BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
  • cagri
    • Jul 2023
    • 4
    • Turkey
    I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
    PMIC: iML8940
    There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
    Input 12v, fuse ok
    DVDD1V2 = 1.2v
    DVDD1V8 = 1.8v
    DVDD3V3 = 3.3v
    VGL = -7v
    **VGH = -0.3v
    **VCOM0, AVDD, HAVDD = 0v
    SWBK1 = 3.3v
    SW1 = 12v
    VGH to GND resistance is 500kohm as expected
    Readings are same after I disconnected the two cables from TCON to panel
    As far as I could, and quickly check,
    No capacitors are shorted, only one capacitor has no short side to GND (capacitance reading is fine though)
    Inductors' resistances seem okay
    Diodes seem okay
    Resistors seem okay
    VGH etc. points each are short to at least one of PMIC pins, and VGL is correct so I don't think it's a faulty PCB connection from PMIC.
    LD1117AG-AD regulator gnd iirc -0.6v, vin 3.3v, vout 1.8v, R1 (was in datasheet example) is 280ohm, R2 is 137ohm. vout matches the expectation
    I couldn't see any shorts or faulty components, except maybe PMIC is faulty. I'm not very experienced in electronics and I wasn't able to find much details for that PMIC unfortunately.
    But, VGL voltage is correct and thermal image shows PMIC has some heat. as I'm unsure how it works, I'm thinking maybe a resistor or capacitor for PMIC input values is faulty. I checked a lot of times (while they were still soldered, except diodes) and it seems to be fine.
    I'm attaching TCON datasheet, some pictures of it, and thermal images.
    In thermal image you can see processor is "hot", regulator is "hot", the bottom inductor is a bit hot. PMIC and inductor in middle is just a bit hot. So I'm thinking the issue is around the inductor/PMIC area as I expected more heat there.
    (note that "hot" = 40 C)
    Is there anything else I can troubleshoot or try? I wanted to check the transistors but my multimeter doesn't have transistor mode and I'm unsure what should the values be so I couldn't.
    I've wasted so much time on this, it's not about the TV anymore, it's gotten personal lol
    I apologize if I forgot or mistyped anything since I've been working on this for 12 straight hours, and thanks so much in advance
    • 12206
    • U.S.
    Re: BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
    "only one capacitor has no short side to GND" If you are sure that one is a capacitor then I think this is part of the problem, can not recall a cap not having connection to ground and the board be functional. What do you get on the ohm scale for that cap? also test it in ohm with meter lead on both ends of cap, also look the cap over very closely some times you will see a hairline crack on bad ones but a cap not reading correctly can point to a problem other than that cap.
    • cagri
      • Jul 2023
      • 4
      • Turkey
      hi, thanks for your reply
      i desoldered it and it reads 516 nF
      on the board from ground to one end it's 1m-ish, other end 0.8m-ish, capacitor resistance reading changes between 2m ohm to 300kohm
      I've also noticed there are a bunch of tiny similar capacitors near the processor and they don't have a short to GND as well, there's a few hundred kohms resistance to GND.
      • cagri
        • Jul 2023
        • 4
        • Turkey
        hey guys, I fixed it by baking tcon card in the oven! it works now! I've ordered a replacement tcon since i don't think it'll work for too long.
          • 12206
          • U.S.
          Good work, yes the oven reflows usually don't last very long.
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • thelankanguy
            Sony KD-55X9000F TCON Issue
            by thelankanguy
            The TV shows a black screen with no image.
            TCON ribbon connectors were disconnected individually for image and there was no half image even.
            Later both ribbons were disconnected and TCON voltages were tested.
            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
            There is also a short to ground in this circled inductor.
            Is this a TCON issue or something else ?...
            12-13-2024, 12:27 AM
          • EazyBone
            Vizio P759-G1, Tcon issue?
            by EazyBone
            Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
            Any help appreciated
            https://youtu.be/tPeV2Q7TXIQ?feature=shared
            03-22-2024, 03:25 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
