is the question
                                Dose this hold true for all 9 volt devices how much more voltage can you put to them before you start destroying them
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8706
                                  You can undercharge the cells too... that's another option? I think if it has a 7805 it's quite possible a higher voltage is just fine.
                                  Oddly enough I was looking at ICL7106 and apparently it can deal with higher than 9V just fine...
                                    • Jul 2011
                                    • 6070
                                    The Maximum voltage of ICL7106 is 15 volts assuming that it uses this ic chip or something similar in nature would work
                                    Dose under charging Lipo 4 to 10.2 volts how drastic would be the running time be I will have to test this and see if this is a good idea or not if I only lose a little bit of running time it might be worth it but now it time to take out my 12 volt switching power supply and see if I can make it go from 12 volts down to basically 11 volts is this switching power supply going to complain if I do this ( because some switching power supplies do not like working on lower voltage output if it is too low ) because I will need to put a diode on the switching power supply to keep the battery pack from back feeding the switching power supply if the switching power supply happens not being turned on for some reason
                                      • Jul 2011
                                      • 6070
                                      This is some what true however it working voltage is 9.6 to around 9.3 volts before the voltage start rolling out and this what I consider a non working voltage range because it does not last very long at this voltage level and above 9.6 volts it rapidly dropping down until it levels out to the working voltage output depends upon the current level that you are using I am basing this on a one amp load on these battery cells that I for this particular project granted the current draw would not necessarily be this high in every situation but I planning on using this battery pack on different types of devices so I have to go by some parameters in determining what is feasible and what is not feasible
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8349
                                        I think the blue ESR meter should handle that lithium ion battery pack just fine. Keep it simple, you said. Well this is as simple as it can get!
                                        Put 6 Lithium AA's at 1.85V per cell =11.1v! Puts that 10.5v from the rechargeable pack to shame, Open that meter up and check the voltage regulator(s), but this should be within tolerance no problem.
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
                                        • Vincenzo2
                                          Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                          by Vincenzo2
                                          My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                          Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                          I put some pictures here to show that it is labeled "M7"....
                                          09-07-2023, 07:43 PM
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
