Sanyo FW42D25T
  • nomoresonys
    • 12328
    • U.S.
    #41
    Re: Sanyo FW42D25T
    Ok, so probably no boosted voltage in this tv, anyway the panel lights up, 48 leds, 8 across, 6 vertical, all leds are equally bright, then 42 seconds later they all turn off, tested both lines with backlight tester, have 64.5 on both. Kind of seems low if they are 3 volt leds.
    • nomoresonys
      • 12328
      • U.S.
      #42
      Re: Sanyo FW42D25T
      After the 42 seconds and they go off, if I try to turn it off and right back on the backlights stay off.
      • nomoresonys
        • 12328
        • U.S.
        #43
        Re: Sanyo FW42D25T
        No, I lied, it does come back on, what it does is hit power backlights come on in 5 seconds then go off about 42 seconds later, every time.
        • nomoresonys
          • 12328
          • U.S.
          #44
          Re: Sanyo FW42D25T
          Resistor RB114 is marked 4r7 but reading 7.6 ohms, wondering if that would be bad enough to cause this problem.
          • nomoresonys
            • 12328
            • U.S.
            #45
            Re: Sanyo FW42D25T
            If you look at the picture in post #1, it's that resistor right there by CB116 by the transformer. Also noticed that the underside of the board where this transistor QB801, located right by the backlight connector is discolored darker than the rest of the board, like it was maybe running hot or something.
            • diif
              • Feb 2014
              • 6978
              • England
              #46
              Re: Sanyo FW42D25T
              You're measuring it in circuit ? Take it out to measure correctly.
              • nomoresonys
                • 12328
                • U.S.
                #47
                Re: Sanyo FW42D25T
                Thanks for reply, guess this model wasn't too popular, very few youtube videos of it. Going to trace it before removing it, see where it goes and see if I can decipher what it does. It's smaller than a grain of rice.
                • nomoresonys
                  • 12328
                  • U.S.
                  #48
                  Re: Sanyo FW42D25T
                  Thinking the problem might be one of those 2 resistors, the other one 200, reads 43 ohms in circuit, or maybe QB101 or CB116.
                  • nomoresonys
                    • 12328
                    • U.S.
                    #49
                    Re: Sanyo FW42D25T
                    The most notable thing is, before backlights go off after 45 seconds both UL1 and 2 read correctly, when they go out UL1 still reads correctly but UL2 is dead, any ideas? thanks.
                    • nomoresonys
                      • 12328
                      • U.S.
                      #50
                      Re: Sanyo FW42D25T
                      Wondering if UL2 is bad or could it be whatever feeds it voltage is bad, not even any guesses?
                      • nomoresonys
                        • 12328
                        • U.S.
                        #51
                        Re: Sanyo FW42D25T
                        Would a bad eeprom UF1 make UL2 read dead/no voltage?
                        • lotas
                          • Jan 2016
                          • 4840
                          • Russia
                          #52
                          Re: Sanyo FW42D25T
                          Yes, that might be the case, post your dump here and I'll take a look.
                          • nomoresonys
                            • 12328
                            • U.S.
                            #53
                            Re: Sanyo FW42D25T
                            I wish I could Lotus but I'm not smart enough to figure out how it works, I REALLY suffer in this area and most other areas lol. Don't have a programmer, was thinking about grabbing eeprom from m-tronicz, less than 10 dollars, didn't want to invest anything in this seemingly sub-standard tv but I'm just determined to figure out the problem, THANKS for the offer.
                            • nomoresonys
                              • 12328
                              • U.S.
                              #54
                              Re: Sanyo FW42D25T
                              Just want to say THANKS, you CapLeaker and Diah are outstanding people who have helped so many, I hope good Karma comes back to you all many times fold.
                              • nomoresonys
                                • 12328
                                • U.S.
                                #55
                                Re: Sanyo FW42D25T
                                I left out a few folks who deserve mentioning but they know who they are.
                                • nomoresonys
                                  • 12328
                                  • U.S.
                                  #56
                                  Re: Sanyo FW42D25T
                                  Tested voltages on eeprom 25q32bsig, not sure if it will tell anything or not, tested on bench not grounded, 1-0, 2-3.17v, 3-3.25v, 4-0, 5-0, 6-0, 7-3.28v, 8-3.28v Data sheet: https://www.datasheetcafe.com/25q32bsig-datasheet-pdf/
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    #57
                                    Re: Sanyo FW42D25T
                                    Ok, off to YT programmer school to try to learn some new tricks.
                                    • nomoresonys
                                      • 12328
                                      • U.S.
                                      #58
                                      Re: Sanyo FW42D25T
                                      • lotas
                                        • Jan 2016
                                        • 4840
                                        • Russia
                                        #59
                                        Re: Sanyo FW42D25T
                                        The software in the firmware is live, try it with a clean NVM.
                                        • nomoresonys
                                          • 12328
                                          • U.S.
                                          #60
                                          Re: Sanyo FW42D25T
                                          You lost me, you mean I should erase it and try the one you posted above?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • HERETIK10
                                            MSI GT70 2PE Voltage dropping on the main power rail
                                            by HERETIK10
                                            I have a strange problem (for me) on an MSI GT70 2PE laptop.
                                            When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                                            The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                                            On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                                            I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                                            11-24-2023, 06:06 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • Henke
                                            Philips 55POS9002/12 - No PS_ON voltage from main board
                                            by Henke
                                            I wondering if there are some usual faults regarding the PS_ON signal from main board to PSU board?
                                            Where do i start looking?
                                            I have standby light and the PSU is working if i connect 3.3V to the PS_ON pin on the psu board....
                                            08-11-2024, 08:34 AM
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
