KDL-60W600B won't open just Red Blinks 6 times
  • Ali101
    • Jul 2017
    • 152
    • Taiwan
    #81
    Re: KDL-60W600B won't open just Red Blinks 6 times
    Hi budm, IC6801 # printed on top is (Sony CXA3854M) & i search on web but can't find match # data sheet, below i found, so which one i should choose & how i check IC via Multimeter,
    Link#1: http://www.datasheet4u.com/share_sea...sWord=CXA3854M
    Link#2:
    Thanks.
      OK, I search the web and found SONY TV (KDL-xxW800 series RB1G chassis) uses power supply board that has CXA3854 IC on it, so we can at least check to see if it is getting the VCC of 12V at pin 24 or not when the TV is turned on.
      We can also find out if the BL-ON gets all the way to the EN pin 11 to turn on the IC or not.
      • Ali101
        • Jul 2017
        • 152
        • Taiwan
        #83
        Dear budm, many thanks for help, Appreciated, below is results for tests,
        Multi Meter set on 20 Dc range and On pin 24 plugin tv it show some time 1.5v and some time 2.4 and some.time 3.2 v after turn on tv it goes 4.7v than drop to 0.00 v, on pin 11 plugin tv it show 0.00v, turn on tv it goes 3.6v than drop to
        Thanks.
        • Ali101
          • Jul 2017
          • 152
          • Taiwan
          #84
          @budm, so if IC6801 (Sony CXA3854M) not getting the VCC of 12V than does that means IC6801 have problem in PSU right?
            It means that the IC is not getting the Voltage for it to run.
            You must check the resistance between the VCC pin and Ground pin to see if it shows low resistance of less than 500 Ohms or so or not, it can also be that the resistor for feeding the 12V to VCC may be bad too.
            • Ali101
              • Jul 2017
              • 152
              • Taiwan
              #86
              budm bro sorry but can you advise how to check resistance between the VCC pin and Ground pin? set multi meter on Ohms & put black prob on VCC pin 24 & red prob where? it need to check while power off tv right? your guide will help me to check faster,
              Thanks.
                When checking the resistance in any circuit you do not want to have the device powered.
                Meter set to 200 Ohms range, Red probe on VCC PIN 24, Black probe on GND PIN 23 and record the reading, then reverse the probe and record the reading. Report the readings.
                BTW, did you look around to see how this power supply board will cost you? If we do find bad surface mounted part then do you know how to remove and install the part?
                • Ali101
                  • Jul 2017
                  • 152
                  • Taiwan
                  #88
                  Thanks for advise budm, will check & get back,
                  this power supply cost is around USD $100 to $150 here in Taiwan & yes i know how to soldering & replace parts from boards,
                  Thank you so much.
                    Please check the marked resistor in the picture, it should show <10 Ohms on your meter (meter set to 20 or 200 Ohms scale and put probes on each end of the resistor).
                    • Ali101
                      • Jul 2017
                      • 152
                      • Taiwan
                      #90
                      will check resistor & post results here, thanks alot budm, & please accept my apology since i can't check & post results now coz i am on work, will back home & do check,
                      Thanks.
                      • Ali101
                        • Jul 2017
                        • 152
                        • Taiwan
                        #91
                        Ok i checked & below are results,
                        Results = 1
                        Meter set to 200 Ohms range, Black probe on VCC PIN 24, Red probe on GND PIN 23
                        Results = 160.5
                        Marked resistor in the picture results below
                        Meter set to 200 Ohms range = 24.6
                        Other two points marked in the picture results below
                        Meter set to 200 Ohms range = reading start from 5.2 & slowly slowly it goes down & it stop on 0.07
                        please check in picture yellow color reading,
                        Thanks.
                          Results = 1
                          Results = 160.5
                          Thanks.
                          I did not expect that resistor to have 24.6 Ohms, I expect around 4.7 Ohms
                          OK, now we need to test the Voltage on each end of that resistor that shows 24.6 Ohm with ref to GND. You will leave the meter probes in place and then turn the TV on to see how much Voltage we have on each end of that resistor when the TV is first turned on.
                          • Ali101
                            • Jul 2017
                            • 152
                            • Taiwan
                            #93
                            Hi budm, thanks for furthur help,
                            below are results,
                            Meter set to 20 dc range, Red probe on up
                            Results = 0.0v & after turn on tv no changes & same 0.00v
                            Meter set to 20 dc range, Red probe on down
                            Results = 12.6 v & after turn on tv it drop to 0.00v
                            below attached picture for refrence
                            Thanks.
                              below are results,
                              Thanks.
                              OK, I expect to 12V on the top end of that resistor since we did have 12V for seconds before the power supply goes into shutdown. So we have problem in that section, it can be that IC, or the two other component that are also connected to that pin 24 of the IC.
                              Can read any number printed on top of that resistor?
                              • Ali101
                                • Jul 2017
                                • 152
                                • Taiwan
                                #95
                                yes on top of that resistor it can read 4-7 actualy 4 than arrow face on 4 than 7
                                below is picture can be take as refrence,
                                  OK, it is 4.7 Ohms, the same value as used the schematic that I found which use the same IC for the backlights control.
                                  So do you have 4.7 Ohms 1/4W or less that you can solder in place of that resistor?
                                  We are getting close!
                                  • Ali101
                                    • Jul 2017
                                    • 152
                                    • Taiwan
                                    #97
                                    yes i have 4.8 Ohms 1/2W, below is picture for refrence, so i can use it?
                                      For testing, but what you need to do is to leave one DCV meter probe to gnd and another probe on the end of the resistor that is connected to VCC pin 24, the apply power to the TV and turn the TV on and see if you will get the 12V or not. Hopefully that the IC is not bad which may have caused that resistor to go up in value.
                                      The 4.7 Ohms resistor R6811 is used as a protection in case the IC, the capacitor C6822, ZENER DIODE D6811 at the VCC pin shorts out.
                                      Per schematic, the resistor is rated at 1/10W (0.10W).
                                        https://www.badcaps.net/forum/attach...8&d=1502497817
                                        BTW, that third black device (D6811) down from the 4.7 Ohms resistor (R6811) may be Zener as shown in the schematic I provided earlier.
                                        • Ali101
                                          • Jul 2017
                                          • 152
                                          • Taiwan
                                          #100
                                          Hi budm,
                                          Getting keep fail to soldering below resistor with soldering iron,
                                          https://www.badcaps.net/forum/attach...9&d=1502503446
                                          since place of the 4.7 Ohms resistor R6811 is very small & line of above picture resistor is thick, so no success,
                                          you think it’s worth to buy another PSU? coz i need to buy PSU from web so once bought, no return so you are peety sure that issue is in tv PSU right? It’s not LCD or any other board, Since we are trying from past 3 weeks, & now I am feeling your huge work & help finally find out we have issue with PSU,
                                          your advice will be highly appreciated, waiting for your reply,
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • JarzabekPZ
                                            HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
                                            by JarzabekPZ
                                            I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
                                            09-18-2025, 08:16 AM
                                          • htv239
                                            LG UH8500 Backlight Troubleshooting Help
                                            by htv239
                                            I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                            Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                            What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                            10-11-2021, 01:53 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • netgearnetgear
                                            TCL 43S423 TCON OR PANEL FAULTY???
                                            by netgearnetgear
                                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                            08-20-2025, 06:04 PM
