BN44-00517C dead - blown cap, resistor and fuse
  • bobby4star
    • 9
    Hi All,
    I have a UE32ES6540 which is dead, customer reported a pop and a puff of smoke. PSU is BN44-00517C and has blown 221k 1KV cap, next to this a blown resistor RM811. Board mains fuse is blown.
    Has anyone seen this problem and will changing the cap, resistor and fuse likely fix it? One more ask, can anyone give me a 2nd opinion of this resistor rating of RM811? I think it's 0.24 Ohms but would like a 2nd opinion! See attached pic.
    Thanks!
    Bob
    Re: BN44-00517C dead - blown cap, resistor and fuse
    Very common problem for those snubber ceramic cap to short out like that, it is connected in parallel with Source and Drain pin of that MOSFET, so when the cap shorted out it will usually take out that Source resistor with it, you still should check the MOSFET to make sure it is also not shorted out either, you also need to check the bridge rectifier to make sure it is also still OK.
    That flame proof resistor is 0.24 Ohms.
    The cap should be replaced with 2KV rating instead of 1KV as original is rated at.
    You may be as lucky as this guy, anupkg1985, in this thread here:
    https://www.badcaps.net/forum/showth...ht=snubber+cap
    • bobby4star
      • 9
      Hi budm,
      Thanks for your message, i will check for shorts on the fet, yes i have some 2kv caps as change these quite often on sone of the older 32" boards that come in to me. Thanks for confirmation on the resistor, i will order sooner if those in. Will confirm if the repair works! Thanks Bob
      • bobby4star
        • 9
        Hi, do you reckon that will be a 2w or 3w resistor? Cheers! Bob
        • dazzystar
          • Dec 2023
          • 25
          I know this is an old thread but I'm hoping someone can help. I'm also having the same problem with my BN44-00517C board. The cap and resistor I have ordered but I have no clue what the MOSFET model is. Can anyone help?
          Cheers
          Daz
          • diif
            • Feb 2014
            • 6978
            • England
            Cheers
            Daz
            The MOSFET should have some markings on it.
            • dazzystar
              • Dec 2023
              • 25
              Thanks so much for the reply. The MOSFET is completely blank. I've looked at a YouTube video of a similar Samsung TV PSU board and the MOSFET there is a 10NM60N so I've ordered one from ebay. Let's hope with that, a new cap and resistor it'll work!
              • lotas
                • Jan 2016
                • 4653
                • Russia
                Don’t forget to replace the SSC2S110 PWM and check its wiring (smd resistors, stabilizer bars, diodes...)
                • EazyBone
                  • Jun 2023
                  • 1347
                  • United states
                  Why would 2kv be better to put here? Wouldn't that change something ? Am asking for future repairs. Cause I just don't understand them yet, I always replace with same one
                  • dazzystar
                    • Dec 2023
                    • 25
                    Got to change that as well? That's not gonna happen...looks like the bin for the TV then.
                      • 12206
                      • U.S.
                      It can handle more, lots of times the makers are using the cheapest lowest capacity components they can get away with and they go bad and blow up pretty easily, so going up in voltage on caps is usually recommended for that extra headroom.
                        • 12206
                        • U.S.
                        Aren't there any cheap powerboards on ebay, sometimes they are pretty reasonable. But being a 32 it might not be worth messing with, unless you have a need for a 32 somewhere.
                        • dazzystar
                          • Dec 2023
                          • 25
                          Yeah. 32" was for our bedroom. Can't find any of the same PSU boards anywhere in stock in the UK ATM.
                          • dazzystar
                            • Dec 2023
                            • 25
                            It's a BN44-00517C by the way.
                              • 12206
                              • U.S.
                              I saw this: https://www.buyqual.com/pd32b1d-csm-...wer-board.html
                              • EazyBone
                                • Jun 2023
                                • 1347
                                • United states
                                Just change the things that are broken. Fuse/cap/mosfet. And try it since you ordered it already.
                                • dazzystar
                                  • Dec 2023
                                  • 25
                                  will change the broken parts and give it a go. cheers guys.
                                  • lotas
                                    • Jan 2016
                                    • 4653
                                    • Russia
                                    If you do not replace the SSC2S110 PWM, then the first time you turn it on, the mosfet and fuse will burn out again...
                                    • dazzystar
                                      • Dec 2023
                                      • 25
                                      well then it will definately go in the bin after that!
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        Why not replace the SSC2S110 whilst you're replacing the other components ?
                                        • dellxps15
                                          macbook a1707 15 inch trackpad dead. blown fuse identification
                                          by dellxps15
                                          hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                          another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                          04-30-2024, 10:48 AM
                                        • magneh
                                          Is this some kind of fuse resistor ?
                                          by magneh
                                          Hello guys
                                          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                                          Seem to me like some kind of fuse resistor?
                                          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                                          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                                          The red band is larger than the 4 others, but I dont have much experience with these components.
                                          Also one of the orange...
                                          02-10-2025, 07:54 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
