Another LG, Another TCON Issue.. 55LN5100
  • Michale32086
    • Nov 2011
    • 1453
    This one is not so bad as yesterdays..
    Just got in a 55" LG this morning.. Powers up, backlight, no display..
    Swapped out a few Main Video Boards.. Same issue..
    TCON it is... No shorts or blown fuses this time..
    I found a similar TCON in my parts jungle.. Literally.. A jungle..
    Taaa Daaaaa.. It works!!
    But the display is upside down.. I have run into many upside down displays, but it's usually the Main Video Board that's the issue.. Swapping out FIRMWARE chips usually takes care of that..
    But I think I need to go thru the Service Menu to fix this..
    Anyone know how to access the Service Menu on the LG LN series??
    I have tried TV MENU/REMOTE MENU and TV OK/REMOTE OK... No luck...
    Any help... Most appreciated..
  • handsworth
    • Oct 2015
    • 174
    Re: Another LG, Another TCON Issue.. 55LN5100
    I have a LG service remote that accesses the service menu. Costs $40, but paid for itself many times over. I also have many LG tcons available. Which correct one do you need. 6871L-xxxx
    • Michale32086
      • Nov 2011
      • 1453
      I actually found another in my parts jungle.. Works fine.. Thanx for the reply... So, yer saying it's a special remote that is needed??
      Thanx again...
      • handsworth
        • Oct 2015
        • 174
        Yes, I do a ton of LG tvs so this was a great tool. Its called LG Factory SVC Remocon Model# MKJ39170828. Saw a few on Ebay $10.
        • Michale32086
          • Nov 2011
          • 1453
          Awesome!! I'll check into that.. Yea... The LG infamous LED issue?? Almost single-handedly Keeps me in business....
          Thanx again..
          • neilc6
            • Nov 2015
            • 1550
            There is also an app if your smartphone has an IR blaster. I have a LG service remote I bought off ebay. To do a factory reset on LN series, Instop and 0413. Instart gets into service menu.
            • Michale32086
              • Nov 2011
              • 1453
              Looks like I might have to avail myself of that...
              The TCON board I put in crapped out after about an hour.. Now I am back to a backlight but no display..
              I am going to put the upside down TCON in it tomorrow morning and let it run for a couple of hours.. Hopefully it's not something else frying TCON boards..
              If it lasts the burn in, I'll try the factory reset...
              Thanx again to all who replied..
              Seems like TCON boards are my nemesis this week...
              • neilc6
                • Nov 2015
                • 1550
                Panel faults can fry tcon boards. I would look for liquid damage on the edge boards.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  Since you've eliminated the signal processor board, this is moot....but a bunch of LG's I've seen needed their processor chips reflowed.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                    Did the T-CON fuse also blown?
                    • petehall347
                      • Jan 2015
                      • 4426
                      wondering if say power supply was high voltage it may blow the tcon ?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        if you need to flip the image maybe this lg service remote apk will work it is very easy, just audio or IR with android
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Nope.. At least, not on the first one...
                          I haven't had a chance to check the replacement, but I have a feeling that the fuse will be good on this one as well.
                          Should know more in a few hours when I get to my shop..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            That's awesome, dood!!! Thanx a bunch.. VERY much appreciated..
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Yea, I know what you mean... I have had quite a few LGs where the boot-up process would freeze at the logo... I am assuming that's a processor chip issue as you describe..
                              A reflow usually fixes those right up..
                              That's one of the nice things about LGs.. They break easy but they are, by and large, easy to repair, once ya identify the problem.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Turns out that THIS TCON had the fuse blown.. Put the upside down TCON in it and gonna let it play for a few...
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  I just looked at my phone and I remembered I bought the SMART IR App a bit ago....
                                  How would I incorporate this LG APK into the existing app??
                                  EDIT:
                                  Never mind.. It came up.... I push IN-START and it prompts for a password.. Grrrr.. Nothing is ever easy
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Passwords 0000 and 1234 and 1111 do not work...
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      EDIT:
                                      i have not got a android device here at the minute too test the apk are you using your version you brought? or the the i uploaded? user on this fourm DIAH first uploaded this file a while ago no one has said it needed a password maybe send diah a pm and see if he knows the password if its needed try 04103
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        OK I'll install the APK and see what happens.
                                        Thanx again..
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
                                        • cagri
                                          BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                                          by cagri
                                          I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                                          PMIC: iML8940
                                          There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                                          Input 12v, fuse ok
                                          DVDD1V2 = 1.2v
                                          DVDD1V8 = 1.8v
                                          DVDD3V3 = 3.3v
                                          VGL = -7v
                                          **VGH = -0.3v
                                          **VCOM0, AVDD, HAVDD = 0v
                                          SWBK1 = 3.3v
                                          SW1 = 12v
                                          VGH to GND resistance is 500kohm as expected
                                          Readings are same after I disconnected the two cables from TCON to panel...
                                          07-27-2023, 09:48 PM
                                        • EazyBone
                                          Vizio P759-G1, Tcon issue?
                                          by EazyBone
                                          Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                                          Any help appreciated
                                          https://youtu.be/tPeV2Q7TXIQ?feature=shared
                                          03-22-2024, 03:25 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
