Hi! I have almost the same power supply (BN44-00517A, I suppose the only difference is in the shape of the power connector), but in my case another converter (logic power supply) failed, and the backlight channel should be working. I can measure almost any element of interest on my board in the next few days (including SMD capacitors with a meter). What element values do you need? On my board, the CM804 capacitor burned out, and I can't read its marking. Could you take a photo of its marking on your board?
BN44-00517C dead - blown cap, resistor and fuse
Hi Dhikn,Hi! I have almost the same power supply (BN44-00517A, I suppose the only difference is in the shape of the power connector), but in my case another converter (logic power supply) failed, and the backlight channel should be working. I can measure almost any element of interest on my board in the next few days (including SMD capacitors with a meter). What element values do you need? On my board, the CM804 capacitor burned out, and I can't read its marking. Could you take a photo of its marking on your board?
Yesterday I've managed to repair my board.
In addition to other faulty elements, one Zener diode was also faulty, but it measured ok with a diode checker, so it went unnoticed.
On my board CM804 is a ceramic capacitor 220pF, 1kV (marking is 221K) - it failed on my board for LED power also.
When replacing, put a 2 or 3 kV capacitor - it failed because of low voltage rating.
If it has failed then some other components are dead also - resistor 0.24 ohm RM812 (on my board), MOSFET, etc...
The schematic is pretty straightforward, and the PWM controller SSC2S110 is available on Aliexpress.
Good luck!
DinkoComment
by dellxps15hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .4 Photos -
by magnehHello guys
Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
Seem to me like some kind of fuse resistor?
After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
The red band is larger than the 4 others, but I dont have much experience with these components.
Also one of the orange... -
by BabbarI found a project in the electronics trash yesterday. A nice Argon SA1 audio amp with some electrical issue. Took it apart and saw that the 4A250V fuse was blown so started lifting components to find the short. Eventually got to two MOSFETs (model FTA14N50C) that are shorted and when i took them out the short was gone.
Now i didn't have any replacements of the same model of course but i found a couple with pretty similar spec i thought (K10A60D & K12A50D) and put them in. Also replaced the blown fuse with a 3.5A250V one. Checked another time for short circuit and plugged it in.... -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
- Loading...
