samsung qn55q7famxza blurry picture
  • nwelec
    • 61
    • usa
    Very blurry picture. Changed the one connect box and same problem. Tried disconnecting one side of the tcon but I guess that no longer shows half of the tv picture so I am kind of stuck. I would normally think the Tcon is the problem but other than ebay it is not in stock for a fair price, and on ebay it is $100.00. Hope anyone here can help.
    Re: samsung qn55q7famxza blurry picture
    https://www.badcaps.net/forum/attach...1&d=1577483494'
    Double-image is usually panel Gate drive issue.
    But at this point you no longer get anything on the screen?
    Did you verify that the ribbon cables are not damaged or verify that they are put back in place correctly?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4333
      • Italy - Milan
      I don't think it has gate drivers , i think it's a QLED panel and the tech behind that is not much known, we need better pictures 'cause is not photographed the main/av board and the board that resembles a tcon must be better caught in zoomed pict without the shield.
        The so called QLED TV is still using LCD panel topology and LED backlight.
        https://www.cnet.com/news/qled-vs-ol...20-comparison/
        Quantum dots are microscopic molecules that, when hit by light, emit their own, differently colored light. In QLED TVs, the dots are contained in a film, and the light that hits them is provided by an LED backlight. That light then travels though a few other layers inside the TV, including a liquid crystal (LCD) layer, to create the picture. The light from the LED source is transmitted through the layers to the screen's surface, which is why we say it's "transmissive."
        • nwcs
          • Dec 2015
          • 311
          • usa
          I get a blurry pic if the flat cables to the panel are connected. If I disconnect one side or the other then no picture at all. I will try and get a better pic of the Tcon next week but with all of my medical appts and the holidays it may not happen. I will try and see if there is any damage to the gate drivers on the panel but not sure when that will happen.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4333
            • Italy - Milan
            Why do you have a multiple account? I ask to the moderators or admin if it is possible...
            • noonyf
              • Jan 2014
              • 5
              • usa
              I need help with a 75" model like this one. with the one connect cable disconnected I see the "disconnect banner". when I connected the cable, the picture is distorted like a checker board. I ordered a new one connect cable and now i have no Image at all but the backlight changes as if video content were there. I have tried a different one connect box with the same results. Do I have a new defective one connect cable? thanks
              • nwcs
                • Dec 2015
                • 311
                • usa
                I would suspect the main board.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4333
                  • Italy - Milan
                  Is your fault the same as the OP? If not why not to open a new thread? This is the way to make jamming..
                    09-07-2024, 05:50 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • shelby5041
                    Samsung LCD TV no picture backlight on no 12v at tcon
                    by shelby5041
                    hi
                    i have a samsung lcd tv
                    it powers on with sound and backlight but no picture
                    all voltages from PS are good 12v 3.3v and 5v
                    whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                    i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                    no 12v at the tcon fuse
                    i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                    the odds of having 2...
                    10-08-2021, 08:21 AM
                  • Dodgethis
                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                    by Dodgethis
                    Hello all,
                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                    09-11-2024, 07:39 AM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
