Why do TVs have ceramic heatsinks?
  • KvnTM
    • May 2018
    • 434
    Hi!
    I was always wondering why TV manufacturers use ceramic heatsinks on many boards. Even mixed ones where one chip has a white ceramic heatsink and another chip a black aluminium heatsink.
    Is there some magic voodoo going on? I know that usually black anodized heatsinks can dissipate more heat. Why do they use white ceramic ??
    Would be highly appreciated if someone could explain this sorcery..
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8320
    Re: Why do TVs have ceramic heatsinks?
    one is conductive, while the other one is not?
    • steviewonder
      • Dec 2013
      • 183
      • england
      Philips is fond of this idea,and the ceramic ones tend to fall off too.
      • KvnTM
        • May 2018
        • 434
        Does ceramic have a higher thermal conductivity than aluminium ?
        What would be the benefit from this? Heatsinks usually don't touch any live circuits.
        Yes and it was probably one of their worst ideas. The contact surface isn't flat and they are way too small. The chip under it cooks itself. Same when it falls off of course. I can imagine that using thermal adhesive on a non flat surface would result in far worse chip temps compared to aluminium with proper thermal grease.
        I smell planned obsolescence...
        • Unspun01
          • Jun 2011
          • 349
          Ceramic heat sinks can be "cast" in any shape and size similar to extruding aluminum so they are easy to manufacture and very versatile.
          The space shuttle used ceramic heat spreading and heat dissipating materials on the bottom and nose of the shuttle upon re-entry to earth atmosphere. They could be red hot from a few thousand degrees, and then moments later they could be cool to the touch by human hand. Amazing tech. Certainly not installed in your TV, but illustrates how good porous ceramics can be at dissipating heat.
          If you notice the ceramic heat sinks in your TV are also porous and helps to dissipate heat quite well.
          The problem tends to be the poor adhesives and thermal paste they use to hold them in place and therefore they sometimes they fall off the chips.
          I don't think there is anything wrong with a ceramic heatsink per-se. In fact - you would think that a porous ceramic would stay in place better than a smooth anodized finish.
          Probably the manufacturer found a way to save a few dollars and a ceramic heat sink works pretty good. They accept heat quite fast and get rid of it quite fast. Specifically they are porous which helps the heat transfer. These are not the same as a hot ceramic dish that you pull from a hot hoven that stays hot for half an hour. They are quite good at getting rid of heat through passive means (ie - no fan).
          • Ven
            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
            by Ven
            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
            07-08-2024, 09:32 AM
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • harp
            can fanless heatsink replace poor original on RX26PG2
            by harp
            I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
            06-25-2025, 10:56 AM
          • harp
            Metod for removing glued heatsink from fragile component
            by harp
            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
            06-23-2025, 02:01 PM
            Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
            by momaka
            This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
            Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
            Macron Power Technology Co. LTD.
            Let’s look at the PSU itself.
            The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
            06-02-2021, 10:05 PM
