Zap, zap and zap!
  • stevo1210
    • Oct 2006
    • 4156
    Zap, zap and zap!
    My friend's laptop keeps zapping her, and only her. I used it the other day and it didn't zap me whatsoever which is quite strange. Whereas if she uses it, we have an issue.
    Now the laptop is an Asus F5 entertainment series laptop. I checked the power cable and it is a grounded one. But I wanna know what the hell is going on here?!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Zap, zap and zap!
    Carpet.
    Tell her to pick up her feet or get rubber socks.
    Mann-Made Global Warming.
    - Dr Seuss
    • stevo1210
      • Oct 2006
      • 4156
      it happens on concrete as well for her. last time i used that laptop on carpet, i didn't have any issues.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Does it only do it with AC adapter plugged in?
        - Perhaps she has an outlet with no or a bad ground.
        - Dr Seuss
        • stevo1210
          • Oct 2006
          • 4156
          Only on AC power. On battery power, it's all fine.
          • Krankshaft
            • Jan 2007
            • 2328
            It sounds like it may be specific to that outlet. I'd check to make sure the ground and neutral are at the same potential.
            With a DMM on AC go between ground and neutral record the voltage then from hot to ground the voltage should be the same. A difference in potential can cause little irritating shocks on grounded metals. The neutral and ground are bonded together at the service panel to avoid differences. The only way for there to be a difference is a poor connection in a box somewhere down the line.
            On a few Wan Hung Lo laptop PSUs I opened they had the 3 terminal IEC connector but on the PCB the ground pin went nowhere. Hopefully this one was built properly.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              You probably have a bad outlet -and- a bad brick.
              A good brick shouldn't result in a shock even if the ground is missing.
              - Dr Seuss
              • stevo1210
                • Oct 2006
                • 4156
                Well I haven't inspected the brick yet. But why don't I get a zap from it too? or am I just built differently? LOL
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Were you using the same wall socket?
                  - Dr Seuss
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Sort of related but not a lappy. My Dell desktop took to shocking me when I touched any of its bright metal. The issue was caused by a power strip that was missing its ground pin. I would think that if the socket being used by her had a ground fault her lappy could zap her just like my desktop was doing to me.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      To get shocked you need a bad ground + some defect sending current to ground in the chassis.
                      - Dr Seuss
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Yup, same wall socket. I used it in the same spot that she uses her laptop every day.
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          Perhaps she wears a lot of polyester clothing and is generating a lot of static?
                          Ludicrous gibs!
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            The fact that she gets shocks and you don't depends on how thick you skin is, and how moist your hands are, amongst other things...
                            Not that I would recommend you to do this (death is likely outcome)
                            But if standing on a dry wooden floor you can actually touch the live AC wire at 230VAC and not get shocked, because there is not a "good enough" path to ground through you (it's like the bird sitting at the powerline wires)
                            However static electricity can still shock you, even if you are not properly grounded to earth.
                            That is due to the very very large potential difference, if you have been rubbing up against something creating static electricity and then touches your car (which is not itself grounded, since it stands on rubber wheels) you will still get a tremendous shock, this is because you and the car are brought to the SAME potential
                            You could have static electricity at 8000volts (this is the start of where you will see a blue flash from your fingertip when touching the car) and the car is at 0v so therefore it gets charged by your potential
                            Something similar could be happening with the laptop, if it IS properly grounded but you have allot of static electricity in you the static electricity gets a great path to ground when you touch the laptop, similar to the car analogy....
                            You could also do like I once did, use a 12v > 230VAC inverter in your car to give the laptop power, and get one HELL of a chock, this time because the car and laptop do NOT share grounding planes, because this particular inverter did not have a grounding prong
                            That analogy is similar to when you have a washing machine and some other electrical machine, when you make contact with them both you are suddenly the medium creating the "grounding" wire which is bringing these two devices to the same potential
                            It's all quite spooky and I could well be wrong on a count or two, but this is my general understanding of it anyway
                            • stevo1210
                              • Oct 2006
                              • 4156
                              That could be possible.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Same type shoes?
                                Maybe she's just hot for ya and can't help it....
                                Sweaty hands and all....
                                - Dr Seuss
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  Tell her to take off her clothes then repeat the experiment.
                                  And rub against everything (including you)
                                  I had a similar thing happen to me with a laptop. Basically I got shocked once, but never again after that, even though I wore the same clothes that day and the laptop was plugged in the same outlet. Different humidity throughout the day perhaps, I don't know.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    only if the computer is filled with porn...
                                    try a different outlet... keep in ming that the laptop might be a metal frame (latitudes, toughbooks, and thinkpads)... one scratch and you have bare metal that is normally a ground!
                                    sigpic
                                    (Insert witty quote here)
                                    • weirdlookinguy
                                      • Sep 2007
                                      • 1638
                                      You don't need porn to "troubleshoot" this problem as per momaka's suggestion, although if this laptop has a webcam, I'm sure you can MAKE a porno while "troubleshooting"
                                      • Hondaman
                                        • Sep 2008
                                        • 1092
                                        Quite a few times I have been shocked in the basement - I measured it -- 77 volts AC. My PC's UPS down there lights an LED announcing a "building wiring fault".
                                        I suggest the outlet doesn't always make contact with the device's plug (probably bad ground as other posters have said). In 1976-77, my Dad and the neighbor (a union electrician) added some outlets down there. Maybe the outlets made back then were poor quality -- just like the cars of that era....
                                        (My Mom used to get a shock when she touched the exhaust fan hood and the oven at the same time -- and with 230 volts instead of 120, this could be troublesome....)
                                        A (green?) triangle in the center indicates a super high-quality outlet with close parts tolerances (I've seen them and plugged stuff in to them). They probably cost a fortune though.
