Sanyo FW42D25T
  • nomoresonys
    • 12328
    • U.S.
    #81
    Re: Sanyo FW42D25T
    I will look up the data sheet on both chips, I suppose they are compatible, I think they just sent this out with a garbage dump on it.
    • nomoresonys
      • 12328
      • U.S.
      #82
      Re: Sanyo FW42D25T
      Ok, contacted the seller, they said you have to match every letter and number of the part number, my part # is 02-SLS39A-C005000 001, the one I bought is 02-SLS39A-C003014. Looks like the first eight numbers match, does that sound like an explanation for it being badly damaged or not able to work for my board, if so then it was my fault for not knowing that I needed to match every number in that string. Thanks Lotus for the assist.
      • lotas
        • Jan 2016
        • 4841
        • Russia
        #83
        Re: Sanyo FW42D25T
        This dump has a severely damaged firmware core and this firmware will not work on any TV or you did not read it correctly from the chip (bad contact...), I cleaned your original dump for you, write it down correctly and check it.
        • nomoresonys
          • 12328
          • U.S.
          #84
          Re: Sanyo FW42D25T
          Ok, thanks, that's what I thought you meant when you said it was severely damaged, which is it is not fit for anything, so is it true that I should have matched all the numbers or was the first eight numbers enough? I only read the new chip once, I'll read it again. Since I don't have a 25 adapter, I put the new chip in the clip to read it.
          • lotas
            • Jan 2016
            • 4841
            • Russia
            #85
            Re: Sanyo FW42D25T
            It’s not the numbers that are needed here, but the TV model, motherboard number, panel number, and TV tuner that match.
            • nomoresonys
              • 12328
              • U.S.
              #86
              Re: Sanyo FW42D25T
              Starting to wonder if the programmmer I bought is defective, it will not read either chip now, it doesn't say not connected to chip but all I get is f's on all lines after reading, going to try it on a 24 and see if I get a reading.
              • nomoresonys
                • 12328
                • U.S.
                #87
                Re: Sanyo FW42D25T
                I know these cheap programmers usually mean they are harder to deal with, what inexpensive step up from ch341 do you recommend?
                • lotas
                  • Jan 2016
                  • 4841
                  • Russia
                  #88
                  Re: Sanyo FW42D25T
                  25 is a spi flash, and 24 is an eeprom, they are completely different, and they have different pinouts, the main thing here is that 1 pin of the chip corresponds to 1 pin on the programmer.
                  • nomoresonys
                    • 12328
                    • U.S.
                    #89
                    Re: Sanyo FW42D25T
                    Yes indeed, excuse my lumping them up, Yes pins 1 are lined up.
                    • nomoresonys
                      • 12328
                      • U.S.
                      #90
                      Re: Sanyo FW42D25T
                      Well the goshdampos programmer will not read anything, it read those two chips, that was all it did. Tried it on 4 others and those two again, nothing but f all across. Sending the programmer and the chip back and starting over OR giving up.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • HERETIK10
                        MSI GT70 2PE Voltage dropping on the main power rail
                        by HERETIK10
                        I have a strange problem (for me) on an MSI GT70 2PE laptop.
                        When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                        The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                        On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                        I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                        11-24-2023, 06:06 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • Henke
                        Philips 55POS9002/12 - No PS_ON voltage from main board
                        by Henke
                        I wondering if there are some usual faults regarding the PS_ON signal from main board to PSU board?
                        Where do i start looking?
                        I have standby light and the PSU is working if i connect 3.3V to the PS_ON pin on the psu board....
                        08-11-2024, 08:34 AM
                      • Fernon@Repair
                        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                        by Fernon@Repair
                        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                        VCCIO voltage ok
                        VCCSA Voltage OK
                        VCCPLL Voltage OK
                        Ram Voltage ok
                        RamVTT OK
                        VPP 2.5 OK
                        But No Core Voltage
                        and i want to this vrm ic datasheet or pinout (ISL69269)
                        anyone have this ic pinout voltages?...
                        06-25-2025, 07:19 AM
