can anyone help me identify this cap
  • jstraksis
    • May 2019
    • 14
    https://photos.app.goo.gl/mHsjtJc4Q8ynUvqWA
    was testing caps on this board and this one is giving me an intermittent short then a reading of 70microF
  • mariushm
    • May 2011
    • 3799
    Re: can anyone help me identify this cap
    Read the text on the capacitor, type what's written on it here...
    or take a clear picture (use macro mode if needed) and upload it here
    based on all the other capacitors on the board, it's most likely a samwha or samyoung capacitor, series and specs I have no idea... that's why you're supposed to read what's on it.
    • jstraksis
      • May 2019
      • 14
      https://photos.app.goo.gl/V912a8vU2qEN44dt9
      I read whats on the cap but it doesn't list any capacitance but it acts like it wants to keep discharging repeatedly unlike the other capacitors
      • R_J
        • Jun 2012
        • 9625
        The markings are likely on the other side, what is the problem with the tv? The cap is for the B5v supply It might be a 390µf/25v
        There are two 390Ω resistors in parallel with the cap.
        Check if QS851 is shorted
        Then check all the solder connections on the transformer pins and fets etc. that are mounted to the heatsinks
        • jstraksis
          • May 2019
          • 14
          its from samsung tv, the power relay keeps clicking on wait 5-10 secs but it never powers up the tv. this cap will carry 5V then discharge with the relay. but the tv never turns on it just keeps power cycling. the caps all appear in good working order show readings of or above their rating.
            Did you verify that the PS-ON stay at >2V when the relay drops out? Relay is turned on by the PS-ON signal.
            Is the standby power supply Voltage steady?
            You should report the Voltage reading of the power supply connector that goes to the main board is in standby and when power switch is activated, make sure to put down the pin name and follow by the reading for each pin so we can easily see what is going on.
            What is the Model of the TV?
            Power supply board BN44-??????
            I see you double post: https://www.badcaps.net/forum/showthread.php?t=76638
            • jstraksis
              • May 2019
              • 14
              ill test that item in a few im trying to locate it currently
              TV model : UN60F7100AFXZA
              POWER Supply Board: BNN-00630A
              from what I can see pin 22 A5V it is the only pin that is carrying voltage before I try and turn the TV on
              https://photos.app.goo.gl/YGGSigaaSP3aKiJr8
              Standby pin 22 holds 5.34 V steady throughout
              PS-ON PIN 24 is 0.26V in standby mode
              PS-ON PIN 24 3.3V when relay closes,
              PS-ON PIN 24 0.26V when relay clicks back out
              • jstraksis
                • May 2019
                • 14
                QS851 does not appear to be shorted out
                  Well, you need to find out why the main board stops sending the PS-ON signal.
                  Since we are trying to fix TV you should stick to this TV thread instead:
                  • jstraksis
                    • May 2019
                    • 14
                    ok
                    • CapSwapper
                      • Feb 2014
                      • 69
                      lmao Sam Young. more chinese junk like the rest of the capaciotrs
                      • protocold
                        MacBook Pro 15" 2010 820-2850 intermittent charging
                        by protocold
                        I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                        I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                        when it is not intermittent:
                        PPVBAT_G3H_CHGR_R is 12.07v
                        when it is intermittent:
                        When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                        when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                        data line on the battery...
                        07-25-2025, 08:18 PM
                      • thesame
                        DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                        by thesame
                        Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                        The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                        02-27-2024, 04:31 AM
                      • silver60618
                        Lenovo Legion 7 - Help Identify IC
                        by silver60618
                        Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                        I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                        Any help would be appreciated...
                        07-02-2025, 12:16 PM
                      • chth96
                        How can I identify varistor which have been blew up?
                        by chth96
                        I mistakely pluged 100v japanese retro game console to 220v outlet.
                        So It seems that glass fuse and varistor have been blew up.
                        I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                        Is there any way to identify varistor type in my sega saturn PSU?
                        Any reply would be appreciated.
                        EDIT:
                        It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                        11-26-2023, 08:52 AM
                      • freakorio
                        Need Help To Identify Component on Ymain LJ41-05120A
                        by freakorio
                        Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                        05-21-2024, 02:32 AM
