Post help identifying capacitors here
This is a sticky topic.
  • lti
    • May 2011
    • 2555
    http://www.paullinebarger.net/DS/RM%...E%20Series.pdf
    Those look a lot smaller than 8x12mm, though.
    • udonome
      • Jul 2023
      • 14
      #142
      Thanks for the prompt respond.
      From your PDF, the chart shows the only part that matches the description 16V / 220UF is size 8x12 , right?
      But those on my boards seems to be of size 6.3x11.
      So i have a question, do the "(IR) Ripple Current " value and "(Z) Impedance" value have to accurately match the original ones ?
      I guess there is enough space available to replace them with the larger 8x12 but will it affect / degrade / damage the board ?
      • jm1234
        • Jan 2024
        • 61
        • Slovakia
        #143
        I'm trying to replace what seems to be a film(?) Epcos capacitors labeled with:
        Z111774865 P10
        U12 J 900 D8
        I'm guessing it's a 120nF 900V? But I would appreciate exact reference, because google doesn't find Z111774865 at all.
        They came from a Siemens induction heater, 3 of them are connected in parallel between the 2 wires that power individual induction segment.
        Their size is aprox. 26mmx15mmx7mm.
        Thanks for any help
        • radoslaw jaworski
          • Mar 2024
          • Wielka Brytania
          #144
          Hi all is anyone able to send me to right web page where i can buy one of those FP10K 07Cz 5 6 1 6.3. Thank You
          • James Boden
            • Mar 2024
            • 6
            • england
            #145
            Hi Iam trying to look for this on the net it states it's a 560 , 2DDtn p. But I can't seem to find anything about it .. on my meter it comes up as 1.5 uf so Iam a little confused and have started to think Iam doing something stupid.. any enlightenment would be appreciated 😆.
            • Major_Custom_Computing
              • Nov 2024
              #146
              Looking for help on this - missing from board. I'm new to this so not sure how to interpret.
                • 21389
                PC210 is 2200 pico farads , 0402 is the size , 25 Volts. You can find capacitor conversion charts online to convert between micro fardas uF , pico farads pF and nano farads nF .
                • kalemaroni
                  • Jun 2016
                  • 180
                  4.7uF 100v
                  (M)105c EH(M)10
                  9091537 (C)19091
                  Would like to know what ESR it needs for buying from Digikey/Farnell/Mouser etc.
                  • kalemaroni
                    • Jun 2016
                    • 180
                    Anyone know what the above cap is? Have I not provided enough info?
                    • filmbot
                      • Dec 2024
                      Anyone able to help fully identify this cap? Need to get a replacement. It was ripped off a Asus motherboard.
                      • Bushcat
                        • May 2023
                        • 18
                        • Japan
                        #151
                        Nichicon functional polymer, 560 uF, 6.3V
                        • kasfamily
                          • Aug 2014
                          • 774
                          • Russia
                          #152
                          http://www.chinsan.com/welcome/
                          • filmbot
                            • Dec 2024
                            Thanks!
                            • Bushcat
                              • May 2023
                              • 18
                              • Japan
                              #154
                              Elite/Chinsan aluminum electrolytic, EH series, 4.7 uF with maybe 20% tolerance, 100 V, rated to 105 C. If you search on the web site, Chinsan uses both 4.7 and 5 to refer to its 4.7 uF caps (and the usual 4R7 in parts numbers). The link in the post above me will get you started on your long, long journey through the Chinsan parts list... it's just a standard low-impedance cap so there are a lot of alternatives.
                              (Maybe that's a 47 and not a 4.7: the "." might be a reflection.)
                              • kalemaroni
                                • Jun 2016
                                • 180
                                Thank you very much
                                • ghost180sx
                                  • Jun 2021
                                  • 12
                                  Hey all. I'm recalpping an Artesyn P/N 22943505 PSU with SGI P/N 060-0021-002 Rev A for an Indigo2 IMPACT and have come across some bad caps that I can't identify a replacement for. They're red, very small, made by Marcom. I think they are FP-Caps (functional polymer/solid caps), but Marcom got bought up Nippon Chemi-Con a year before these caps were produced. They are 330uF, 6.3V, 105degC, red in color with a silver "-" stripe, 10x10mm and one of three on the board tested bad with an LCR meter. They are marked "CFM" (the series) and "9614" which I'm told is how Marcom prints the manuf. date of 1996 14th week.
                                  Let me know if you need a pic.
                                    SMDFlea commented
                                    Editing a comment
                                    pics would be good
                                • PeteS in CA
                                  • Aug 2005
                                  • 3581
                                  • USA, Unsure of Planet
                                  #157
                                  Given the age, if it is an electrolytic I'd suggest Nichicon PS, PM, PJ, or PW series, in that order of preference, whatever fits. I'm not sure whether polymer caps were coming into use in 1996.
                                  PeteS in CA
                                  • ghost180sx
                                    • Jun 2021
                                    • 12
                                    Thanks PeteS, that's what my friends in the SGI collector community have done. Then again, some have failed to repair their PSUs or had them fail after a recap. Most of us are flying "flying blind" tho as SGI never released any schematics.
                                    My PSU is working but outputting high ripple. It's very noticeable and was getting worse the more I used my machine, so I took it apart to fix the supply.
                                    This is the only one of three like it in the supply that tested bad with my LCR meter. The other caps in the PSU were getting old but in OK condition and within tolerances.
                                    Does anybody have any old Marcom data books or data sheets to confirm it's a polymer or what the CFM series was? I'd feel better replacing these three with a FP high ripple tolerant and super low ESR variant if that's what these are.
ID:	3531321Click image for larger version
                                    • ghost180sx
                                      • Jun 2021
                                      • 12
                                      My bad, these are made by Marcon, ending with an "n". Marcon Electronics, a former subsidiary of Toshiba Corp, then bought up by United Chemi-Con.
                                      See: https://www.procureinc.com/manufactu...ted_Chemi-Con/
                                      • Hitto
                                        • Apr 2019
                                        • 95
                                        • Italy
                                        #160
                                        Yes, Marcon (''N'') which is a diminutive of Marconi (in honor of Guglielmo Marconi, I suppose) and these are very old capacitors available in stores here in Italy in the era mentioned by PeteS in CA. They are still available as N.O.S. on some shops.
                                        I also reinforce that, given their era, this is not a polymer. I would replace it with a Panasonic FC but also Nichicon PM would be perfect (E.S.R. not too low and capable of handling high frequencies). I would derate and use a 10V replacement.
                                        EDIT: I confirm, electrolytic. As per specifictions in the inventory of a shop which sells N.O.S. parts. Picture attached.
                                        • varkatope
                                          Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                                          by varkatope
                                          Hey there, retro fans.
                                          I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                                          12-15-2024, 09:48 AM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • Cama
                                          Solar Inverter - SMH-II - 2 missing capacitors
                                          by Cama
                                          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                          My model is : EASUN SMH-II 7 KW
                                          Mother Board : P/N 18947-002401250250
                                          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                          Thank you...
                                          Yesterday, 02:50 AM
