Sanyo FW42D25T
    • 12328
    • U.S.
    Re: Sanyo FW42D25T
    didnt have a 10uf 50v cap handy for the orange cap, threw a 47uf 50v in there.
      • 12328
      • U.S.
      Re: Sanyo FW42D25T
      Only getting voltage there, only millivolts or 0 volts everywhere else, no voltage on cold side no voltage on any coil or cap except filter cap no voltage on UL1, UL2 or eeprom, maybe problem with transformer?:
        • 12328
        • U.S.
        Re: Sanyo FW42D25T
        oops I lied, there is 170 volts on 2 pins of the transformer on hot side.
          • 12328
          • U.S.
          Re: Sanyo FW42D25T
          • R_J
            • 9623
            Re: Sanyo FW42D25T
            For the primary smps ic to operate it first needs vcc voltage, what do you measure on the vcc pin of the ic?
              • 12328
              • U.S.
              #26
              Re: Sanyo FW42D25T
              not sure, is that ic on the primary/hot side? I don't see any ic on the hot side.
              • R_J
                • 9623
                Re: Sanyo FW42D25T
                It is on the primary side. There will be a small driver ic, likely a smd 6 pin, this ic drives a power mosfet that switches the primary of the main transformer to produce the secondary voltages.
                • lotas
                  • Jan 2016
                  • 4848
                  • Russia
                  #28
                  Re: Sanyo FW42D25T
                  Remove the heatsink and you will see UB101 PWM (6pin.).
                    • 12328
                    • U.S.
                    #29
                    Re: Sanyo FW42D25T
                    Thanks gentlemen, any way to verify UB101 is not working, like testing QB101 or DB106? QB101 has 170 v on middle pin, 0 v on the other two, DB106 tests good in diode mode, has 170 v on each end.
                    • R_J
                      • 9623
                      Re: Sanyo FW42D25T
                      What is the top marking on the ic? what is the vcc voltage?
                        • 12328
                        • U.S.
                        #31
                        Re: Sanyo FW42D25T
                        would have to remove heatsink to get to it, was hoping there was another way to proof it out.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Re: Sanyo FW42D25T
                          A simple desoldering job that should take less than 5 minutes, what's the issue?
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            Re: Sanyo FW42D25T
                            Any progress on this? What soldering iron do you have?
                              • 12328
                              • U.S.
                              #34
                              Re: Sanyo FW42D25T
                              already moved on, this one isnt worth time or energy.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                Re: Sanyo FW42D25T
                                For the sake of a 5 minute soldering job
                                Do you not have a decent soldering iron?
                                  • 12328
                                  • U.S.
                                  #36
                                  Re: Sanyo FW42D25T
                                  to what end, no time for it, if you want it just hop on over and it's yours, no charge.
                                    • 12328
                                    • U.S.
                                    #37
                                    Re: Sanyo FW42D25T
                                    its an old tv from 2012, theres no value there, was only looking at it for the puzzle factor but really not curious enough to mess with it anymore.
                                      • 12328
                                      • U.S.
                                      #38
                                      Re: Sanyo FW42D25T
                                      I for sure appreciate the help from Lotus and RJ but this one isn't worth wasting anyone's time on.
                                        • 12328
                                        • U.S.
                                        #39
                                        Re: Sanyo FW42D25T
                                        Having a little revisit with this one board pos, think it's bad backlight/s, current situation, tv comes on fine, goes blank screen after about a minute or so, sound still there, passes flashlight test, voltage on big caps is about 164 both when working with picture and when it goes dark, I don't know much about these one board tvs, do you think that it is only suppose to have 164 and not go any higher or is something else wrong other than backlights?
                                          • 12328
                                          • U.S.
                                          #40
                                          Re: Sanyo FW42D25T
                                          Anyone know if these are supposed to have boosted voltage or not?
                                          • HERETIK10
                                            MSI GT70 2PE Voltage dropping on the main power rail
                                            by HERETIK10
                                            I have a strange problem (for me) on an MSI GT70 2PE laptop.
                                            When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                                            The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                                            On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                                            I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                                            11-24-2023, 06:06 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • Henke
                                            Philips 55POS9002/12 - No PS_ON voltage from main board
                                            by Henke
                                            I wondering if there are some usual faults regarding the PS_ON signal from main board to PSU board?
                                            Where do i start looking?
                                            I have standby light and the PSU is working if i connect 3.3V to the PS_ON pin on the psu board....
                                            08-11-2024, 08:34 AM
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
