55ub850v no picture
  • thuss
    • Jul 2012
    • 317
    55ub850v no picture
    Hi
    I could do with some advice.
    Ive got a 55ub850v tv which turns and stays on, with backlights and sound but no picture.
    The fuse on the the tcon has 11.78v on both sides.
    There is also voltages on I assume test points at the bottom right hand corner of the tcon. There is also voltage present on the bottom left corner which fluctuate.
    I have checked the (as much as I can) the components on the screen boards. They seem fine.
    The psu output voltages are fine. The chips on the tcon is not very warm- whilst the main chip on the main board is hot-ish.
    I was wondering if anyone could advise on what to check next or what they suspect is faulty?
    I was going to change the main board.
    Thanks in advance
    Re: 55ub850v no picture
    What do you get on the screen if you have only one ribbon cable connected one at a time between T-CON and the tab boding board?
    BTW, pictures are too out of focus to see Voltage test points on that T-CON board.
    • thuss
      • Jul 2012
      • 317
      If I remove the one ribbon or both of them the screen still remains blank - I hope the attached photo of the voltages for the test points on the tcon (bottom right hand corner).
      If I remember correctly they read between 1.2v to 13.9 and were static but not 18v.
      There are no voltages written on the bottom left hand corner of the tcon.
      When I removed the two ribbon cables from the tcon the voltages read the same.
      Sorry really struggled to get clear focused photos
      • thuss
        • Jul 2012
        • 317
        Bottom Left hand side of tcon
        • CapLeaker
          Leaking Member
          • 8027
          Check the LVDS with an oscilloscope. See if the main board puts anything out. Also check to see if the panel is getting any power.
          • thuss
            • Jul 2012
            • 317
            no havent got a scope - the main board is getting power and then in return feeds power to the tcon hence the 11.8 v on the fuses.
            Would the next step be to remove the Lvds and supply 12v to tcon fuse and connect vcc to pin 41?
              https://www.badcaps.net/forum/attach...3&d=1525142506
              https://www.badcaps.net/forum/attach...0&d=1525170610
              I still cannot see much test points on that inverter board, I cannot read the P/N on the barcode sticker and the P/N as printed on the board.
              BTW, what brand is this 55ub850v?
              • thuss
                • Jul 2012
                • 317
                its a lg tv and please see attached photo where I tested the voltages on the tcon
                The part number is also on the photo
                • thuss
                  • Jul 2012
                  • 317
                  as far as I can make out the p/n 6807-0502c thats all there is on the board there is no additional stickers.
                  The second part number maybe 6871E - 3703M?
                  I assumed they were test points
                    LG 6871L-3703M (6870C-0502C) T-Con Board.
                    There many power supplies Voltages that need to be tested.
                    Pictures provided by shopjimmy.
                    • thuss
                      • Jul 2012
                      • 317
                      Thank you for that - would they range from say 1v up to a max of 24V?
                        Voltage range of what test points?
                        Just report Voltages of all those test points, make sure to put down the name and follow by the Voltage reading.
                        • thuss
                          • Jul 2012
                          • 317
                          will do thanks
                          • satinser
                            • Oct 2012
                            • 214
                            Had two of this model both with the issues you describe in the last couple of months both were caused by faulty main boards. In both instances a replacement main board resolved the problem.Also from what I remember the 49" board will also work with no adjustments.
                            Hope this helps.
                            • thuss
                              • Jul 2012
                              • 317
                              Hi
                              Sorry about the late response. The readings on the tcon were as follows
                              v18-1.6mv
                              v15-1.9mv
                              v14-1.7
                              v12-1.6
                              v10-1.6
                              v9-13.4
                              v7-13.5
                              v5-13.5
                              v4-13.7
                              v1-13.7mv
                              vdd- 1.74v
                              vcourfb- 1.7
                              vcc18- 1.6
                              vglI- 18.3
                              VIN- 11.78v
                              VGH - 1.5mv
                              VDD - 0.7
                              VCOM2- 22mv
                              VCOM1- 22mv
                              VCORE- 1.5mv
                              VGH_R- 1.4mv
                              VGH_even- 5.8mv
                              VGH_ ODD- 5.7mv
                              I think its the screen but any advice would be appreciated. I changed the main board still has the same symptoms. i.e No picture (the replacement board was out of a broken 49ub850v screen tv with a display).
                              • thuss
                                • Jul 2012
                                • 317
                                I also swapped my main board (from 55ub850v) into the broken screen 49ub850v turns on and displays a broken picture.
                                I also swapped the tcon out of the broken screen 49yb850v into the 55ub850v but still no picture
                                  • 12086
                                  • U.S.
                                  Guess it's possible that the tcon from the 49 isn't a match for the 55?
                                    • 12086
                                    • U.S.
                                    One thing to try, put the 49 tcon back in the broken screen and see if it still has the picture, a lot of times a bad panel will kill a tcon. Did you try the tcon from 55 into 49?
                                      Hi
                                      v18-1.6mv
                                      v15-1.9mv
                                      v14-1.7
                                      v12-1.6
                                      v10-1.6
                                      v9-13.4
                                      v7-13.5
                                      v5-13.5
                                      v4-13.7
                                      v1-13.7mv
                                      vdd- 1.74v
                                      vcourfb- 1.7
                                      vcc18- 1.6
                                      vglI- 18.3
                                      VIN- 11.78v
                                      VGH - 1.5mv
                                      VDD - 0.7
                                      VCOM2- 22mv
                                      VCOM1- 22mv
                                      VCORE- 1.5mv
                                      VGH_R- 1.4mv
                                      VGH_even- 5.8mv
                                      VGH_ ODD- 5.7mv
                                      T-CON board is dead, it has 12V feeding it but lots of Voltages are really really low. Do you get the same readings if the cables between T-CON and LCD panel are removed. The board may not be compatible with your screen, also can be bad panel that causes lots of Voltages on T-CON to be low.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        +10 Bad panel sorry to say. With 12V supply coming in and getting only mV on several of those test points, it would appear that either the T-CON is not working as previously stated or the Panel. I suspect the Panel though.
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • EazyBone
                                          Sony XR-77A80J OLED 5 Blink
                                          by EazyBone
                                          Another eazybone post took on this OLED now.
                                          Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                          I'm thinking I have a power board issue though, which is one of the options
                                          Now to check pin voltages from PSU to main and PSU to tcon
                                          Pic 2
                                          1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                          2 bl err -- 0.16
                                          3 evdd on --0
                                          4. Ac off det 3.187
                                          5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                          6 stby...
                                          10-24-2023, 09:09 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
