Sharp LC-60LE832U
  • RickSinGA
    • Jul 2017
    • 60
    Re: Sharp LC-60LE832U
    I have found a main board for a Sharp model the same as mine except it is a 70" vs my 60". The board looks identical and has the same KF733 and QPWBXF799WJN2 stamps on the board but there is 1 slight labeling difference. Mine has a painted on rectangular white strip with FM01N on it and the other has FN82S on it.
    I am hoping that is some kind of date code and is irrelevant.
    Could you possibly confirm that?
    Rick S.
    • RickSinGA
      • Jul 2017
      • 60
      Nobody have any idea?
      • RickSinGA
        • Jul 2017
        • 60
        Bump?
        • RickSinGA
          • Jul 2017
          • 60
          Okay, new Power Board, still same problem. One long blink one short. Power button still does not work nor do the shortcuts described in the other threads?
          Help.
          Rick S.
            So did you find exact same main board as yours?
            Did you check with shopjimmy to see what other board is compatible with your 60" TV?
            • RickSinGA
              • Jul 2017
              • 60
              Not yet, spoke with CS at ShopJimmy and he said there was no compatibility reference? Said it had to be exactly the same and they were out of stock on most everything for that model and not likely to have any in the future. I can't find any cross reference on the net either.
              Board details on eBay are suggestive that their main boards fit a variety of models but I wonder if they really do or they need some sort of tweaking. I have been in contact with one vendor who has what looks like the correct board for a 46 incher and suggests it will fit several others including mine. When asked about the compatibility I was told it would need a firmware update and I should find we01xxxx somewhere on the board, not there?
              I find it hard to believe that there isn't some commonality between boards from same brand/models.
              Would love some expert input or guidance.
              Rick S.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                I have boards for that set..Let me see if i have the main still.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  I do but it is different...mine is for LE847
                  • RickSinGA
                    • Jul 2017
                    • 60
                    Dang, thanks for looking.
                    • RickSinGA
                      • Jul 2017
                      • 60
                      Here is where I am at as of now.
                      Replaced Power Board; nothing changed?
                      Replaced Main Board; nothing changed?
                      Still one long and one short blink of the power light when pluged into power. Neither TV nor remote works for power on or shortcut to codes. Screen is black, no indication of any activity.
                      Can anyone give me some direction please?
                      Rick S.
                        So with the new boards, are you getting the same Voltage readings as in post #58?
                        • RickSinGA
                          • Jul 2017
                          • 60
                          Have not, will need to tear it back apart to get them.
                          What else could it be?
                          Rick S.
                          • RickSinGA
                            • Jul 2017
                            • 60
                            No resistor, everything plugged in, plugged into wall, power off
                            As I have no way to turn the power on.
                            New PB and MB
                            Pin# - Desc - Off - On
                            1 - PNL 12v - 0v -
                            2 - PNL 12v - 0v -
                            3 - GND - - -
                            4 - GND - - -
                            5 - S13.2v - 0.1mv -
                            6 - S13.2v - 0.1mv -
                            7 - UR13.2v - 0.1mv -
                            8 - UR13.2v - 0.1mv -
                            9 - GND - 0v -
                            10 - GND - 0v -
                            11 - GND - 0v -
                            12 - GND - 0v -
                            13 - AC - 0v -
                            14 - PS - 0v -
                            15 - BU5v - 5.5v -
                            16 - PNL - 0v -
                            17 - PWM1 - 0v -
                            18 - NC - 8.2mv - *
                            19 - DIMMER - 0v -
                            20 - NC - 8.6mv - *
                            21 - NC - 8.4mv - *
                            22 - ERROR - .4mv -
                            23 - PWM2 - 0v -
                            24 - STB - 0v -
                            Everything remains the same as post#58 except,
                            I now see power on the three NC pins 18-20-21?
                              New PB and MB
                              1 - PNL 12v - 0v -
                              2 - PNL 12v - 0v -
                              3 - GND - - -
                              4 - GND - - -
                              9 - GND - 0v -
                              10 - GND - 0v -
                              11 - GND - 0v -
                              12 - GND - 0v -
                              13 - AC - 0v -
                              14 - PS - 0v -
                              15 - BU5v - 5.5v -
                              16 - PNL - 0v -
                              17 - PWM1 - 0v -
                              18 - NC - 8.2mv - *
                              19 - DIMMER - 0v -
                              20 - NC - 8.6mv - *
                              21 - NC - 8.4mv - *
                              22 - ERROR - .4mv -
                              23 - PWM2 - 0v -
                              24 - STB - 0v -
                              Is this new power supply board? At least the old one you are getting AC detect of 3V (see your old post), this one is showing 0V.
                              • RickSinGA
                                • Jul 2017
                                • 60
                                Yes, this is with the new PB and MB installed.
