Another LG, Another TCON Issue.. 55LN5100
  • Michale32086
    • Nov 2011
    • 1453
    This one is not so bad as yesterdays..
    Just got in a 55" LG this morning.. Powers up, backlight, no display..
    Swapped out a few Main Video Boards.. Same issue..
    TCON it is... No shorts or blown fuses this time..
    I found a similar TCON in my parts jungle.. Literally.. A jungle..
    Taaa Daaaaa.. It works!!
    But the display is upside down.. I have run into many upside down displays, but it's usually the Main Video Board that's the issue.. Swapping out FIRMWARE chips usually takes care of that..
    But I think I need to go thru the Service Menu to fix this..
    Anyone know how to access the Service Menu on the LG LN series??
    I have tried TV MENU/REMOTE MENU and TV OK/REMOTE OK... No luck...
    Any help... Most appreciated..
  • handsworth
    • Oct 2015
    • 174
    Re: Another LG, Another TCON Issue.. 55LN5100
    I have a LG service remote that accesses the service menu. Costs $40, but paid for itself many times over. I also have many LG tcons available. Which correct one do you need. 6871L-xxxx
    • Michale32086
      • Nov 2011
      • 1453
      I actually found another in my parts jungle.. Works fine.. Thanx for the reply... So, yer saying it's a special remote that is needed??
      Thanx again...
      • handsworth
        • Oct 2015
        • 174
        Yes, I do a ton of LG tvs so this was a great tool. Its called LG Factory SVC Remocon Model# MKJ39170828. Saw a few on Ebay $10.
        • Michale32086
          • Nov 2011
          • 1453
          Awesome!! I'll check into that.. Yea... The LG infamous LED issue?? Almost single-handedly Keeps me in business....
          Thanx again..
          • neilc6
            • Nov 2015
            • 1550
            There is also an app if your smartphone has an IR blaster. I have a LG service remote I bought off ebay. To do a factory reset on LN series, Instop and 0413. Instart gets into service menu.
            • Michale32086
              • Nov 2011
              • 1453
              Looks like I might have to avail myself of that...
              The TCON board I put in crapped out after about an hour.. Now I am back to a backlight but no display..
              I am going to put the upside down TCON in it tomorrow morning and let it run for a couple of hours.. Hopefully it's not something else frying TCON boards..
              If it lasts the burn in, I'll try the factory reset...
              Thanx again to all who replied..
              Seems like TCON boards are my nemesis this week...
              • neilc6
                • Nov 2015
                • 1550
                Panel faults can fry tcon boards. I would look for liquid damage on the edge boards.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  Since you've eliminated the signal processor board, this is moot....but a bunch of LG's I've seen needed their processor chips reflowed.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                    Did the T-CON fuse also blown?
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      wondering if say power supply was high voltage it may blow the tcon ?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        if you need to flip the image maybe this lg service remote apk will work it is very easy, just audio or IR with android
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Nope.. At least, not on the first one...
                          I haven't had a chance to check the replacement, but I have a feeling that the fuse will be good on this one as well.
                          Should know more in a few hours when I get to my shop..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            That's awesome, dood!!! Thanx a bunch.. VERY much appreciated..
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Yea, I know what you mean... I have had quite a few LGs where the boot-up process would freeze at the logo... I am assuming that's a processor chip issue as you describe..
                              A reflow usually fixes those right up..
                              That's one of the nice things about LGs.. They break easy but they are, by and large, easy to repair, once ya identify the problem.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Turns out that THIS TCON had the fuse blown.. Put the upside down TCON in it and gonna let it play for a few...
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  I just looked at my phone and I remembered I bought the SMART IR App a bit ago....
                                  How would I incorporate this LG APK into the existing app??
                                  EDIT:
                                  Never mind.. It came up.... I push IN-START and it prompts for a password.. Grrrr.. Nothing is ever easy
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Passwords 0000 and 1234 and 1111 do not work...
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      EDIT:
                                      i have not got a android device here at the minute too test the apk are you using your version you brought? or the the i uploaded? user on this fourm DIAH first uploaded this file a while ago no one has said it needed a password maybe send diah a pm and see if he knows the password if its needed try 04103
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        OK I'll install the APK and see what happens.
                                        Thanx again..
                                        • cagri
                                          BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                                          by cagri
                                          I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                                          PMIC: iML8940
                                          There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                                          Input 12v, fuse ok
                                          DVDD1V2 = 1.2v
                                          DVDD1V8 = 1.8v
                                          DVDD3V3 = 3.3v
                                          VGL = -7v
                                          **VGH = -0.3v
                                          **VCOM0, AVDD, HAVDD = 0v
                                          SWBK1 = 3.3v
                                          SW1 = 12v
                                          VGH to GND resistance is 500kohm as expected
                                          Readings are same after I disconnected the two cables from TCON to panel...
                                          07-27-2023, 09:48 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • jdawg99
                                          Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
                                          by jdawg99
                                          Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
                                          Any advice welcome. Thanks in advance....
                                          09-18-2022, 05:30 AM
                                        • angelos
                                          TCON and self diagnosis!
                                          by angelos
                                          Hi Guys.
                                          I have experienced something rather unique and need to find out by the forum what to make of it.
                                          I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal...
                                          09-19-2022, 03:05 AM
                                        • pc1staid
                                          Dell Latitude E7270 shut down issue
                                          by pc1staid
                                          Hi Guys and Gals,
                                          I have a really strange issue with the above titled Ultrabook.
                                          Quick spec's, i7-6600 with intel HD520 graphics, 8GB DDR-4 RAM, 256GB M.2 SSD, 12" screen, Wifi, Finger print, NFC.
                                          Use of the laptop is out on sites, remoted into a NAS just for files, software installed Win10, Office 2019, Teams, Printer software. Thats it, sledge hammer to crack a walnut.
                                          OK, the issue. 4 days prior to me getting it, just after login, approx 15 secs the laptop will shutdown. Not as in power off/cut, no restart, it goes through the shut down procedure. This is...
                                          12-19-2020, 01:17 AM
