Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
  • tranquility
    • Dec 2024
    • 32
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont have a spare part here
    measured some voltages:
    die 1,1V - 1,8V - 3,3V and 5,2V are available
    usb port is dead
    the usb power chip gets the 5.2V but no voltage on the enable pin
    i connected via serial to the hdmi board and get the following.
    las message is starting kernel and then nothing happens.
    maybe there is a nand problem ? oder its the dts chip or both ?
    or is there another problem which stops the booting process
    U-Boot 1.3.3-svn (Nov 29 2010 - 18:05:03)
    DRAM: 64 MB
    NAND: NAND Manufacturer id: 20
    NAND Device id: 75
    NAND device: Manufacturer ID: 0x20, Chip ID: 0x75 (ST Micro NAND 32MiB 3,3V 8-bit)
    Bad block table found at page 65504, version 0x01
    Bad block table found at page 65472, version 0x01
    nand_read_bbt: Bad block at 0x00000000
    nand_read_bbt: Bad block at 0x00018000
    [......this meassages come a lot]
    nand_read_bbt: Bad block at 0x006bc000
    nand_read_bbt: Bad block at 0x006d0000
    32 MiB
    In: serial
    Out: serial
    Err: serial
    ARM Clock : 400000000 Hz
    Hit any key to stop autoboot: 1 08 08 08 0
    Loading from NAND 32MiB 3,3V 8-bit, offset 0x254000
    Image Name: Linux-2.6.33-rc4
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 1034560 Bytes = 1010.3 kB
    Load Address: c0008000
    Entry Point: c0008000
    Automatic boot of image at addr 0xc0200000 ...
    ## Booting kernel from Legacy Image at c0200000 ...
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
  • MotherTeresa
    Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
    by MotherTeresa
    Hi.
    I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
    Regards.
    09-20-2025, 12:09 PM
  • Formaster
    nand bad block with an RT809H, didn't boot
    by Formaster
    Hello guys
    I did a dump from a MX30LF4G28AD@TSOP48 nand with an RT809H. If I flash back the firmware, the auto verify show everithing ok, but if click on Verify button there is a lot of inconsistence bytes.
    I did a bad block check and found it few. However I use any bad block management algorithm, after flashing the verify show the same inconsistences.
    The device didn't boot up. What I did wrong? Thank's in advance!...
    11-08-2022, 06:33 AM
  • mattpd
    PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
    by mattpd
    PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
    No LM damage. UART gives a generic "APU not responding" error.
    Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
    I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
    So to those with experience, would you expect at least a little heat from the NAND during...
    09-02-2025, 09:42 AM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
  • sohail5307
    Need a2159 128gb nand bin file
    by sohail5307
    I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
    Two nand are using :
    Tsb4226(128gb)
    Tsb4226(128gb)
    09-16-2023, 09:20 PM