                                This is just plain crazy, I am getting different numbers now when I use the chassis as a ground vs the pins #3&4? Appears as I now have power although negative on most pins that used to be zero including +0.1mv on #13.
                                Have to wait on a helper to write down the readings as I probe the pins, will be later today.
                                Am I doing something wrong?
                                Thanks for the help.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Does this have the capacitive buttons on the front panel ? This worked for me...
                                  https://www.badcaps.net/forum/showpo...2&postcount=33
                                  • RickSinGA
                                    • Jul 2017
                                    • 60
                                    No resistor, everything plugged in, plugged into wall, power off.
                                    New PB and MB
                                    8/4/17
                                    Pin# - Desc - Off
                                    1 - PNL 12v - 0v
                                    2 - PNL 12v - 0v
                                    3 - GND - -
                                    4 - GND - -
                                    5 - S13.2v - 0.1mv
                                    6 - S13.2v - 0.1mv
                                    7 - UR13.2v - 0.1mv
                                    8 - UR13.2v - 0.1mv
                                    9 - GND - 0v
                                    10 - GND - 0v
                                    11 - GND - 0v
                                    12 - GND - 0v
                                    13 - AC - 0v
                                    14 - PS - 0v
                                    15 - BU5v - 5.08v
                                    16 - PNL - 0v
                                    17 - PWM1 - 0v
                                    18 - NC - -
                                    19 - DIMMER - 0v
                                    20 - NC - -
                                    21 - NC - -
                                    22 - ERROR - .5mv
                                    23 - PWM2 - 0v
                                    24 - STB - 0v
                                    I had used the old Multimeter on the previous readings by mistake.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      can you explain again what the "text" associated with pin 3 and 4 is trying to say. Further, what measurement test point are you using as a reference? Lastly, IF "GND" is indeed a ground, they should all be grounded with respect to a KNOWN ground (point).... likely some chassis point but not necessarily depending on mounting techniques and chassis build. The check for this is a resistance measurement (with power disconnected), and not a voltage check.
                                      added:
                                      OK I think I see, you are using pins 3 and 4 for your other measurements. Although OK, it may be misleading IF there is an issue with grounding. It perhaps appears to be a potential issue as you seemed to indicate different readings based on a different reference point. Again, check grounds / grounding points... your readings should be the same / very similar for all points with respect to a KNOWN ground.
                                        New PB and MB
                                        8/4/17
                                        Pin# - Desc - Off
                                        1 - PNL 12v - 0v
                                        2 - PNL 12v - 0v
                                        3 - GND - -
                                        4 - GND - -
                                        5 - S13.2v - 0.1mv
                                        6 - S13.2v - 0.1mv
                                        7 - UR13.2v - 0.1mv
                                        8 - UR13.2v - 0.1mv
                                        9 - GND - 0v
                                        10 - GND - 0v
                                        11 - GND - 0v
                                        12 - GND - 0v
                                        13 - AC - 0v
                                        14 - PS - 0v
                                        15 - BU5v - 5.08v
                                        16 - PNL - 0v
                                        17 - PWM1 - 0v
                                        18 - NC - -
                                        19 - DIMMER - 0v
                                        20 - NC - -
                                        21 - NC - -
                                        22 - ERROR - .5mv
                                        23 - PWM2 - 0v
                                        24 - STB - 0v
                                        If all the boards are connected back in place, then your NEW power supply board has problem with AC DET (pin 13), at 0V the main board is being told that the incoming AC is not within the operating range so it will stay in shutdown.
                                        • RickSinGA
                                          • Jul 2017
                                          • 60
                                          Yes, all connected. Remember that I have no way of powering it on. These reading are with the TV plugged into a wall receptical.
                                          Bad PB?
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • Mitike
                                            SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                                            by Mitike
                                            Hello guys,
                                            I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                                            According to other sharp SM-s it is lamp error (I can't find SM for this model)
                                            And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                                            If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                                            02-16-2020, 08:11 PM
                                          • SdlewisSr
                                            Sharp LC-80LE632U 2-5 blink code
                                            by SdlewisSr
                                            I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
                                            Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
                                            07-11-2021, 07:36 PM
                                          • c00lman
                                            Sharp LC-90LE745U 3 slow and 1 fast Blink
                                            by c00lman
                                            hi, new member her and apologize if this has been discussed.. tried to search and most of the result are for LC-xxLe6xx series and not sure if it's applicable to the 745U.
                                            the TV stopped turning on and after the V logo stayed solid for a minute or 2, it gives the 3 slow and 1 fast blinks which from what I researched are internal communication error.
                                            did some voltage measurement on the power supply out.
                                            Pin 1 and 2 = 0V --> PNL 12V
                                            Pin 3 and 4 = 0 V --> GND
                                            Pin 5 to 8 = 13V --> UR 13V
                                            Pin 9 to 12 = 0 V --> GND
                                            PIN 13...
                                            06-21-2021, 05:18 PM
