Post help identifying capacitors here
This is a sticky topic.
Re: Post help identifying capacitors here
Nippon Chemicon KY series is pretty much a direct cross.PeteS in CA
****************************Comment
MrWizzard - a couple questions - what was the power supply powering the system seeing as how they are on the +12V VRM input of the CPU buck regulator? Did it run 24/7 for several years? I find it slightly worrying hearing about Nichicon's HD series failing like that even though going by the “Z4” date codes (the 4th week of December, 2002, according to the JIS C 5101 standard) they are over 20 years old now and were in storage for years (not particularly great, especially for water base capacitors such as the HD series). Chemi-con KZE and Rubycon ZL should be a direct cross.Comment
MrWizzard - a couple questions - what was the power supply powering the system seeing as how they are on the +12V VRM input of the CPU buck regulator? Did it run 24/7 for several years? I find it slightly worrying hearing about Nichicon’s HD series failing like that even though going by the “Z4” date codes (the 4th week of December, 2002, according to the JIS C 5101 standard) they are over 20 years old now and were in storage for years (not particularly great, especially for water base capacitors such as the HD series).
O/P should definitely check out (and maybe show us) the power supply that was used. While it is possible that the caps "depolarized" if they sat too long in storage, I also agree that the PSU could be part of the reason they went - especially if it's not a new PSU but rather original with the system.
BTW, haven't seen you for a while, Wester547, but good to see you're back.
Other alternatives are:
Rubycon ZLH, ZLQ, ZLK, and ZLG series
Panasonic FR, FM, and FS series
United Chemicon KZH and KZM series
Nichicon HW and HV series. HE will likely work OK too, even though they are not quite up to spec as the HD series (on the other hand, HE is more durable.)
UCC KY is slightly lower spec (in terms of ESR and RC) compared to Nichicon HD / Ruby ZL / UCC KZE... but they've been proven to be very reliable and should work too. Just may not filter as much noise due to slightly higher ESR.
For what it's worth, UCC KY is a direct cross with Nichicon HE, Panasonic FK, and Rubycon YXG.
I usually go with whatever is cheapest on Digikey or Mouser... and Rubycon ZLH seems to be that series currently. Years ago, Mouser used to have Nichicon HD and UCC KZE very cheap (much cheaper than other series.)
I suppose for 1 or 2 caps for a motherboard, it doesn't really matter. But when buying for lots of stuff, it does "save" a few $ here and there, which I can then "re-use" for buying other caps and parts.
BTW, MrWizzard, consider replacing all of the 16V 1000 uF Nichicon HD caps at this point, since it's hard to say whether they blew from a possibly questionable PSU or just old age. Nichicon HD series are generally pretty reliable... though they are a little more "sensitive" (particularly with heat) compared to other series from Nichicon. Their next lower step series (HE) and higher step (HC) series are both more reliable for whatever reason.
While buying caps, also consider getting more caps for the rest of the motherboard. Better yet, start a new thread, post some pictures of the motherboard, and list what capacitors it has. Being an Intel i845 series, it probably doesn't have many other large caps, aside from the ones around the CPU. Look out for any brown caps with label "KZG", though - particularly if they are 6.3V 3300 uF. These are known to go bad too. Nichicon HM and HN series starting with date codes of H01_ _, H02_ _, H03_ _, and H04_ _ are also known to have reliability issues and should be replaced.
Anything 330 uF and up in capacitance is usually OK to leave as-is... though sometimes Intel likes to put some small caps around hot linear regulators (particularly in the area close to the AGP slot between the NB and SB). These may be bad too if you see the board darkened around the regulators and if these caps were in the vicinity.Last edited by momaka; 02-16-2023, 03:10 PM.Comment
Thanks from the first post this is what I ordered already. Hopefully they will work.
https://www.digikey.com/en/products/...6HwRTXu1qeNSWTComment
I don't know if the original capacitors were Nichicon's just the ones I was suggested to replace them with.Comment
+1
Anything 330 uF and up in capacitance is usually OK to leave as-is... though sometimes Intel likes to put some small caps around hot linear regulators (particularly in the area close to the AGP slot between the NB and SB). These may be bad too if you see the board darkened around the regulators and if these caps were in the vicinity.Comment
As for the Corsair CX500 PSU... it's probably too new at 5 years old to have bad caps. Of course, it never hurts to try to look through the fan vent to see if any of the caps inside look bulgy. And if the warranty is expired, feel free to crack it open. But again, I think it's still likely OK at this age. (Though if it has CapXon caps, you never know.)
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Comment
Are you sure it's not a 25 volt capacitor? From what I found, the capital E means 25 volts, whereas a lowercase j means 6.3 volts.Comment
Ryzen 3600x
FX-8802 Iron
In case you're wondering, here is the graphic I found:
If you don't mention the specific company whom made those capacitors , it's worth nothing but for the same series and the same company , so only useful for those whom know which company they're .
Different markings by different companies are like hair on my head .. Sanyo or Panasonic for an example put only the specific voltage and capacitance directly plus a series name , while they don't put "Sanyo" or "Panasonic" .. And so on .Comment
Here's an example from Sanyo .. Notice that , among other criteria , height and dimensions are specific to the company itself ..Attached FilesComment
BTW the capacitors that were asked about are Panasonic FK series. However, the letters for voltages work for Panasonic, Rubycon, and probably other brands.Comment
Is it bad or just acting bad because of the water damage/corrosion? Any 4.7uf 0603 is fine.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
looking for this cant find anywhere any help will be appreciated thanks
ic v718279Comment
by varkatopeHey there, retro fans.
I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...1 Photo -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... - Loading...
