Dell laptop powers up with kb backlight about 10 seconds, then shuts off
  • survivalbloke
    • Aug 2021
    • 307
    I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
    Any ideas?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    112 mA in off condition? Thats not right? Check voltage on all coils as well as resistance to GND. Is there any difference in voltage on coils before/after power button press? Share mb marking code
    • lowpost99@gmail.com
      Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
      by lowpost99@gmail.com
      I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
      09-03-2024, 02:57 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • chaos-theory
      Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
      by chaos-theory
      I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
      Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
      03-14-2025, 05:37 PM
    • samuelphirik
      Dell inspiron 15 7567 sudden shuts down
      by samuelphirik
      Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
      During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
      I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
      Now I've noticed that laptop...
      07-02-2023, 05:45 AM
    • APOPAP
      Panasonic National NV-M3 VHS Camera shuts down after some seconds
      by APOPAP
      Hello everybody,
      First post here. I have been reading posts here for some time now, but today I made my first account and post.
      The same question is also posted on another site, here it is:
      Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
      I tried connecting it to a Computer PSU (12.7v) but I get battery error...
      08-25-2025, 10:12 AM
