Re: Panasonic 58-TXAX802B Stuck on Panasonic Logo
I know i'm reviving an old thread here but i'm wondering if the OP Ben198585 has any more info on what they did as i'm in the exact same boat now.
I have the exact same boards and i'm going to frankenstein them!
Physical mods i'm fine with.
I have both service manuals.
regarding pinout mods, you mention main board to power, buttons and ir.
Are the below the mods you made?
* - Main board (A-Board) >>> power board (P-Board)
* - Main board (A-Board) >>> IR receiver (K-Board)
* - Main board (A-Board) >>> Buttons (GK-Board)
I just downloaded both service manuals, then compaired both power boards and main boards to put correct pin 2 pin.
It does get very confusing lol... As long as you check your wiring 3 time over before you switch it on.
I wired the B/L on to the standby button, and when you turned tv off with remote it didn't turn off the B/L.
So that was the only thing that wasn't perfect!!
but just ment turning it off with the button on the side instead.
TX-50AX800E
TNPH1100Leave a comment:
but just ment turning it off with the button on the side instead.Leave a comment:
Hi, jumping in on the end of this talk about the poor fast dying model the TX-**AX802.
I have some good news!!!
I picked up a main board from a TX-**Dx902 flagship model off the bay for £40 (not bad compaired to £150)
If one ever turned up on the bay, it would most definitely end up going bad. A Bit like a £150 ticking time bomb lol...
A little bit of modification to back cover with the metal snipped & removal of the 5 aux ports on top of the main board, also add putting correct pin to pin rewiring main to power, main to ir & buttons. This is not plug n play!!! Be warned!!! Also remove original HDMI/backlight control boards.
Stitch up after rewire, zap with 2.6 jigga watts and Frankenstein is alive.
I know it's A bit ghetto but keeps recycling fun
I can't really understand how u wired the backlight between the new main board and the inverter board. Or is there no need for wiring. Could you please explain that to me.
Best RegardsLeave a comment:
Jamjon i thought you had same model same problem and instead nothing, this is not the place for you, open.your own thread pleaseLeave a comment:
My 50axw804 is hanging in a boot loop. Sometimes its working (when it passes some point in the boot process) normal unto the next boot. It doesn't show any error code whithin the test mode.
@David: what would be your plan, which debug port you mean?Leave a comment:
Thanks for the information Davi .
Haven't experimented with this model myself , but was told by another engineer about the pairing thing .Leave a comment:
Zen i don't think the thing is made so, i guess : in factory it is written the firmware, after it is launched an application from within the tv that reads the CPU registers and initializes the right keys in the right files. The problem with the eprom copying is that it is like two cars turning with same ... sorry i don't know the name.. plate??Leave a comment:
Hi
Even if you manage to programme up the E M M C chip & get the set working , i suspect there may be issues with the HDMI hand shake , as i believe the chip is paired with the CPU .
Most TV manufacturers have now started to do this , & as of yet , i don't know of anyone that has found a workaround .Leave a comment:
The problem is only software for me. there's non need to replace any chip. The point is that it needs to succesfully have access to the system through the debug port and no other strange obstacles prensent , finally needed a good basic knowledge of linux systems. If out there some of you would risk to spend money for sending the board to me, i can try to do the work in the time intervals, i need to be payed for the work anyhow.. The main risk is that there can be a software protection when accessing system..Last edited by Davi.p; 01-11-2021, 06:38 AM.Leave a comment:
Could u show the wiring that you changed?
Thanks my friendLeave a comment:
VERY nice work, it's very cool when someone solves a puzzle like that and everything works fine, as long as no protection was disabled, just did one not long ago, needed a snip here and there and presto. Nice save.Leave a comment:
I know it's A bit ghetto but keeps recycling funLeave a comment:
dump for ic1600Attached FilesLeave a comment:
There is no need to upload a new DUMP to the IC1600, but the main problem is in the eMMC IC8903 on the other side of the mainboard.Leave a comment:
Apologies for the general post, but I have exactly the same problem with the same model (the TX-58AX802). Removing and reflashing seems like an extreme solution but if anyone has any pointers I'd be more than grateful.
I guess if someone could tell me where the firmware image is stored, for example there is a replacement t-con board on ebay which I'd happily fit, but want to be sure that will fix the problem (i.e. where the firmware is stored).
There are three groups of boards (excluding the power on the left), the t-con board seems to be the one at the bottom (as it's the same as the part on ebay), but the other chap here sent a photo of the board on the right (which has all of the external ports connected). The centre seems to be the HDMI control board. If anyone could let me know which board I'd need to replace, or if there's any other way of getting beyond the panasonic logo that would be amazing.
This only just happened, it seems to have automatically updated itself as it had been fine since I had it which was second hand for a little over a week!
*** EDIT! ***
OK - so t-con = timing controller, so would imagine it's unlikely to be that, so the firmware is on a chip on the mainboard presumably. Did anyone manage to reflash it? I'm so surprised, I've seen around 15 of these panels showing the same problem just in my limited research, there's got to be a straightforward way of doing this. WOuld happily pay is anyone could reflash it for me, I'm in Huntingdon\St Neots area.
*** SECOND EDIT!? ***
So based upon what diif and paul said I'd need to reflash the IC1600 (so need to work out how to flash it, and need to find the firmware for it, because the standard panasonic SEC file isn't enough), otherwise I'll need to find a main board replacement!
*** THIRD AND FINAL EDIT!! ***
OK so there's a connector labelled CN1600 which I traced back to the IC1600 chip, presumably so it could be factory flashed.
Is there any way of getting hold of the IC1600 firmware from the above broken link, and would anyone be able to flash it for me for a fee?
Thanks guys,
RossLast edited by cubinarium; 09-16-2020, 02:11 PM. Reason: Updated post with more detail, refined my question.Leave a comment:
Anyone manage to find a dump for this ?Leave a comment:
by x_orange90_xI just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by justice171Hi everyone,
I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
Thanks in advance!
by mr.DataHello,
This Macbook Pro 2018 boots up and then gets stuck on the logo.
All the normal methods of resetting this Macbook have been tried but do not work.
I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
Any help would be greatly appriciated.... -
Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....1 Photo
- Loading...
