Philips 37PFL8605 not booting
  • debruina
    • May 2020
    • 29
    • Nederland
    I need some help with a Philips 37PFL8605 board. TV has no image and gives error 53. Voltages are all ok. If i connect a uart it gives the below output.
    FSBL-CI+ 550 (007)TLB-DONE
    FLASH RESET
    SECUREBOOT-ENABLED
    U▒U
    UBOOT-OK1
    U-Boot 2009.01_Production (Jul 05 2010 - 11:09:21)
    DRAM: 512 MB
    NAND: 512 MiB
    Bad block table found at page 262080, version 0x02
    Bad block table found at page 262016, version 0x02
    ECC failed step 0
    nand_bbt: ECC error while reading bad block table
    nand_read_bbt: Bad block at 0x000c0000
    nand_read_bbt: Bad block at 0x005c0000
    nand_read_bbt: Bad block at 0x00c80000
    < lots of the same lines of errors here 3 or 4 pages>
    nand_read_bbt: Bad block at 0x1fec0000
    nand_read_bbt: Bad block at 0x1ffe0000
    .Env: NAND @ 0x00580000
    In: serial
    Out: serial
    Err: serial
    Model: M1 (a1530100)
    bootcmd1
    BOOTREASON=coldboot
    Sending: 00 04 00 02 05 00
    Sending: 00 04 00 02 05 01
    Creating 1 MTD partitions on "NAND 512MiB 3,3V 8-bit":
    0x00b00000-0x07980000 : "mtd=2"
    UBI: attaching mtd0 to ubi0
    UBI: physical eraseblock size: 131072 bytes (128 KiB)
    UBI: logical eraseblock size: 126976 bytes
    UBI: smallest flash I/O unit: 2048
    UBI: VID header offset: 2048 (aligned 2048)
    UBI: data offset: 4096
    UBI warning: init_volumes: static volume 0 misses 4 LEBs - corrupted
    UBI warning: init_volumes: static volume 1 misses 15 LEBs - corrupted
    UBI error: init_volumes: not enough PEBs, required 844, available 841
    UBI error: ubi_wl_init_scan: no enough physical eraseblocks (-3, need 1)
    UBI error: ubi_init: cannot attach mtd0
    UBI error: ubi_init: UBI error: cannot initialize UBI, error -12
    UBI init error -12
    My first guess was that the NAND had so many badblocks it had no longer enough room to create the MTD partition. So i made a dump of the original nand and wrote it back to a new NAND chip. However i have exact same problem. If i check the original nand on bad blocks then there are only a few. No i am wondering if the error is maybe about another flash device.
    So maybe someone can explain a bit better what happens here. I assume it is still running in bootloader. Also maybe someone has a known working nand image.
    Regards
    Arnold
  • CapLeaker
    Leaking Member
    • 8327
    Re: Philips 37PFL8605 not booting
    maybe there is too much corruption on your dump. The flash is too far gone, or something important got corrupted. Try to find a dump online and copy that on the new flash.
    • debruina
      • May 2020
      • 29
      • Nederland
      I am still new at this nand stuff, so maybe a silly question. I don't really understand how a new nand chip has the same bad block errors in the log?
      I can see how the OS maybe is too corrupted for boot but i would have expected a different log after replacing the nand chip. Or did i actually somehow copy all the bad blocks/marks to the new nand chip? I tried finding a dump on the internet but so far no luck
      • debruina
        • May 2020
        • 29
        • Nederland
        Did some additional research. If you make a hardcopy than apparently you copy everything over to the new nand. So i used another option in the programmer: skip bad blocks and reallign, soldered this new chip onto the board and it booted. No more bad blocks and linux boots. But as expected parts are corrupted. The TV goes into a reboot loop because the tv application won't start/crashes and it restarts the OS. Also trying to recover from USB doesn't work because of a missing recovery volume. Ah well. i learned a few new things
        • William1967
          • Nov 2017
          • 215
          • Netherlands
          Error 53. This error will indicate that the PNX8550 has
          read his bootscript (when this would have failed, error 15
          would blink) but initialization was never completed because
          of hardware problems (NAND flash, ...) or software
          initialization problems. Possible cause could be that there
          is no valid software loaded (try to upgrade to the latest main
          software version).
          • debruina
            • May 2020
            • 29
            • Nederland
            software version).
