Samsung UN43NU6900FXZA 43" 4K - Power Supply Issue
    Re: Samsung UN43NU6900FXZA 43" 4K - Power Supply Issue
    BTW, when you removed that MOSFET on the heatsink, that MOSFET is for PFC Voltage booster, when you put it back are you getting 380 ~ 400VDC Voltage (measure between the legs of the cap) on the main 450VDC filter cap legs?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      I did not do any voltage measurements with that mosfet removed, I just checked it for shorts and removed it to identify it....it was mounted funny; face down. The only way to identify it was to desolder it. If you want measurements with it removed, I surely can.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        What I mean is that after you solder it back into the board, is the PFC Boost Voltage still present or not.
        BTW, I also forget to ask if the 3.3V is going up and down when you run the power supply board by itself or not without anything connected it but just AC cord.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Yes, it does... in sync with the faint 'chirp' I hear that's also in time with the blinking STBY/Power LED...
          Team : 49813
          Join in!!
          Team Stats
            can you pin point where the chirp is from?
            Since the 14V standby power supply is stable, there must be the problem some where in the step down power supplies/loads that is going on and off.
            • R_J
              • 9624
              What are the numbers on IC9101, I see voltage test points around it, like A_12v (always 12 volts) Is the A12V stable? I suspect the A_12V supplies other ldo's. I see what look like many ldo regulators in the picture with the heat sink removed.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Sorry for the delay, fellas.....I had to slide this aside to work on some other stuff....but I've got this one back on the bench.
                With the naked ear, no....it's very faint. I need to find my old stethoscope....it got lost in the garage (also good for finding boost leaks and vacuum hissing in cars).
                It's marked:
                Line 1: SLM4281A
                Line 2: 1833
                Team : 49813
                Join in!!
                Team Stats
                • R_J
                  • 9624
                  IC9101 has no datasheet, so I don't know if it has anything to do with the voltages in that area. You said the 14 volts is stable, did you check if any of the other sub voltages are also stable ie: A_12V
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    There is 12.5~12.9v there, drops/fluctuates ~.5v with the 'chirp'. With the aid of a stethoscope, the 'chirp' seems to be coming from TP801CS....but it's very faint, so I can't guarantee that....but that's where it was the loudest.
                    https://www.badcaps.net/forum/attach...1&d=1620847524
                    Team : 49813
                    Join in!!
                    Team Stats
                      • 22190
                      Originally posted by Topcat
                      It's marked:
                      Line 1: SLM4281A
                      Line 2: 1833
                      How many pins are there on that IC ?
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        Originally posted by smdflea
                        how many pins are there on that ic ?
                        16.
                        Team : 49813
                        Join in!!
                        Team Stats
                          • 22190
                          16.
                          Samsung use renamed Magnachip parts afaik, it could be a MAP3249 ,its the only 4-channel LED 16 pin IC listed on their site: https://cdn.badcaps-static.com/pdfs/...74f7b75b74.pdf
                          • basementtech
                            • Mar 2010
                            #33
                            Hello Topcat , did you ever do any good with this samsung ? I have the exact tv with same issues . thank you
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16959
                              No, I never did figure it out. I reassembled it and shelfed it hoping maybe I'd encounter one someday with a broken screen but a good board. It must be a common problem, there are no used boards anywhere for this thing.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Protractor_4transisters
                                • Apr 2022
                                • 3
                                Good day:
                                I am looking for a Service manual and schematic for this same model TV (UN43NU6900FXZA). I also have a power supply issue. No standby light, the fuse on the board is good, and about 170 volts is getting to the MOSFET (60R360QS), that same 170 Volts (DC) is at the transformer. I removed the MOSFET and tested it and other than having a high RDS of .7 ohms, ( I can't find a exact match datasheet for the MOSFET). I can only find a datasheet for a 60R360Q., that datasheet calls for an RDS of .36. I think it maybe OK? Oh and also the TV is about 5 years old and I noticed maybe after about a year of use the TV would go blank for a few seconds every now and again and then come back on in a second or two or three (Now the TV is dead). Any help would great.
                                  • 12331
                                  • U.S.
                                  #36
                                  [QUOTE=Protractor_4transisters;n3166147]Good day:
                                  I would check the solder joints on the powerboard and the electrolytic capacitors.
                                    • Apr 2022
                                    • 3
                                    I have tested all the capacitors (in-circuit) they all test (and look) good. I have not tested the ESR of the caps. though. Maybe I should just recap. the power section of the board? Any thoughts on that.
                                      • 12331
                                      • U.S.
                                      #38
                                      That would eliminate them as suspects.
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16959
                                        FWIW, I checked all those caps on my LCR. They were fine.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • captainKKK
                                          Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                          by captainKKK
                                          Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                          02-17-2022, 08:59 PM
                                          09-07-2024, 05:50 AM
