PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
  • mattpd
    • Oct 2012
    • 302
    PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
    No LM damage. UART gives a generic "APU not responding" error.
    Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
    I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
    So to those with experience, would you expect at least a little heat from the NAND during the boot sequence? And if yes, is a bad controller the likely cause considering NAND voltage is present?
  • ugamazing
    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
    by ugamazing
    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
    08-31-2022, 07:34 AM
  • speggio91
    820-00165 pulsing and stuck at S5
    by speggio91
    Hello everyone!
    I have this board that got slightly water damanged and it is stuck at S5 state. It pulses once every 5 seconds.
    When connected the magsafe 2 to the bench psu, the current goes from 0.02A to 0.10A when is pulsing.
    When using the genuine magsafe 2 charger, the light turn on and it became green and then amber. The fan is not spinning.
    When I tried the SMC bypass mode, the fan spins a quarter every 5 seconds and the pulsing is still present every time the fan spin.
    The pulses are present in the CPU Vcore rails on L7320 and L7310....
    11-25-2023, 11:25 AM
  • feherhollo
    WSON8 NEW Bios Chips READ, ERROR, ETC.
    by feherhollo
    I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
    I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
    For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
    11-26-2023, 09:33 AM
  • ducky29
    RT809H reading nand chips
    by ducky29
    Hello. Im trying to read a nand chip H27U1G8F2BTR@TSOP48 but im unable to do so. Im getting the following error
    Code:
    001: Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
    002: The currently selected:H27U1G8F2BTR@TSOP48, capacity: 1024Mbits, 128Mbytes.
    003: Adapter model£ºRT-TSOP48-1, 0.5, 12*18, Pin to Pin
    004: http://www.ifix.net.cn/thread-53859-1-2.html
    005: Download device programming algorithm......
    006: Algo update OK
    007: >------------------------------------OK---------------------------------------<
    03-01-2021, 01:46 PM
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
