Grounded motherboard
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    I have seen this yt video.
    I also have one desktop motherboard that is "grounded" i.e. it starts immediately when there is power applied to the board. I didn't notice any other problem with the board. Is this really a problem?
  • foshland
    • Jan 2017
    • 122
    • Spain
    Re: Grounded motherboard
    It can be fixed, but that solution is not allways the fix. 3 Days ago I had my testing PC rig "grounded" too and I cleaned just with a brush, without alcohol os similar and after that it was fixed too, but in case there is a mosfet or another component really groundedyou will need skills and tools.
    For sure the first thing is to clean, then to fix
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      I'm not sure this needs to be fixed. Except for starting immediately after connecting PSU to the power, no other problem is noticeable.
      Can this state cause further, more serious problems?
      Should I worry about this?
      • foshland
        • Jan 2017
        • 122
        • Spain
        Ahh, ok, sorry, I missunderstood, so its not grounded, what it has (almost for sure) is a option enabled in bios to start when AC power is back (for example after a blackout).
        Try to log into the BIOS and dissable AC power back or something similar, it uses to be inside power management section. If not founded you can post the exact model of the MB here or just reset bios to default, it will fix the issue
        • Adenitz
          • Jan 2021
          • 122
          • Congo
          Yes, thank you. It was BIOS option. I changed it and it is now behaves exactly as expected. When I saw this yt video, I thought my motherboard has similar issue. I also used multimeter to measure pin on connector where Power ON switch is connected. One side was ground, i.e. very small resistant, but other showed some normal value in diode mode.
          Is this multimeter test the only real way to test if the motherboard is grounded?
          • R_J
            • Jun 2012
            • 9535
            The motherboard is grounded to the computer chassis (usually with multiple screws) which is then grounded to the power supply chassis which is grounded via the third pin or ground on the a/c line plug
            In that stupid video, when he removed the bios backup battery to clean the board the bios reset to default which was likely stay off when power is applied. The way it was set before was likely resume state if power is interrupted. If the motherboard was ON when it lost power it will turn back ON when power is applied.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              I fixed this problem many times in various videos - all you need to do is remove the CMOS battery and fit a good one if the original is reading less that 3.0V (and if it is reading just 3.0V replace it anyway as it is nearly expired)
              Follow me on YouTube
              Learn Electronics Repair
              • Adenitz
                • Jan 2021
                • 122
                • Congo
                Hello Dicky96,
                which problem exactly did you solve by changing the battery? The problem that computer starts immediately when AC Power is applied?
                BTW, you have great YT repair videos. Thank you very much for that.
                • glovecaps
                  by glovecaps
                  11-25-2024, 04:23 PM
                • Docus
                  Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                  by Docus
                  Hi everyone 😀,
                  I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                  To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                  Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                  1. I already own the exact same model, but its plastic chassis is badly damaged.
                  06-10-2025, 04:24 PM
                • Archimedes
                  HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                  by Archimedes
                  Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                  Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                  Fans are spinning. Blindly could install windows11 and got the device manager...
                  07-30-2024, 05:14 PM
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
                • dragon3x
                  by dragon3x
                  power on.
                  Here are some examples :
                  switching supply area).
                  than 6.3 V.)
                  03-21-2025, 02:46 PM
