Lg 65UH655O BARS ON THE SCREEN
  • gabe1022
    • Nov 2016
    • 12
    • united states
    Any help would be appreciated. I'm not sure if i have t-con, main board, or panel issue?
    Re: Lg 65UH655O BARS ON THE SCREEN
    More likely to be panel.
    You need to open up the back and see if the T-CON, tab bonding boards are on the bottom edge of the LCD panel or not.
    Did anyone spray the screen with cleaner to clean the screen?
    • gabe1022
      • Nov 2016
      • 12
      • united states
      1st pic is with cable 1 left side unplugged from t-con, and pic 2 is right side
        So can we see the backside of the TV?
        • gabe1022
          • Nov 2016
          • 12
          • united states
          Here ya go
          • budwich
            • Jul 2015
            • 3097
            were you inputting a signal during those tests.... the other side should have shown a picture.
            • gabe1022
              • Nov 2016
              • 12
              • united states
              Just the home screen that was shown in the original picture. That is kinda what lead me to believe it wasn't a panel issue. Thoughts?
                So do you get picture just like in post #1 when both cables are back in place?
                • gabe1022
                  • Nov 2016
                  • 12
                  • united states
                  Yes
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4458
                    • Italy - Milan
                    I had the same exact defect on a little older LG, it's a common issue on LG panels, the problem is on the source driver cof that began to slightly desolder, i have fixed it for some minutes but i had too much hurry to remount the bezel, the story is long, i ended cracking the cof due to shim mal positioned, its not easy when there is not a confortable plane of work. I think a better technique than mine can be used to fix it much faster and better with the use of a simple soldering iron stylus.
                    not on the LG..
                    NOTE: A COF is a chip! not the band that holds it.
                    • Diah
                      • Feb 2013
                      • 6435
                      Just the home screen that was shown in the original picture. That is kinda what lead me to believe it wasn’t a panel issue. Thoughts?
                      download the zip from this post and extract the test photos on USB formatted FAT32, then play them on yours TV show us the result..as:
                      !- BOTH ribbon connected
                      2- both side with one ribbon in place
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • netgearnetgear
                        TCL 43S423 TCON OR PANEL FAULTY???
                        by netgearnetgear
                        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                        08-20-2025, 06:04 PM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
