Philips 55POS9002/12 - No PS_ON voltage from main board
  • Henke
    • Oct 2022
    • 41
    • Sweden
    I wondering if there are some usual faults regarding the PS_ON signal from main board to PSU board?
    Where do i start looking?
    I have standby light and the PSU is working if i connect 3.3V to the PS_ON pin on the psu board.
  • nomoresonys
    • 12328
    • U.S.
    How bout a clear focused straight on picture of powerboard and the legend/map depicting expected voltages, should be nearby the connector.
    • Henke
      • Oct 2022
      • 41
      • Sweden
      The powerboard is ok, but don’t get the ps_on from main board.
      • Diah
        • Feb 2013
        • 6550
        please post photo on the complete boards to see how they connect together...
        what about the front LED indicator did it lit Red
        • nomoresonys
          • 12328
          • U.S.
          And is the optical light lit red on the mainboard.
          • nomoresonys
            • 12328
            • U.S.
            Many times when the mainboard isn't sending the power on and or bl-on signal it's the processor on the mainboard with bad solder connections, a diy reflow done properly can get it working again if that's the issue. If done properly it will not hurt to try it, many how to videos on youtube, some better than others of course. Look at this thread, lots of good info on the subject: https://www.badcaps.net/forum/troubl...-no-backlights
            • Henke
              • Oct 2022
              • 41
              • Sweden
              LED is flashing 3 fast, pause, about 40 fast and then repeat.
              • Henke
                • Oct 2022
                • 41
                • Sweden
                No, not what i can se.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • tuner2000i
                  Philips 65PUS8518/12 distorted image after main board replacement
                  by tuner2000i
                  hello everyone,
                  I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                  The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                  07-15-2025, 01:15 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  by JDC
                  ONN 100012588
                  Long answer:
                  07-15-2022, 07:39 AM
