SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
  • Mitike
    • Jan 2020
    • 9
    Hello guys,
    I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
    According to other sharp SM-s it is lamp error (I can't find SM for this model)
    And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
    If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again.
    I've already disassembled the set and tested the LED-stripes individually with LED tester and they seems working great none of them fails or dimming differently and all of them bright as the sun.
    Also similar voltage on them:
    LED stripe1: 86.9V
    LED stripe2: 87.8V
    LED stripe3: 88.7V.
    Interesting info that during the set was disassembled and the LCD panel wasn't connected I was able to start up the set with CHANNEL DOWN + VOLUME UP + POWER combo and the LEDs turned on dimmed a little down and the set was running without turning itself off.
    After this I put the set back together and I was hoping this "new" button combo will fix it but unfortunately the TV acts the same assembled and not reacting on the button combo at all. (But still can turn it on with POWER + INPUT combo and it turns off after android logo appears and starts the blinking)
    Anyone any experience with this model/error?
    PS: why can't I find any SM or schematics out there about this model and it's power supply module?
  • Mitike
    • Jan 2020
    • 9
    Re: SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
    Since Nobody reacted here is a little update:
    Tried new power supply and mainboard and same symptoms.... so keep trying other modules ...
    • budwich
      • Jul 2015
      • 3097
      well, you can try similar tests that you did with the "disconnected panel test"... do it with a combination on one cable disconnected at a time... of course, doing your same "button / power" start up to see if you get any results including different screen reactions (which may be important). Go from the result.
      One other question: how did the set come to arrive at this condition...ie history?
        Are you able to get the backlights to come on and stay on ling enough to be able to the ODS to turn down the backlights level (not Brightness) to may be 50% or less and see if it stay ob linger or not.
        The LED tester only puts out about 30mA instead of 300mA or more by the LED driver.
        The LED tester Voltage look suspicious, they should be real close to each others.
        LED stripe1: 86.9V
        LED stripe2: 87.8V
        LED stripe3: 88.7V.
        • Mitike
          • Jan 2020
          • 9
          I have no history .. found the set on FB Market as a fixer upper for 40$ and I thought let's give it a try since the TV originally a high end model
          • Mitike
            • Jan 2020
            • 9
            LED stripe1: 86.9V
            LED stripe2: 87.8V
            LED stripe3: 88.7V.
            I cant make it stay on long enough to bring up any kind of menu... as I originally wrote the set turn itself off after the SHARP logo. That's my main issue ... picture seems good LED seems good even after disassembly and still 1 long 1 short and it means hardware error
            My tester is able to put out 350 V and 160 mA BTW
            • Mitike
              • Jan 2020
              • 9
              UPDATE:
              So I tried to run some tests on the T-con
              It has 4 ribbon cables connected to the LCD panel I've disconnected those in every permutation but the set always ended up turns itself off and blink 1 long and 1 short on the stand by LED
              The display was "rotating" in 2 states Black/White/"Actual picture" depend on what combination of the ribbons were connected/disconnected. But again after the SHARP and the android logo still turned off.
              If I disconnected either the T-con from the FRC board or the FRC from the main I had the same result: backlight on then off and blinking 3 Long and Short if I counted right.
              So that didn't helped either.
              • Mitike
                • Jan 2020
                • 9
                Update:
                New FRC board from ShopJimmy.... aaaand still nothing ... same issue
                I'll swap the t-con however the picture seems to be good when the logo pops up ....
                ANY advice?
                • Storyteller12
                  • Jun 2020
                  • 625
                  Sounds like maybe a bad panel. If you have swapped all the boards and the problem still persist. However budm is also right about the backlight voltages being closer together. If not the backlights my guess is bad panel. Not uncommon for these 70 and 80” sharp panels to fail unfortunately.
                  • alfatv
                    • Sep 2020
                    • 353
                    You haven't done much diagnostics.
                    Can you determine if the whole TV tuns off or just backlight?
                    Can you measure voltages on power connectors while picture is on and after shutdown?
                    • RDC55
                      • Dec 2017
                      • 180
                      ^^^ good advice on the voltages. PD-22 Error on the Power Supply may be active causing the shutdown. If so you may see the PD-14 PS_ON or PD-16 PNL_POW change states when it shuts down.
                      • Mitike
                        • Jan 2020
                        • 9
                        thank you guys I will try that I was off due to other projects but I still didn't give up yet
                        and I'll be back with the results
                        • lafilipczyk
                          lc 80le632u - Lamp error - TV working after counter reset via buttons
                          by lafilipczyk
                          Hello everyone, I just got my hands on a Sharp lc 80le632u TV that initially had the 1 short, 1 long blink sequence. That indicates a lamp error, however if I follow the isntructions to reset the error counter, the TV starts correctly: no missing LEDs everything lods just fine.
                          I went through the process to get to the diagnostic screen, and got this ( attached).
                          Since all LEDs are working correctly, and the TV seems to load fine after reset, that tells me that the power board and the LED strips are working correctly. Could this be a main board issue?
                          Any...
                          07-29-2024, 11:00 AM
                        • JohnML1975
                          LG 49UK7550PTA - after couple of hours screen starts to blink
                          by JohnML1975
                          Hello Forum team
                          Have this TV; searched for the model and could not anything so thought I would share in here
                          Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
                          Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
                          So I removed the covers, and could not see anything visibly
                          Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
                          07-25-2025, 10:48 PM
                        • ebj423
                          asus b75m-plus PSU turns on but no POST. Reset button starts it ?
                          by ebj423
                          Posted Today, 07:34 PM
                          , Hi! In the normal startup process, my pc's power led will turn on, the hdd led will flash brightly for a moment, then beeps once and you would know that everything is starting up fine. But recently, it will just flash dimly(sometimes too dim to see) and then nothing, no beep to show it is posting but the psu is on and all fans/hdds/peripherals/usb are on, even the lan port is flashing. Luckily, I discovered that pressing the reset button after the power button will initiate the post (the hdd led will flash brightly, beeps once and everything starts up fine),...
                          06-02-2022, 06:05 AM
                        • cloo
                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                          by cloo
                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                          After doing a factory reset this problem was gone and the picture was back to...
                          01-06-2025, 06:02 AM
                        • Superbee_dad
                          Sharp 80” long short flash backlight error - Help
                          by Superbee_dad
                          Hello Sharp TV experts
                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                          01-24-2025, 11:51 PM
