Sharp 80” long short flash backlight error - Help
  • Superbee_dad
    • Jan 2025
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing green led.
    > I have 110 volts DC at the LED driver MOSFET and 192 DC volts at the L1 LED string input connection. I found a spec for the LED input voltage of 215 volts. Backlight lights up in Service Mode.
    > I removed the front panel and checked the LED strips with an LED backlight tester. I recorded 183 volts at each light strip and all LEDs light up bright. There are 15 rows with 21 to 24 LEDs per row.
    > I checked voltages at the FETS on the return circuit. The voltages at the collector pin were 36 volts DC (+ or - 1/2 volt) at every FET. There are 15 FETS, one for each light string.
    > This is where I found a peculiarity. I checked the voltage at the emitter of each FET and I also got 36 volts which I would expect … except for 4 FETS all beside each other had double or triple voltages. Three were 70 volts and one had 93 volts. I checked the gate voltages and they all are 5.5 volts except these 3 have 1.5 volts and is one has 18.4 volts. I removed the FETS from the board. There are 4 per heat sink so I removed 8.
    > I checked the FETS with a multi meter following an online transistor test procedure. They all checked the same … okay.
    Any ideas as to what is going on here and or what my next steps should be????
    Thank you in advance. All expert opinions are immensely appreciated.
  • SONY_E-WASTER
    Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
    by SONY_E-WASTER
    Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
    The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
    then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
    does...
    12-26-2021, 05:46 PM
  • u666sa
    HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
    by u666sa
    Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
    Platform: ipa32 la-m024p rev 1b
    Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
    I found a short on the other side:
    10-04-2025, 05:03 PM
  • Charrlie
    Sharp Lc-70le734u blinking 2 long 5 short
    by Charrlie
    Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
    So I busted into it and have done the following:
    -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
    07-07-2022, 02:02 PM
  • valvashon
    Sharp R-930CS microwave/convection oven, dim display
    by valvashon
    Older microwave/convection oven I picked for free on Marketplace. Previous owner replaced turntable motor which didn't fit in the mounting hole properly. Shaft was at an angle causing plastic thing that fits onto it to eventually break. Filed the hole bigger, fitted the motor correctly, put on a new plastic thing, all (almost) is OK.
    The fluorescent display is quite dim. The camera doesn't see what the eye sees so these pictures are brighter than what the display really looks like:
    As you can see even from these pictures, the tops and bottoms of the...
    11-14-2025, 12:34 PM
  • Loretto
    Samsung SMPS BN44-00339A
    by Loretto
    this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
    I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
    I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
    I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
    03-29-2025, 08:30 AM
