How to turn on a TV without remote or physical buttons?
+ More Options
Posts
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    As said, no remote nor physical buttons. No joystick or wheel either.
    Too old for any type of on-screen touch-commands.
    Model is Philips 42pf3320/10.
    Also, I don´t have access to smartphone with IR port...
    Any solution other than magically turning it on by willpower?
    Got it as no-tested so could be working as far as I know. Power button turns it on in standby with red diode stable as rock
    Thanks in advance
    stay classy
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: How to turn on a TV without remote or physical buttons?
    Have you access to an universal remote?
    • Joe Black
      eager to learn
      • Sep 2015
      • 173
      Eh, forgot to wrote that one. Nope, but I'll have to manage that.
      Can't expect wonders to happen, right?
      I just can't believe that someone designed TV without physical buttons, nonsense.
      Now, if I find universal remote, can I use it on TV in STBY mode? Will that work?
      stay classy
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        i had a DL branded one like that a while ago. ended up stripping it for parts, then about 3 weeks later, got my hands on a remote.
        the problem with most universals is that it requires you to have the tv powered up first to scan for the right frequency. so not ideal.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I have bought quite a few remote controls directly off the internet at very low prices.
          I'm sure that there are probably cheaper ones out there.
          http://www.ebay.co.uk/itm/New-UK-STO...-/121541616789
          • budwich
            • Jul 2015
            • 3097
            any cheap remote that requires you input the manufacturer "code" will likely work... IF that manufacturer code is in the remote's "code base". I suspect "philips" is pretty "standard"... and perhaps a few other "code base" may work... eg. magnovox, etc.
            • dskall
              • Oct 2016
              • 2905
              • usa
              I've been able to find original equipment remotes for all my TV's as cheap as a universal. Don't have to mess with programing
              • gabiz_ro
                • Mar 2011
                • 167
                • Romania
                Use some DVD player or any thing with euroscart (euroconnector) to inputs EXT1 or EXT2.
                Device must have same euroscart connector and good working cable.
                Some TV when powered on switch to respective input when attached DVD or device connected is powered on.
                There is one pin signal in that cable that will signal TV that device is powered and TV switch to EXT1 or Av1 etc.
                Maybe this can power up too TV from stand-by.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  I agree with "Joe Black". There should be a power on function on mainboards like on laptops. Shorting 2 pads and it turns on.....
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    In this video he has a signal connected to EXT2 and then plugs in the tv which comes on without pressing any buttons on a remote.
                    https://www.youtube.com/watch?v=j9YQ6fe08g0
                    • ducky29
                      • Dec 2015
                      • 369
                      • Europe
                      You have to turn it on first, then it will change sources automatically if you plug in the device that is connected to EXT2/
                      • Joe Black
                        eager to learn
                        • Sep 2015
                        • 173
                        Got a original remote, so this is sorted nicely. Original owner found it beneath the closet. Thanks, people!
                        Now, it just changes LED status from red to green and there's nothing on the screen, even under lamp.
                        Should I start a repair thread, bearing in mind that this thing is plasma? Any hope?
                        stay classy
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          There are many plasma experts on this forum and ofcourse you dont see anything on the screen with a lamp. Its plasma not lcd. ( There are no lamps ).
                          Start a new thread with good pictures!
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            have you looked at the video in post 10 that problem sounds like the one your having too so maybe worth testing the capacitors for esr etc
                            • Joe Black
                              eager to learn
                              • Sep 2015
                              • 173
                              I knew that
                              Haven't checked the video, sure will. And then start the thread with pics and info.
                              Thanks a lot.
                              stay classy
                              • Joe Black
                                eager to learn
                                • Sep 2015
                                • 173
                                TV working again, just as on the video linked above.
                                Many thanks to Dick Barton and the others.
                                So, if someone googles, hopefully he´ll see this:
                                -PHILIPS plasma TV (many models), turns on but no image (picture)
                                -Most of the time troublemakers are two elcos on the main board (often expanded visually or cracked), values 3300uF and 10V, both.
                                stay classy
                                • Joe Black
                                  eager to learn
                                  • Sep 2015
                                  • 173
                                  Now, I hadn´t 3300uF by me, so i put on a combo of 2200+1000 x2.
                                  Any downsides on that?
                                  And, it would be nice if PHILIPS actually produced some parts of it´s TV. (haven´t checked panel tho)
                                  If I wanted SAMSUNG, I´d buy one in the first place
                                  stay classy
                                  • augiedoggy
                                    • Aug 2016
                                    • 62
                                    • united states
                                    They do? or rather that companies that actually make the tv for phillips usually use off the shelf components short of the main board..(As I believe you already eluded to seeing). I had an old phillips plasma myself which was actually a samsung plasma with a "phillips" speced main board and firmware... I was told phillips got out of the tv making business themselves in 2004 or 2006..
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      Rebranded funai is what you'll see now.
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • markolino
                                        LG OLED55B7V doesn't turn on Help.
                                        by markolino
                                        Hi.
                                        namely, the TV stayed turned off at the red light overnight.. when I want to turn it on with the remote or physical button, there is a not relay click.. and after 5 seconds a click back. the light is always on, nothing flashes... I opened the TV and played around a bit.. when I disconnected the flat cables that lead from the T-Con of the board to the main board, the TV behaves differently (normally) the red light flashes 3 times and then disappears... the TV remains on.. on the main board the audio output light also lights up. and when I press the buttons on the remote, the light...
                                        09-12-2023, 03:11 AM
                                      • RdeveLabs
                                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                        by RdeveLabs
                                        To all the members here...
                                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                        05-05-2025, 04:59 AM
                                      • robante15
                                        Acer Aspire 4520 won't turn on after reboot
                                        by robante15
                                        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                        If I remove the...
                                        04-06-2024, 06:50 PM
                                      • masoksian
                                        Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                        by masoksian
                                        I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                        The system does not turn on, there is no post.
                                        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                        The problem continues in the same way.
                                        I tried to turn on the Fn key, nothing came to the screen....
                                        02-15-2025, 12:08 PM
