Vizio M370NV Powers on for 2 seconds then shuts down
  • R_J
    • Jun 2012
    • 9625
    Re: Vizio M370NV Powers on for 2 seconds then shuts down
    If there was an issue with the backlights I would expect they would shut down even in this test mode.
    It does seem to point to the main board, being a vizio it could be the eeprom? You could try freezing the U53 eeprom ic. Either with cold spray or an inverted canned air.
    freeze the eeprom with the tv unplugged, wait a few seconds then plug it in and turn it on and see if it makes a difference.
    It could be corrupt data and when it hits that point it does'nt know what to do so it turns off
    • MisterD
      • Oct 2012
      • 668
      I sprayed the eeprom U53 with cold spray, waited a few seconds but still had the same problem. the TV Powers on with backlights,has the on screen vizio logo for 2 seconds, then blank white screen for 1 more second, then tv turns itself off
      • R_J
        • Jun 2012
        • 9625
        Did you spray it with the tv unplugged? then plug it in. The eeprom data is read when it is first pluged in, spraying it after that will not work
        • MisterD
          • Oct 2012
          • 668
          I can order and replace the eeprom to see if that fixes it, I think it was $15 from shopjimmy not sure what the shipping would be..or order a replacement Main Bd. shopjimmy price $39 and $10 shipping...other than either one of these do you have any further suggestions or tests I can do to point me in the right direction. please reply back. I am signing off and going to bed now. will check back tomorrow to see what you or anyone else says...Thanks again for all your help.
          • MisterD
            • Oct 2012
            • 668
            Yes I had the TV unplugged at the time I sprayed the eeprom, then plugged it in after that before turning on the tv. I can try it again.
            • MisterD
              • Oct 2012
              • 668
              I just tried it again with it unplugged and it didn't change anything.
              • MisterD
                • Oct 2012
                • 668
                At this point do I order an eeprom or main board??I don't really want to spend $50-$65 on this TV.
                • Diah
                  • Feb 2013
                  • 6614
                  Man, resistor test for BL doesn't mean your backlight okay if you see lighting on. take the screen apart and inspect visually you will find the issue.
                  • MisterD
                    • Oct 2012
                    • 668
                    I have been thinking about doing that, I see the ribbon cables to the panel are at the bottom on this TV, I'm wondering if I could just take out the front bezel mounting screws and swing the panel forward enough to inspect the led's......I did unplug both ribbon cables to the LED'S and the TV still powers itself off. I'm not sure if the LED's must be connected to keep the TV powered on. ANYONE ?
                    • Diah
                      • Feb 2013
                      • 6614
                      most Tvs with out BL socket connected will turn off . same way if LED issue set goes to protecting mode.
                      take panel aside will not help .. need to remove it out and all defusser plate.. keep in mind to notice their order.
                      • MisterD
                        • Oct 2012
                        • 668
                        I did this on a 55" Vizio for my friend, we ended up replacing all the LED Strips, we marked all the defective LED bulbs and he saved the strips, if I have any that are open ( not lit ) I wonder if I can pull some from the other led strips he has and just change the bulbs as needed.
                          I had a 4 pack of 560 ohm resistors, I have connected them with small alligator clip leads and this did force on the power supply and backlights are on now...I did have backlights prior to this test but the tv would power itself back off in about 2 to 3 seconds...now that I have these resistors in place what would be the next step???? I tried to see if all led's are on but it's hard to tell from the back side, but it appears as if they are.
                          So the backlights come on and stay on as long as the TV is plugged into the AC outlet?
                          • MisterD
                            • Oct 2012
                            • 668
                            Info Below on next post
                            • MisterD
                              • Oct 2012
                              • 668
                              With the resistors hooked up, mainboard disconnected and the power supply and backlights forced on then yes the backlights will stay on then as long as the TV is plugged in.....but with mainboard plugged back in to normal, the TV will power on and shows the Vizio Logo on the screen (backlights are on too) but the TV will power itself back off within 2 or 3 seconds...the amber vizio logo is normal..amber when tv is off and white when tv is on.
                                Put everything back to normal, then monitor the BL-ON pin then turn on the TV while monitoring the BL-ON pin to see if it goes to >2V DC and then drops down to <1V in sync with the backlights behavior.
                                You also should report the Voltage of other pins of the power supply connector that goes to the main board as well.
                                • MisterD
                                  • Oct 2012
                                  • 668
                                  CN 202 connector at Power Supply to Main board.
                                  Pin 1 5.1 VSB reading Is 5.38 V TV on or off is the same
                                  Pin 2 5.1 VSB reading 5.38 V TV on or off is the same
                                  pin 3 5.1 VSB reading 5.38 V TV on or off is the same
                                  pin 4 SGND reading zero volts TV on or off is the same.
                                  Pin 5 SGND reading zero volts TV on or off is the same.
                                  pin 6 SGND reading zero volts TV on or off is the same.
                                  pin 7 SGND reading zero volts TV on or off is the same.
                                  Pin 8 12 V reading 12.04 when TV is on and zero v when off
                                  pin 9 12 V reading 12.04 when TV is on and zero v when off
                                  pin 10 12 v reading 12.04 when TV is on and zero v when off
                                  pin 11 Remote On_Off reading 3.28 V when tv is on and zero when off
                                  pin 12 BL On_Off reading is 3.28 V when tv powered on and backlights are on then drops to .75 V as soon as backlights are off ( when tv powers off by itself)
                                  Pin 13 NC
                                  Pin 14 Dim_Pwm_Signal reading 3.26V when tv is on and Zero when tv off
                                  • R_J
                                    • Jun 2012
                                    • 9625
                                    The mainboard is telling the power supply to do what it should, turn on and then turn on the backlights. Since there is no backlight error signal etc. from the power supply back to the main, the main has no idea if the backlight is on or off and really does'nt care.
                                    Thats why I suspect the main board, and it could be an eeprom issue or I suspect it is more likley a bga problem on the large chip.
                                    • Diah
                                      • Feb 2013
                                      • 6614
                                      for me look after the age of the TV.. did the LED survive .. and they are edge one.. not direct.. only visual check can help.. beside the set just 37 size no risk to break down panel.
                                      • MisterD
                                        • Oct 2012
                                        • 668
                                        I was thinking a bga problem myself, I tried cold spray on the large chip shielding, also tried heating up the chip and eeprom, and going back and forth with both cold and heat. none of this made a difference....I have a question, if I unplug both ribbon cables that go to the panel will that have any affect on the tv staying powered on? i was just wanting to try that in case there was a short somewhere going to the panel....also I don't see a T-Con board anywhere on this TV and none are listed on Shopjimmy.
                                        • MisterD
                                          • Oct 2012
                                          • 668
                                          I may possibly do that first. before getting too far into this thing.
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
                                          • survivalbloke
                                            Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                                            by survivalbloke
                                            I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                                            Any ideas?
                                            01-08-2024, 12:12 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
                                          • tec3000
                                            Sony LED 65X9005A shuts down after few seconds - looking for help
                                            by tec3000
                                            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                            03-20-2024, 07:29 AM
