Post help identifying capacitors here
This is a sticky topic.
    master hoarder
    • May 2008
    • 12175
    #101
    Re: Post help identifying capacitors here
    LF = possibly Nichicon LF series, if it has a blue text and mark for the negative stripe, though might be easier to reveal with a picture.
    If I'm not mistaken, C = 16V rating.
    • lethbrp
      • Apr 2023
      • 15
      #102
      [Like many before me I need some help identifying these SMD capacitors (see attached image). Could someone help me with this. Many thanks
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        #103
        10 microfarads , 25 volts .
        • lti
          • May 2011
          • 2555
          Those are bipolar, too.
          • lethbrp
            • Apr 2023
            • 15
            #105
            Many thanks
            • Dtreb
              • Jun 2023
              • France
              #106
              I've got an Asus X99 Deluxe for years, and few days ago, the PC won't start at all (no BIOS, no fans spinning, ...), only the "Start" and "Reset" buttons on the MB are lit. When I push the "BIOS flashback" green button, the NZXT Kraken, watercooling the CPU is lit while I push the button.
              What I noticed is that the two bottom PCI-e ports, and particularly the capcitor between these two ports is burning hot.
              I want to replace it to try to save the motherboard, with not much hope, but I'll try anyway
              Could you help me identify the 2 capacitors, and, if possible, the two other elements circled in red, please?
              What I can read from the bigger capacitor is:
              FP 10K
              48Cz
              271
              16
              And from the smaller:
              FP10K
              46*z
              561
              6.3
              (* is for character that I cannot read)
              The other two elements, from top to bottom:
              2R2
              434
              5OR
              And
              BA5P03
              BCD1638
              Second photo which is clearer for the bigger capcitor and the component just next to it:
              Would these capacitors be ok to replace the two on my MB?
              Nichicon RHA0J561MCN1GS
              Nichicon PCX1D271MCL1GS
              I'm not sure about the 20% tolerance. Is this acceptable or should I find a reference with a lesser tolerance?
              Also, I noticed that on the back of the MB, a MLCC was not properly soldered (only one side was soldered, the other one was not). Do you know the specs of these MLCC? Nothing is written on it, and apparently, a myriad of MLCC exist, so I'm lost.
              Thank you for your help.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                #107
                2R2
                434
                5OR
                2.2 microhenry inductor
                PeteS in CA
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  #108
                  FP 10K
                  48Cz
                  271
                  16
                  FP10K
                  46*z
                  561
                  6.3
                  2R2
                  434
                  5OR
                  And
                  BA5P03
                  BCD1638
                  (FP 10K
                  48Cz
                  271
                  16) : 270 microfarads , 16 volts , the rest is for series and codes , related to manufacturer .
                  (FP10K
                  46*z
                  561
                  6.3) :
                  560 microfarads , 6.3 volts , the rest is for series and codes , related to manufacturer .
                  (2R2
                  434
                  5OR) : Panasonic power inductor choke coil 2.2 microhenrys .
                  (BA5P03
                  BCD1638) : A discrete component , with no available data , probably undocumeted yet , but surely i's a LVR (Low voltage regulator) , Sot223 sc-73 or sc-89 (if you can give its exact dimensional measures , i can affirm more) . From its marking it's a positive regulator anyway (the "P") , and most probably , 5volts for the "5" , And 3volts for the "03" ..
                  I'll keep looking for it more .
                  (MLCC) : Please show its picture , to know if it's ceramic or propylene or else , etc..
                  • Dtreb
                    • Jun 2023
                    • France
                    #109
                    Thank you very much to both of you.
                    Here is the component on the back of the socket:
                    I removed it to be sure that it being desoldered would not damage anything else.
                    • Dtreb
                      • Jun 2023
                      • France
                      #110
                      Originally posted by jiroy
                      (FP 10K
                      48Cz
                      271
                      (FP10K
                      46*z
                      561
                      6.3) :
                      (2R2
                      434
                      (BA5P03
                      The unidentified component seems to be 3mm * 6mm. It's a bit tricky to measure, because it's between two PCI-e ports and the two capacitors, but I think this is the right measurement.
                      • jiroy
                        • Jun 2016
                        • 2416
                        • Lebanon
                        #111
                        That's a smd ceramic capacitor , basically to provide power and stability to the CPU . Measure any surrounding capacitor , they're basically the same here .
