UN60F7100AFXZA issue standby blinks 5x never turns on
  • jstraksis
    • May 2019
    • 14
    I have a Samsung UN60F7100AFXZA it is just clicking and not turning on fully, the standby light blinks 5 times then the power relay clicks and starts the whole process over. I get steady 5VDC on pin 22(I believe to be the stby) on the cable that connects the logic board. the other pins match the board markings when I try to turn the tv on. the power relay carries 5V when closed on the small legs, the capacitors appear ok and read at or above rated capacitance except for the one circled on power board image, which will show as a short then 70microF. Not sure what the capacitor is cannot find any ratings on it.
    Would appreciate any tips for narrowing down my problem with this tv
    these are the boards in my TV
    Power Board:
    https://photos.app.goo.gl/jNsv6YnrHCD5H9cB8
    Logic Board:
    https://photos.app.goo.gl/XBhEraMx4jNfqtpz5
    Small capacitor:
    https://photos.app.goo.gl/ASCst1soSkiUWLPm8
  • R_J
    • Jun 2012
    • 9535
    Re: UN60F7100AFXZA issue standby blinks 5x never turns on
    I answered your question in your other post. you only need one thread.
    • neilc6
      • Nov 2015
      • 1550
      Make sure your backlights are working before suspecting boards. On Samsungs, first test is to unplug the cable between the main board and power supply to see if the backlights come on. If they don't, then confirm the LED backlights are all working (easier with a LED tester).
        https://www.badcaps.net/forum/showthread.php?t=76636
        • jstraksis
          • May 2019
          • 14
          TV model : UN60F7100AFXZA
          POWER Supply Board: BNN-00630A
          from what I can see pin 22 A5V it is the only pin that is carrying voltage before I try and turn the TV on
          https://photos.app.goo.gl/YGGSigaaSP3aKiJr8
          Standby pin 22 holds 5.34 V steady throughout
          PS-ON PIN 24 is 0.26V in standby mode
          PS-ON PIN 24 3.3V when relay closes,
          PS-ON PIN 24 0.26V when relay clicks back out
          What would you suggest to look at why the main board is not sending continous power to PS-on
          • jstraksis
            • May 2019
            • 14
            I went back over the power supply board this morning, and disconnected it from the main board and plugged the led cables back up and the lamps power up when plugged in. also when the main board is unplugged all the pin outs show the voltages they call for on the board,
            1. 12.6
            2. 12.6
            3. 12.6
            4. 3.1
            5. 1.35
            6. 3.1
            7. 1.35
            8. 3.1
            9. 0
            10. 3.1
            11. 12.6
            12. 3.1
            13. 12.6
            14. 12.6
            15. 12.6
            16. 3.1
            17. 12.6
            18. 0
            19. 0
            20. 0
            21. 5.35
            22. 5.35
            23. 5.35
            24. 3.35
            But when I connect the main board back up the only voltage I still get is pin 22 @ 5.35vdc. is there any point in troubleshooting the main board or would any of the parts be replaceable?
            • nomoresonys
              • 12145
              • U.S.
              Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description and condition on and off, pay attention to, looks like pin 15 BLU-ON. looks like the mainboard isn't sending that signal so your getting no backlights, do you see menu or anything on screen with a flashlight when hitting menu? 2 threads on same tv makes things confusing that's why it's frowned on.
              • jstraksis
                • May 2019
                • 14
                Thank you for the advice I will check those numbers and post, I apologize for the double post.
                • jstraksis
                  • May 2019
                  • 14
                  I have attached voltages I got from the main board side connector with all boards connected and TV plugged in then also while the power would cycle. I do not see anything on the screen when the power is cycling even with flashlight
                  • nomoresonys
                    • 12145
                    • U.S.
                    From the looks of your chart it looks like the mainboard isn't sending the blu-on signal to turn on the backlights.
                    • jstraksis
                      • May 2019
                      • 14
                      would there be any parts to check on the main board for replacement or easier to just get a replacement. and would not having that signal keep the power relay cycling?
                      • nomoresonys
                        • 12145
                        • U.S.
                        I'd replace the mainboard myself, suppose it could be something simple but I usually don't have the patience or in depth knowledge to fix the mainboard. Other than simple eeprom replacement which I don't think is your problem, yours could be micro controller issue??
                        • nomoresonys
                          • 12145
                          • U.S.
                          Could try heating mainboard with hairdryer, small section at a time be sure n heat the capacitors on mainboard too and see if there's any change.
                          • Brucetafer
                            • Jun 2018
                            • 133
                            This looks exactly like my post.. lol..
                            • jstraksis
                              • May 2019
                              • 14
                              i replaced the main board and the tv boots up perfect I still need to hook up a source to check sound but so far so good, thank you all for the help
                              • nomoresonys
                                • 12145
                                • U.S.
                                Glad to hear it.
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • Soulzink
                                  Samsug washing machine. Power supply DC41-00189a board issue
                                  by Soulzink
                                  I am trying to fix a samsung washinmachine power supply main board.
                                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                  The power supply board reference is the following: DC41-00189a
                                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                  04-19-2025, 06:26 AM
                                • howardc64
                                  by howardc64
                                  07-24-2025, 05:17 PM
                                • afnan
                                  Yamaha RX-V677 Not turning on
                                  by afnan
                                  My RX-V677 decided to quit on me.The standby light is not there and when i turn it on it just blinks. I have checked the error codes and there is one `PS3 PRT:127 L` Looks like its a power supply issue. Checked the manual and normal values are
                                  Normal value PS3: 132 to 168 and it monitors 5.5V
                                  I have checked the value of the voltage and it is exactly 5.5V tested. I do get System Version error but i believe it might be because eeprom is not powered up. I have checked these points and the Yellow ones show exact 5.5V. However, the connector highlighted in Green...
                                  01-19-2025, 07:01 AM
                                • Taurus12
                                  Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                  by Taurus12
                                  Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                  I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                  i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                  Any recommendation on what I have to do next? Thanks in advance
                                  06-10-2025, 05:05 PM
