Sharp LC60C6400U - 2 long binks, 5 short blinks error code
  • nomoresonys
    • 12335
    • U.S.
    #41
    Re: Sharp LC60C6400U - 2 long binks, 5 short blinks error code
    https://www.youtube.com/watch?v=YLAVfokdcSU
    • nomoresonys
      • 12335
      • U.S.
      #42
      https://www.youtube.com/watch?v=eEJoPCa7Kt0
      • Noobwithamultimeter
        • Apr 2021
        • 94
        Thank you nomoresonys. Are Sonys that tough to work on you've sworn them off?
        Also just re-tested my voltages on the KIA378R12PI which is what I originally thought was the problem, now not so certain. But the final peg reads 2.68
        It originally read 2.5V so I'm worried it's broken now possibly causing this fussy fault-finding set to throw a tantrum over turning on. I'd like to know the jump technique - I haven't been able to jump the feet on the regulator myself, not sure what I'm doing there even though I've read the threads about it...
          • Apr 2021
          • 94
          What value should NUR460 on my board be when I test it with multimeter? Should I test it when the set is off or on? Leaning towards this part as failing as it is reading 0V on both ends, but I see a slight flutter on the reading, but it settles at 0V.
            Is the PFC Voltage booster not working? Is that why you are checking the PFC section?
              • Apr 2021
              • 94
              It could be one thing leading to the whole failure. I've been reading on the board and found it to be a catch-all error code so I'm not sure.
                • Apr 2021
                • 94
                Everything looks clean. All the LEDS are clean looking with no brown or black marks on them, all the ICs on the sides and bottom are new looking with no melting or anything and the image has no lines in it when it's working. Just haven't been able to turn it on since the last failure. Stopped working mid-movie and no progress since.
                  • Apr 2021
                  • 94
                  I just found someone with a similar code 2 blinks 2 blinks with a failed NUR460. I'm grasping at straws now.
                  • nomoresonys
                    • 12335
                    • U.S.
                    #49
                    That's a diode you have there in your picture: https://www.youtube.com/watch?v=nQpXBHEn09A
                    • nomoresonys
                      • 12335
                      • U.S.
                      #50
                      In retrospect sonys aren't really that bad, I prefer them over samsung as far as reliability goes, specially since 2013 or so when they went to all led backlighting, later came oled which has it's own problems of course.
                        • Apr 2021
                        • 94
                        Yes I now see youtube videos of dead pixels on those OLEDS.
                          • Apr 2021
                          • 94
                          NUR460 reads 499, then 498. I think that means it's ok.
                          • R_J
                            • Jun 2012
                            • 9638
                            If there is a NUR460 (made by NXP) in the location, D7805, it could be shorted and needs to be replace with the MUR460 (made by Lite-on), This was in a Sharp bulletin.
                            If D7805 IS indeed shorted it would effect the PFC voltage which can be measured across one of the main filter capacitors. (160vdc in standby) (385vdc with power ON)
                              • Apr 2021
                              • 94
                              Aha! Now we're getting somewhere. D7805 is on my board, I tested it and there are numbers coming through. Just not sure what the values should be. But I know it would be lower than 1000 according to youtube.
                                • Apr 2021
                                • 94
                                So the MUR460 is a stronger part? Worth a shot if Sharp told their techs about it.
                                • R_J
                                  • Jun 2012
                                  • 9638
                                  This will only effect the PFC voltage. I doubt its your problem if you are getting UR13.2 volts on PD pin 5,6,7,8 ,or a simple check of the voltage ACROSS one of the main filter capacitors (C7800A or B) in the primary will give the answer.
                                    • Apr 2021
                                    • 94
                                    Oh, can you tell me how to check that? I have a few hours to kill. Still tinkering.
                                      • Apr 2021
                                      • 94
                                      Those are the big boys I have to discharge when I work on the board. Scary.
                                      • R_J
                                        • Jun 2012
                                        • 9638
                                        Check the voltage on plug PD pin 5,6,7,8 If it is 13.2 volts (or close to it) the pfc circuit is working and there is no need to check the voltage across the main caps. And DO NOT short those caps to discharge them you will kill the board.
                                          • Apr 2021
                                          • 94
                                          Yes pin 4 on KIA378R12PI is still 13.19V
                                          Bad news for you and me - that's how I've been discharging both main caps every time I remove the main board. Across the leads one at a time with a screwdriver until I see sparks.
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • cm0002
                                            Sharp LC-55N7000U 1 long 5 short blinking, no display
                                            by cm0002
                                            I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                                            Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                                            I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                                            06-19-2023, 06:21 PM
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • Charrlie
                                            Sharp Lc-70le734u blinking 2 long 5 short
                                            by Charrlie
                                            Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                                            So I busted into it and have done the following:
                                            -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                                            07-07-2022, 02:02 PM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