            Yeah I know. The nand is bad and i need a nand dump of a working board
            • debruina
              • May 2020
              • 29
              • Nederland
              Made some progress. I found a NAND image for this model and loaded it into a new NAND. The TV is now booting and i have a image, home menu and everything seems to work. But after 30/40 seconds it reboots and everything starts over. The last log message is:
              00 <5>~000029603 Get key
              00 <5>~000029603 Number of Keys found 4
              00 <5>~000029824 ChanDec: FEL=0, UNCOR=0
              00 <2> 000030094 Exception in process 226: address not mapped to object
              00 <2> 000030095 EPC = 0x2e25c4f8
              00 <2> 000030095 RA = 0x2e25dde8
              00 <2> 000030096 BADVA = 0x12345678
              SYSLOG: DEBUG DUMP 000000: Exception: address not mapped to object, process = /philips/apps/ceplfapp (226), epc = 0x2e25c4f8, ra = 0x2e25dde8, time = N/A, millis = 30094, SW version = Q5551-0.140.48.0 Release
              00 <3> 000030129 DEBUG DUMP 000000: Exception: address not mapped to object, process = /philips/apps/ceplfapp (226), epc = 0x2e25c4f8, ra = 0x2e25dde8, time = N/A, millis = 30094, SW version = Q5551-0.140.48.0 Release
              Flush prints
              00 <5>~000031570 **************** bootmode == 11 *****************
              00 <5>~000031574 /proc/pnx8xxx/boot_allowed_mode opened
              Restarting system.
              • R_J
                • 9588
                Anything here of any help? https://monitor.net.ru/forum/threads/456325/page-2
                • debruina
                  • May 2020
                  • 29
                  • Nederland
                  Originally posted by R_J
                  Yeah i noticed that page. One person said the Standby μP is somehow locked in software and if you replace the standby controller you get this fault. Now i didn't change the controller but of course the software dump is from a different board (same model). It is possible that the Standby μP is rebooting the TV because it finds a mismatch with software keys or something.
                  I tried a software update. That didn't work with the bad NAND because of corrupted update software. However i tried updating the software with this new nand and that worked. However it is still rebooting.
                  • debruina
                    • May 2020
                    • 29
                    • Nederland
                    Update this thread because maybe one day it will help someone.
                    I found a compleet set of firmware images for this model. A NAND, NVM and the bootrom. I replaced them all because the person that made the dump said that NAND FLASH must be paired with IC 7F52 = 25P05 and IC 7F58 = 24C64, otherwise it gives different errors, ie mainly the TV restarts after a few seconds. But somehow I still have the same problem. Everything seems to work. It powers up, shows Philips logo, i can go into the home menu and then it reboots.
                    Error in uArt:
                    00 <5>~000032922 Get key
                    00 <5>~000032922 Number of Keys found 4
                    00 <5>~000032923 1. baglength 249
                    00 <5>~000032923 2. baglength 245
                    00 <5>~000032923 3. baglength 241
                    00 <5>~000032923 4. baglength 225
                    00 <5>~000032924 Get key
                    00 <5>~000032924 Number of Keys found 4
                    00 <2> 000033452 Exception in process 226: address not mapped to object
                    00 <2> 000033452 EPC = 0x2e25c4f8
                    00 <2> 000033453 RA = 0x2e25dde8
                    00 <2> 000033453 BADVA = 0x12345678
                    SYSLOG: DEBUG DUMP 000017: Exception: address not mapped to object, process = /philips/apps/ceplfapp (226), epc = 0x2e25c4f8, ra = 0x2e25dde8, time = N/A, millis = 33451, SW version = Q5551-0.140.48.0 Release
                    00 <3> 000033508 DEBUG DUMP 000017: Exception: address not mapped to object, process = /philips/apps/ceplfapp (226), epc = 0x2e25c4f8, ra = 0x2e25dde8, time = N/A, millis = 33451, SW version = Q5551-0.140.48.0 Release
                    Flush prints
                    00 <5>~000034960 **************** bootmode == 11 *****************
                    00 <5>~000034964 /proc/pnx8xxx/boot_allowed_mode opened
                    Restarting system.
                    So i guess maybe the board is somehome paired with the software or still something else is bad. If i go into the CSM menu it dumps a config file on USB i noticed it doesn't have a ID or number behind the 200Hz board. Could be normal but this model has a 200Hz board.
                    1.1 Set type :46PFL8605H/12
                    1.2 Production code :VN1D1030004379
                    1.3 Installed date :06/10/2017
                    1.4a Options 1 :04100 13341 12479 08383
                    1.4b Options 2 :43782 34311 00030 00000
                    1.5 12NC SSB :310432864982
                    1.6 12NC display :932227888682
                    1.7 12NC supply :272217190198
                    1.8 12NC 200 Hz board :
                    1.9 12NC AV PIP :
                    2.1 Current main software :Q5551_0.140.48.0
                    2.2 Standby software :STDBY_75.63.0.0
                    2.3 e-UM version :310432700355
                    2.6 AV PIP software :
                    2.7 3D dongle software :
                    3.1 Signal quality :Bad
                    3.4 Ethernet MAC address :00:00:00:00:00:00
                    3.5 Wireless MAC address :00:00:00:00:00:00
                    3.6 BDS key :Not present
                    3.7 CI module :No
                    3.8 CI+ protected service :No
                    3.10 Event counter :S:011b 011b H:0001 0008
                    If you want this firmwareset send me message.
