M65-F0 power supply issue
  • EazyBone
    • Jun 2023
    • 1321
    • United states
    Got this tv, no indicator light plugged in. First check PSU
    PSU has no stby voltages or anything, the main caps have 165 across them. I found this transformer (I believe) has all the cold side points grounded. Does this mean it has gone bad some way? The hot side isn't grounded at all points. Anyone know if supposed to be grounded here in picture.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Cold side will look like it's grounded because one side really is grounded...and other side, well it's a transformer and a piece of wire so it too will look grounded.
    The second picture is really low resolution, can't really see anything but should look for the switching controller and go from there. Are there SMT components on the other side, or are all the semiconductors and other stuff just hidden underneath the heatsinks?
    • EazyBone
      • Jun 2023
      • 1321
      • United states
      Thanks, learning still. Grounded all makes sense. All mosfets under heatsink except EL115/4/3/2 (clearer pictures now)
      Basically need to figure out why no voltage at all on hot side. Octocoupler shows like .8v coming out which is clearly wrong. Gonna mess with multi meter tonight hopefully find something
      Edit also no mosfets are shorted
      Edit I also don't know what a switching controller is. If you have an example I would appreciate it
      • EazyBone
        • Jun 2023
        • 1321
        • United states
        Have done more research and found that IC600 on back of PSU may be faulty, found a nick tv video, ordered one for $3 and will report back if it fixes
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
        • KYBOSH
          Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
          by KYBOSH
          I have a floodlight-security camera that recently died on me.
          its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
          Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
          07-01-2024, 06:54 AM
        • handsworth
          TCL 43S431 Backlight issue or Power Supply
          by handsworth
          I was wondering if anyone else has come across this problem. What was the problem?, and was it solved. I recently picked up 2 of these tvs and both initially diagnosed as bad backlights. When turned on, the backlights flash the red logo screen. Sound and an image is clear using a flashlight. So I buy 2 sets of leds. When they arrive I take one tv apart and test the leds before removing them. OMG they all work. but I put the new ones in anyway. So I think its the power supply. I swap PS from one to the other and same results. Now here is the issue and really confused me. I reset the tv using...
          10-16-2024, 04:29 PM
          03-31-2024, 02:12 PM