                        For the BA5P03 , I need more , including height and even the pins ..
                        • K46tank
                          • Jun 2023
                          Hello!
                          Can anyone tell me what these are and where to buy replacements?
                          Marked 1510A and 1310A
                          I have Google searched but haven't had any luck locating any info.
                          Thanks in advance
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #113
                            Looks like inductors, no need to replace.
                            • jiroy
                              • Jun 2016
                              • 2416
                              • Lebanon
                              #114
                              Those are discrete Through hole ferrite shielded radial choke inductors , and like Per Hansson mentioned , no need to replace , and they look super fine .
                              About the marking , 1310A stand for 13mm x 10mm , A for tolerance 5% , and 1510A stand for 15 mm x 10 mm , A for tolerance 5% .
                              Without labeling them with their inductance values , like mh inductance , makes them standard from any series from some unknown company . So the only way to know their real value , without a schema is to measure one of them . Next , you can have any similar 1310A , meaning 13x10,5% , from any other manufacturer , like this series attached , SRC1013 .
                              • K46tank
                                • Jun 2023
                                Thanks Per Hansson and jiroy!
                                I thought maybe they were inductors but I wasn't positive. I have one that is discolored, so much so that the marking is almost unreadable, and the ferrite "cap" has popped off so I'm pretty sure it needs to be replaced. I attached the above pic because the markings were clear. These are in a Samsung surround sound amp/cd changer. I'll order a few and replace the one that's lost its head and see what happens
                                Thanks again!
                                • udonome
                                  • Jul 2023
                                  • 14
                                  #116
                                  I have a motherboard MSI B350M Gaming Pro with missing components. One of it is a capacitor named in the schematic as "C560p50X4".
                                  I need help identifying it as I am trying to find a replacement from an old board Asrock G14C-S.
                                  The pads where it is missing are around 1.5mm apart so it should be really small.
                                  It would be helpful to know how i could use a multi meter to find one from the donor board.
                                  • cobovo
                                    • Jan 2023
                                    • 12
                                    • Ukraine
                                    #117
                                    Hi guys!
                                    Can some one to identify this type of smd capacitors from Gigabyte motherboard?
                                    • cobovo
                                      • Jan 2023
                                      • 12
                                      • Ukraine
                                      #118
                                      Originally posted by cobovo
                                      Hi guys!
                                      I found same logo on Asus motherboard at DIP type capacitor and then by boardview found needs to me series and type on website of manufacturer.
                                      This type
                                      https://www.apaq.com.tw/zh-cn/produc...pe/ACAS+Series
                                      • jiroy
                                        • Jun 2016
                                        • 2416
                                        • Lebanon
                                        #119
                                        Originally posted by udonome
                                        I have a motherboard MSI B350M Gami 1Pro with missing components. One of it is a capacitor named in the schematic as "C560p50X4".
                                        It's a smd capactor 560 picofarads or 0.56 nanofarads , 50 volts . Better test capacitors outside the donor board . Try find similar size and test it .
                                        • jiroy
                                          • Jun 2016
                                          • 2416
                                          • Lebanon
                                          #120
                                          Hi guys!
                                          That's a standard and very common capacitor smd 330 microfarads , 50 or 63 volts .. You can find it in any donor board .
                                          • varkatope
                                            Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                                            by varkatope
                                            Hey there, retro fans.
                                            I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                                            12-15-2024, 09:48 AM
                                          • dragon3x
                                            by dragon3x
                                            power on.
                                            Here are some examples :
                                            switching supply area).
                                            than 6.3 V.)
                                            03-21-2025, 02:46 PM
                                          • slybunda
                                            AA and AAA battery charger capacitors?
                                            by slybunda
                                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                            it has inside:
                                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                            2 x 470uf 16v LZ105c branded as G.Luxon
                                            not heard of these brands are they any good?
                                            iv attached photos of the charger and the board inside for an idea on the type of...
                                            12-24-2023, 04:41 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • Cama
                                            Solar Inverter - SMH-II - 2 missing capacitors
                                            by Cama
                                            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                            My model is : EASUN SMH-II 7 KW
                                            Mother Board : P/N 18947-002401250250
                                            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                            Thank you...
                                            Yesterday, 02:50 AM