                    • Modelvincent
                      • Jun 2015
                      • 10
                      • France
                      I have a problem with my 46FPL8605H/12 tv. It's working for a while (sometime for up to 1hr) and suddenly, it restarts.
                      I have checked the serial debug and I have the following log during the failure:
                      Code:
                      00 <5~003368846 Temperature=34
                      00 <5 003371547 osnfr_mmemuse:[0337] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.90%
                      00 <5 003381564 osnfr_mmemuse:[0338] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.50%
                      00 <5 003391585 osnfr_mmemuse:[0339] freeMem:  221520, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.60%
                      00 <5 003401595 osnfr_mmemuse:[0340] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.30%
                      00 <5 003411615 osnfr_mmemuse:[0341] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.70%
                      00 <5 003421635 osnfr_mmemuse:[0342] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.60%
                      00 <5~003428858 Temperature=34
                      00 <5 003431655 osnfr_mmemuse:[0343] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.71%
                      00 <5 003441658 osnfr_mmemuse:[0344] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.60%
                      00 <5 003451674 osnfr_mmemuse:[0345] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.80%
                      00 <5 003461685 osnfr_mmemuse:[0346] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.50%
                      00 <5 003471706 osnfr_mmemuse:[0347] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.80%
                      00 <5 003481724 osnfr_mmemuse:[0348] freeMem:  221524, pgMajFault: 00000000, sectorsRead: 00041864 idle 97.80%
                      [b]00 <2 003484865 Exception in process 226: address not mapped to object
                      00 <2 003484866   EPC  = 0x10000000
                      00 <2 003484866   RA  = 0x2d656928
                      00 <2 003484866   BADVA = 0x12345678
                      SYSLOG: DEBUG DUMP 000001: Exception: address not mapped to object, process = /philips/apps/ceplfapp (226), epc = 0x10000000, ra = 0x2d656928, time = N/A, millis = 3484865, SW version = Q5551-0.140.48.0 Release
        00 <3 003484920 DEBUG DUMP 000001: Exception: address not mapped to object, process = /philips/apps/ceplfapp (226), epc = 0x10000000, ra = 0x2d656928, time = N/A, millis = 3484865, SW version = Q5551-0.140.48.0 Release
                      Flush prints
                            00 <5~003486493 **************** bootmode == 11 *****************
                      00 <5~003486495 /proc/pnx8xxx/boot_allowed_mode opened
                      Restarting system.
                      It looks like you have already corrected this failure by reflashing NAND, can you send me the differents files?
                      What is the procedure to update flash?
                      Thanks in advance
                      Vincent
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4464
                        • Italy - Milan
                        The main problem with these sets is a failing power mosfet on the tcon, then i guess, due to sudden overloads there are data loss in the flash, so maybe starting to not boot..
                        • Modelvincent
                          • Jun 2015
                          • 10
                          • France
                          Interesting, this can be repaired or it's better to directly change the TCON?
                          Another thing, I've retrieved the CSM log, and i'm suprised with the date, the "installed date" is 01 01 96 and all logs are dated from same date (and obviously the TV has been buyed far later than 1996...)
                          Code:
                          *---------------------------------Error Codes---------------------------------------------*
                          No Errors
                          *---------------------------------Operation Counter---------------------------------------*
                          Number of hours = 15842
                          *---------------------------------Software logs----------------------------------*
                          Total Event = 10
                          No. of Reboots = 10
                          Last Log Clear Date = 960101-00:29:48
                          Last Service = 960101-00:00:00
                          No.		R		Org		OpTime		ActCtx		NrKeys		LstKey		LstSrc		TimeDate		Rsn		EC
                          1		R		exc		00d97		0000		0000		eeee		ee		960101-01:00:58		10000000		0b
                          2		R		rbt		00000		0000		0000		eeee		ee		960101-00:00:00		00000000		0b
                          3		R		rbt		00000		0000		0000		eeee		ee		960101-00:00:00		00000000		0b
                          4		R		trm		00046		0000		0000		eeee		ee		960101-00:00:26		eeeeeeee		02
                          5		R		rbt		00000		0000		0000		eeee		ee		960101-00:00:00		00000000		0b
                          6		R		rbt		00000		0000		0000		eeee		ee		960101-00:00:00		00000000		0b
                          7		R		exc		01a96		0000		0000		eeee		ee		960101-03:03:49		2f69c064		0b
                          8		R		rbt		00000		0000		0000		eeee		ee		960101-00:00:00		00000000		0b
                          9		R		alv		00000		0000		0000		eeee		ee		960101-00:00:00		00000000		00
                          10		R		wdg		00540		0000		0000		eeee		ee		960101-00:51:52		2ab8ad50		05
                          *---------------------------------HardWare logs----------------------------------*
                          Total Event = 5
                          Last Log cleared time = 100908-13:57:49
                          No.		EC		OpTime		NrKeys		LstKey		LstSrc		TimeDate
                          1		026		03100		6564		6166		75		960101-00:00:00
                          2		026		03100		6564		6166		75		960101-00:00:00
                          3		010		00004		0000		eeee		ee		960129-06:00:09
                          4		026		03100		6564		6166		75		960101-00:00:00
                          5		026		03100		6564		6166		75		960101-00:00:00
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4464
                            • Italy - Milan
                            Now i'm on tablet, when i will be on PC i will post the picture to localize the mosfet and the replacement part number compatible , so wait this afternoon..
