Sharp LC-70LE660U stuck at logo...kinda
  • showngo2000
    • Jun 2018
    • 15
    I just got a FREE 70” Sharp. When I powered it on, it wouldn't go past the Sharp logo boot screen. I unplugged and did the Vol- and Input combo and it booted right up. Went in and did a factory initialization on it hoping that would fix it...no dice. I can only get it to work by using the Vol- and Input combo. Software is v2.23.
    I'm thinking the Main Board needs replaced. Am I thinking correctly? Any suggestions? Thanks!
    Re: Sharp LC-70LE660U stuck at logo...kinda
    No error blinking code?
    • showngo2000
      • Jun 2018
      • 15
      Nope, no blinking LED codes at all.
        • 12229
        • U.S.
        Try a firmware update from usb with a flashdrive.
        • showngo2000
          • Jun 2018
          • 15
          Tried the update.
          -formatted drive to Fat32
          -downloaded FW from Sharp
          -unzipped and placed the .img file on the stick
          -went to TV Menu and tried to perform update
          -stick not recognized, files not recognized.
          Any other ideas? I tried from the manual update over Network as well, and it just says it’s up to date.
            • 12229
            • U.S.
            Try unplug tv from outlet, plug in flash drive then plug tv in. You should see some progress on the screen shortly. It should start the update by itself. It might not be updating because you have the latest firmware.
              • 12229
              • U.S.
              Could be you need to go into service menu, if you have lamp errors you need to clear them. Have to be very careful in service menu, adjusting something wrong can brick the tv.
              • showngo2000
                • Jun 2018
                • 15
                Thanks for the help. I went into the service menu and didn't see any errors anywhere. It says there's 12 pages, but not all 12 are accessible. I've attached photos of every page I can get to.
                Also it's setup for a 60” panel, is that right?
                • R_J
                  • 9581
                  This is from the service manual
                    • 12229
                    • U.S.
                    You could toggle the screen size setting there see if it has a 70, maybe do a lamp error reset, shouldn't hurt any but I don't see a lamp error on that screen??
                      • 12229
                      • U.S.
                      Did you try the update procedure RJ found?
                      • showngo2000
                        • Jun 2018
                        • 15
                        Yeah I’ve been trying it. It just won’t recognize the file or start the update.
                          • 12229
                          • U.S.
                          Hmm, maybe try a different flashdrive.
                          • budwich
                            • Jul 2015
                            • 3097
                            Originally posted by showngo2000
                            Tried the update.
                            Any other ideas? I tried from the manual update over Network as well, and it just says it's up to date.
                            when you say "stick not recognized"... what does that mean? Get a stick with an indicator light on it so you can see what's up. Further, if, indeed, the system is not "acknowledging" the usb stick, it has nothing to do with file, there is an issue with the port and / or utility / software that is using the port. IF this is true, you want to get at the usb port and check for voltages there as 5v should be seen.
                            • showngo2000
                              • Jun 2018
                              • 15
                              The system isn’t recognizing the usb stick. I’ve tried two different ones, one which had an indicator light and was lit once plugged in. I know it’s putting power out, I’ve got backlight LEDs that plug in via USB, and they work when plugged in.
                              I saw a post that said that the .img file needs to be name to “install.dmg” for it to work. Right now it’s something like BUFF_C_223.img. Could that be the issue? Sounds unlikely to me...
                              • budwich
                                • Jul 2015
                                • 3097
                                it costs nothing to rename and try again. If I recall correctly, this has something to do with the platform that you are using and how the files are created and transferred. Not sure renaming will work.
                                Further: Are you sure about this... "I saw a post that said that the .img file needs to be name to “install.dmg” for it to work." I don't think the set utilizes "DMG" files.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  you also need to plug in the usb with the set unplugged and then plug the power in... that way the system automatically detects the usb and starts looking for img files and loads them accordingly. Still further, you need to test the voltage as just seeing lights isn't a test. The voltage has to be near the proper value AND stable.
                                  • Steamy777
                                    • Oct 2013
                                    • 8
                                    What are the proper voltages and what pins do I test I have a problem with this model tv
                                    • kdh2012
                                      • Dec 2012
                                      • 17
                                      • usa
                                      Just had one of these tv's come in stuck on the Sharp logo, and eventually cycling. We downloaded the firmware (Buff_C_223.img 130,060KB) and extracted it to a flash drive. Plugged in the flash drive, held input and vol- and powered up. It started loading the flash drive for a while, then froze up. It said to not turn off the tv, but we had no choice. Unplugged the tv (wouldn't turn off), and removed the flash drive. The tv did the same thing (stuck on sharp logo). So unplugged again, put the flash drive back in, and powered up the tv (without holding the input and vol-). It started loading the software again, but differently. It showed each portion of the software it was loading. After a couple of minutes, it said it was completed! And all is well. Don't really know if holding or not holding the input and vol- makes any difference. Good luck to the next guy!
                                      • Stunt
                                        Hp Laptop Stuck on Hp protected by hp sure start screen
                                        by Stunt
                                        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                        screen that's it and stuck there. I left it until the following day and i still...
                                        09-02-2025, 01:51 PM
                                      • YellowJacket
                                        SHARP LC-32CHF5111K - stuck at color test mode
                                        by YellowJacket
                                        Hi friends,
                                        TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                        So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                        02-04-2023, 03:11 AM
                                      • stormanimal83
                                        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                        by stormanimal83
                                        Hey....
                                        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                        01-18-2024, 02:15 PM
                                      • ekozeko333
                                        [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                        by ekozeko333
                                        I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                        🔥 The Problem Started After Suspected ESD/PD Fault
                                        I experienced a power issue or ESD event through a USB-C charger
                                        After that, the NX20P5090 power switch was visibly burned and was replaced
                                        Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                        🧠 What I’ve Done So Far
                                        Flashed...
                                        06-21-2025, 02:48 AM
                                      • praveenramavath
                                        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                        by praveenramavath
                                        Hello All,
                                        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                        https://www.hifivision.com/threads/m...-screen.98243/
                                        Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                        04-26-2025, 09:08 AM
