Vizio M370NV Powers on for 2 seconds then shuts down
    • 12214
    • U.S.
    #81
    Re: Vizio M370NV Powers on for 2 seconds then shuts down
    One there for 34, from reading description they said it may have lines on the screen. I don't think I see any, who knows, they may have had a tcon or panel probem or could be the mainboard is faulty: https://www.ebay.com/itm/VIZIO-M370N...QAAOSwSflbl~VD
    • MisterD
      • Oct 2012
      • 668
      Eeprom n mainboard there, the mainboard does have a make offer option, 45 seems a little high, took a quick look at a few other places and they want even more: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
      I ordered the eeprom, will replace that in the non tested board I got from ebay as soon as I get it in the mail.
      • MisterD
        • Oct 2012
        • 668
        EEprom did not fix it. I am wondering if I should use it on the original board in case that one is corrupted..any thoughts?
        • MisterD
          • Oct 2012
          • 668
          Originally posted by R_J
          Did you spray it with the tv unplugged? then plug it in. The eeprom data is read when it is first pluged in, spraying it after that will not work
          I bought a non working non tested board from ebay, I replaced the eeprom on it. that did not fix it..with this board the tv will not power on...I am thinking about..installing this new eeprom in the original main board that did turn the tv on with back lights but it would power back off in 2 to 3 seconds..what do you think?
          • MisterD
            • Oct 2012
            • 668
            If there was an issue with the backlights I would expect they would shut down even in this test mode.
            It does seem to point to the main board, being a vizio it could be the eeprom? You could try freezing the U53 eeprom ic. Either with cold spray or an inverted canned air.
            freeze the eeprom with the tv unplugged, wait a few seconds then plug it in and turn it on and see if it makes a difference.
            It could be corrupt data and when it hits that point it does'nt know what to do so it turns off
            I replaced the EEPROM on the original board and now the TV stays powered on and works as it should. so the EEPROM must have been corrupted as you said.
              Glad to hear and thanks for the follow-up on the repair.
              I am also glad you did not take the LCD panel apart and taking chance of damaging it.
              • MisterD
                • Oct 2012
                • 668
                This must not be the typical symptoms of a faulty EEPROM, but I am glad that replacing it fixed the TV as well as not having to take the LED Panel apart...Thanks Bud for all your help.
                • Diah
                  • Feb 2013
                  • 6419
                  my post https://www.badcaps.net/forum/showpo...0&postcount=78
                  good to hear you fix it.. but its so strange to buy replace MB and it was had same issue who will pay this coast !!! .. and you replaced eeprom on old one and it worked... you are quine.
                  • survivalbloke
                    Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                    by survivalbloke
                    I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                    Any ideas?
                    01-08-2024, 12:12 PM
                  • chaos-theory
                    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                    by chaos-theory
                    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                    03-14-2025, 05:37 PM
                  • APOPAP
                    Panasonic National NV-M3 VHS Camera shuts down after some seconds
                    by APOPAP
                    Hello everybody,
                    First post here. I have been reading posts here for some time now, but today I made my first account and post.
                    The same question is also posted on another site, here it is:
                    Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                    I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                    08-25-2025, 10:12 AM
                  • tec3000
                    Sony LED 65X9005A shuts down after few seconds - looking for help
                    by tec3000
                    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                    03-20-2024, 07:29 AM
                  • lowpost99@gmail.com
                    Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                    by lowpost99@gmail.com
                    I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                    09-03-2024, 02:57 PM