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4464
                              • Italy - Milan
                              the mos is labeled FDS8880 and i have swapped to a IRF8734PBF
                              • Modelvincent
                                • Jun 2015
                                • 10
                                • France
                                Thanks, I've just remove the cover and yes this is the same board with same transistor reference so I will replace it, it's not the price...
                                However, if the transitor was blown, I suppose that the problem will be present every time, not some time to time as actually?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4464
                                  • Italy - Milan
                                  No, i was giving you a sure repair testimonial, i'm not play around.. ok?
                                  • Modelvincent
                                    • Jun 2015
                                    • 10
                                    • France
                                    I'm really sorry, i didn't want to upset you.
                                    As the initial post was about a TV not starting at all i was not sure if your solution was for my specific problem.
                                    In all case, as mentionned above I will change the transistor and keep you informed of the result.
                                    And regarding the strange date in the log file, is there a problem hidden behind or is that a normal behaviour?
                                    Best regards
                                    Vincent
                                    • Modelvincent
                                      • Jun 2015
                                      • 10
                                      • France
                                      I've changed the mos as suggested by Davi.p but it changed absolutely nothing, the result is still the same, the TV restart from time to time...
                                      What can I check to debug this behaviour?
                                      Best regards
                                      Vincent
                                      • tranquility
                                        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                        by tranquility
                                        i want to repair an Onkyo TX-NR809 receiver.
                                        symptoms:
                                        on power on, display appears and i hear one click. enue functions is given.
                                        - no hdmi output
                                        - audio output not tested, but i think it is not there
                                        - usb sticks are not recognized
                                        if i read out the chips with display+standby button + tone+
                                        both dts show only ????
                                        chip is D830K013BZKB4
                                        things i have done:
                                        - reflow of the dts chip without taking off and reballing
                                        - changed the aluminium caps without the big one with 25v because i dont...
                                        08-25-2025, 01:04 AM
                                      • dragometin
                                        Hitachi 40HYC42
                                        by dragometin
                                        TV Model: Hitachi 40HYC42
                                        Power Supply: 17IPS71
                                        MainBoard: 17MB95M
                                        Panel: VES400UNDS-2D-NO3
                                        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                        Is there any variants on 17IPS71 power supply's?
                                        UART output pins 10 and 12 on scart connector:
                                        Code:
                                        12:24:04.595
                                        08-08-2024, 05:53 AM
                                      • Formaster
                                        nand bad block with an RT809H, didn't boot
                                        by Formaster
                                        Hello guys
                                        I did a dump from a MX30LF4G28AD@TSOP48 nand with an RT809H. If I flash back the firmware, the auto verify show everithing ok, but if click on Verify button there is a lot of inconsistence bytes.
                                        I did a bad block check and found it few. However I use any bad block management algorithm, after flashing the verify show the same inconsistences.
                                        The device didn't boot up. What I did wrong? Thank's in advance!...
                                        11-08-2022, 06:33 AM
                                      • mattpd
                                        PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                                        by mattpd
                                        PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                                        No LM damage. UART gives a generic "APU not responding" error.
                                        Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                                        I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                                        So to those with experience, would you expect at least a little heat from the NAND during...
                                        09-02-2025, 09:42 AM
                                      • ahmedtou
                                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                        by ahmedtou
                                        help me please
                                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                        I will share all the details with you, including the disc information.
                                        Code:
                                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                        Current Profile: BD-R
                                        Disc Information:
                                        Status: Empty
                                        State of Last Session: Empty
                                        Erasable: No
                                        Free Sectors: 12,219,392
                                        Free Space: 25,025,314,816 bytes
                                        Free Time: 2715:27:17 (MM:SS:FF)
                                        Next
                                        08-27-2025, 08:49 AM
