Is this some kind of fuse resistor ?
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Hello guys
    Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
    Seem to me like some kind of fuse resistor?
    After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
    They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
    The red band is larger than the 4 others, but I dont have much experience with these components.
    Also one of the orange bands looks like brown due to burning, but on a clear part of it, Im pretty sure it was orange to start
    Some pics attached.
    I think its a 33 ohm fuse resistor wafer as on the second band there should not be a golden color.
    What you guys think?
    Should I try replacing these 2 components or not worth the shot?
    Appreciate any help!
    Best
    • 31256
    MELF packaged resistors i think - turn a light on next time
    • redwire
      • 3912
      To me looks like a couple MELF 0207 resistors with a solder bridge between them. Some Vishay have a brown body, others blue MMB series.
      • magneh
        • Apr 2014
        • 616
        • Portugal
        Thank you both!
        Yes MELF 0207
        What about the color band.
        The red one being the thicker band means something? like last band or tolerance band?
        or the reverse?
          • 31256
          well the image is dark, but:
          orange,orange,black,gold,red ? maybe?
          so 330 and a divide x10 so 33 and finally red whitch would be 2% tolerance.
          • redwire
            • 3912
            Vishay 5-band color code
            yes 33Ω 2%
            • corrize
              Replacing resistor fuse in Sony DV charger
              by corrize
              Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
              So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
              It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
              06-30-2025, 06:59 PM
            • corrize
              A funny fuse story – Lumix LX100 II
              by corrize
              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
              10-19-2023, 09:58 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • bobby4star
              BN44-00517C dead - blown cap, resistor and fuse
              by bobby4star
              Hi All,
              I have a UE32ES6540 which is dead, customer reported a pop and a puff of smoke. PSU is BN44-00517C and has blown 221k 1KV cap, next to this a blown resistor RM811. Board mains fuse is blown.
              Has anyone seen this problem and will changing the cap, resistor and fuse likely fix it? One more ask, can anyone give me a 2nd opinion of this resistor rating of RM811? I think it's 0.24 Ohms but would like a 2nd opinion! See attached pic.
              Thanks!
              Bob...
              11-12-2020, 12:46 AM
