Sharp LC-60LE832U
Re: Sharp LC-60LE832U
The screen does light up momentarily when powered on and the HDMI/1080 shows up during that brief time then all goes black again. Does not last more than a second.
I haven't found any combination that will give me the "K" screen.Comment
I think it's Vol-/Chan- but could be wrong.Comment
Do you mean disconnecting and reconnecting the flat cables going the bottom edge of the screen while the power is on Budwich?
Have not found the right combination of keys yet Mmartell.
FYI, I have noticed a faint light background on the left side of the screen that just flashes when I power on the TV along with the quickly disappearing HDMI/1080 at the top right. The glow is very faint and cannot see if the room is not completely dark.Comment
Never disconnect or connect any cables with the power connected / on. The "cable disconnected tests" are common for all sets as it isolates potential areas of the system that maybe in trouble allowing the rest of the system to partially function potentially indicating to you what might be the issue. Read up some more on the various threads in and around your set type.Comment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by EazyBoneI write this to maybe help another with this TV.
So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
...03-18-2024, 10:24 PM -
by MitikeHello guys,
I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
According to other sharp SM-s it is lamp error (I can't find SM for this model)
And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again.... -
by SdlewisSrI have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault? -
by c00lmanhi, new member her and apologize if this has been discussed.. tried to search and most of the result are for LC-xxLe6xx series and not sure if it's applicable to the 745U.
the TV stopped turning on and after the V logo stayed solid for a minute or 2, it gives the 3 slow and 1 fast blinks which from what I researched are internal communication error.
did some voltage measurement on the power supply out.
Pin 1 and 2 = 0V --> PNL 12V
Pin 3 and 4 = 0 V --> GND
Pin 5 to 8 = 13V --> UR 13V
Pin 9 to 12 = 0 V --> GND
PIN 13... - Loading...
