Dell laptop powers up with kb backlight about 10 seconds, then shuts off
  • survivalbloke
    • Aug 2021
    • 313
    I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
    Any ideas?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    112 mA in off condition? Thats not right? Check voltage on all coils as well as resistance to GND. Is there any difference in voltage on coils before/after power button press? Share mb marking code
    • riki_22
      ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
      by riki_22
      I’m working on an ASUS B5402CEA notebook.
      B5402CEA_MB_R2.2
      HA4YT LA-L861P
      REV:1B
      The board powers on, fan spins for a few seconds, then it shuts down by itself.
      I suspect the BIOS might be corrupted.
      Could someone please check and clean (repair) the attached BIOS dump?
      I’ve also attached a few photos of the motherboard for reference.
      Thanks in advance for your help!
      11-03-2025, 04:38 AM
    • lowpost99@gmail.com
      Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
      by lowpost99@gmail.com
      I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
      09-03-2024, 02:57 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • chaos-theory
      Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
      by chaos-theory
      I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
      Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
      03-14-2025, 05:37 PM
    • samuelphirik
      Dell inspiron 15 7567 sudden shuts down
      by samuelphirik
      Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
      During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
      I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
      Now I've noticed that laptop...
      07-02-2023, 05:45 AM
