Does anything less than 470uF usually bulge?
  • onetime
    • Dec 2007
    • 5
    Does anything less than 470uF or 1000uF usually bulge ?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Does anything less than 470uF usually bulge?
    Usually ones below 470uF dont cause problems, but I have another way of determining if it will cause problems.
    If it has a vent etched into the top, I usually inspect it.
    A man convinced against his will is of the same opinion still.
    • Spacedye69
      • Nov 2005
      • 698
      • US
      I've seen 100uf up bulge. If it has a vent, it can bulge. No vent=mess.
      • starfury1
        • May 2006
        • 1256
        its less likely but by "no means rule it out", its still very possible
        As with any cap it depends on the circuit and how its being used (or abused) heat around it etc
        Type of brand/series also is it crap brand cap.
        So as above at lest check/test them.
        Cheers
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          They usually don't vent, but since they are so small there is so little gas that could possibly build up so even if they have failed they still may not bulge...
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            1000uF bulging is very common.
            Like everyone else said about the 470's, it less likely but it happens.
            As I recall some of the 470uF you asked about in the other thread are 8mm.
            An 8mm 470 is -probably- more likely to bulge than say a 5mm 470.
            Failed caps don't always bulge.
            But bulged caps are always failed.
            Mann-Made Global Warming.
            - Dr Seuss
            • Big Pope
              Approved Vendor
              • Dec 2005
              • 426
              A nice conclusion!!
              ESR meter or caps meter are always our best tool. Need to check the old caps by these meters even it is a good caps brand.
              My SAMXON Capacitors Database HERE!!
              X-CON is a new brand for SAMXON's Polymer Capacitors.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I've seen a lot of LELON 470uF and 220uF caps fail. However, as a rule, caps below 1000uF tend not to fail. A lot depends on the brand, LELON being the most common for sub-1000uF caps failing.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Right now in my "to do" boxes I have
                  2 bloated leaking 470/16v [8mm] Elite on an LCD inverter board.
                  2 bloated leaking 470/16v [8mm] Fuhjyyu (1 each in 2 different) Antec power supplies.
                  4 slightly plump 220/10v [6mm] Chhsi (2 each in 2 different) MSI boards.
                  And something between 100 and 200 various 1000uF to do.
                  The small ones bloat just not as often as larger caps.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Oops, brain fart...
                    The 470uF Fuhjyyu in the Antecs are 25v.
                    - Dr Seuss
                    • bgavin
                      • Jan 2007
                      • 1355
                      IMO, any of the Fuh-kyoo caps should be replaced as a matter of course.
                      Pure junk.
                      • starfury1
                        • May 2006
                        • 1256
                        Well if it was me I would
                        • larrymoencurly
                          • Oct 2004
                          • 960
                          What about 0.1uF electrolytics?
                          Why do they use electrolytics that small instead of ceramics?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Been wondering that myself and haven't figured it out yet.
                            That's a good enough theory question to warrant it's own thread so I made one here:
                            https://www.badcaps.net/forum/showthread.php?p=85736
                            - Dr Seuss
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5038
                              • New Zealand
                              I had bulging 470uF Hermei in an LCD monitor
                              But I also replaced the 22uF and 1uF Elites with Rubycons anyway
                              I guess the only real way to know is with the ESR and capacitance meter... (which I don't have yet) so I just replaced the lot. Makes me feel better anyway
                              -David VanHorn
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I've had multiple 100uF and 220uF bulgers on different boards.
                                Usually Intel boards where they used 85c for the small diameter caps compounded by poor cooling from clogged fans.
                                - Dr Seuss
                                • smeezekitty
                                  • Aug 2009
                                  • 32
                                  2 Reasons that come to mind.
                                  1 So they will fail
                                  2 because eletrolytics tend to have less resistance across them over ceramics.
                                  • kingofcoins
                                    SaveOnGreen-Cap
                                    • Jan 2010
                                    • 162
                                    With LCD monitor repairs I find it quite common pulling badly bulged 470uf and 1000uf caps, especially those that are physically small for their designed capacitance. I also have observed bad caps down to 1uf, but I would agree apparent bulging in low farad cans is not common, vented or not.
                                    But if you're thinking of leaving small caps on the board, consider that testing of the caps I've pulled, shows a good 50 % test OK with a good ESR meter...so why did I pull them ? Its like when a good mechanic tears and engine down for repairs, he doesn't just replace one valve or one ring or one bearing, he replaces them all for much increased life and reliability for a minimum of expense while the job is being done. So the extra few minutes and that extra buck or two replacing those caps on your board, will pay off in the long haul. Besides where's the fun... if you cut and run ?
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      just had an itox mobo with 220/16 and 470/6.3 ost badly bulged and bottoms blown out.no vents.the bung was the vent.
                                      • gdement
                                        • Jan 2007
                                        • 690
                                        Weird - isn't ITOX a long-life brand? I'm amazed they'd use OST caps.
                                        • mo000
                                          470uf tantalum caps replacement
                                          by mo000
                                          hi
                                          motherboard toshiba C50 PT10F
                                          i found 2 bad 470uf tantalum in cpu sircuit making short .
                                          but i only have 380uf tantalum can i replace them with electrolytic caps .
                                          05-11-2021, 10:44 AM
                                        • gumball
                                          BenQ GW2450HM - Panel is partially dimmed, works for 2 hours after replacing few caps
                                          by gumball
                                          Issue: Panel is partially dark or dimmed, left side is okay (see photos attached).
                                          Trial: Replaced three visibly bad capacitors on the power supply board (see photos).
                                          First result: Monitor worked for two hours only. Two capacitors bulged again.
                                          Diagnosis: After replacing those capacitors the monitor was connected via HDMI cable to a laptop. Laptop was connected to power supply and charging. Power cable was removed from the laptop end and put back. Maybe this was a coincidence but since unplugging the power cable it was noted that the panel had darkened...
                                          10-10-2022, 01:54 PM
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          06-18-2025, 04:14 PM
                                        • notallbad
                                          Samsung LE37R88BD Bad T-con? picture lagging ghosting
                                          by notallbad
                                          Just thought I'd quickly write this one up!
                                          T-con - T370XW02 V5 CB 06A69-1A
                                          Main - BN41-00813B-MP1.0
                                          PSU - BN44-00157A (PSLF231501A)
                                          Invertor bd - 4H.V1448.481/C1
                                          Ghosting, laggy, colour distortion, dark picture
                                          Vgama readings from T-con:
                                          1 - 15.4v
                                          2 - 15.27v
                                          3 - 13.49v
                                          4 - 12.3v
                                          5 - 11.45v
                                          6 - 10.84v
                                          7 - 10.84v
                                          8 - 10.18v
                                          9 - 9.92v
                                          10 - 7.53v
                                          11 - 7.34v
                                          12 - 6.84v
                                          13 - 6.94v
                                          14 - 8.13v
                                          15 - 8.29v
                                          16 - 8.48v
                                          17...
                                          06-23-2020, 01:05 AM
