Sharp LC-90LE745U 3 slow and 1 fast Blink
  • c00lman
    • Jun 2021
    • 32
    Re: Sharp LC-90LE745U 3 slow and 1 fast Blink
    Originally posted by RDC55
    "That is the procedure I'm following, pressing the Input and Volume down while plugging the AC power, the main board LED will blink, then after few seconds, I will hear the power Hum indicating it's activating the backlight, then the back light will flicker then power supply shutdown and the indication is doing the 1-1."
    And you have continued to hold the volume v and input for a good 20 to 30 seconds after plugging in the set, just in case the main has to boot to a point to recognize the command.
    Yup. I will try it again tonight . Just outside
    • c00lman
      • Jun 2021
      • 32
      Yup. Holding the input and volume down key longer does the same thing. It looks like going to boot and display the k but it shutdown after backlight flashed.
      Also took a pic of the ic underneath the power supply. Are you referring to this one?
      • RDC55
        • Dec 2017
        • 180
        I was thinking of the entire bottom of the Power Supply, but it's pretty much a dead end trying to find any meaningful information on that LED controller so the additional picture is not going to help much for now.
        Nice picture though with some really good detail.
        • c00lman
          • Jun 2021
          • 32
          Thanks.. that's what I'm thinking.. will put it in storage for now and hopefully I can find a working power supply to test it. since the back light seems to be working (not 100% confirmed as can't really open up and check each light hahaha).
          or I might just sell it for parts.
          Thank you again.
          • nicholas1110
            • Aug 2012
            • 127
            • usa
            #45
            To get into service mode on some sharp models it’s not like the older ones. First plug in the power, then press volume - and input together and while holding those press the power button. Continue to hold until the tv powers on without the blink code ( should be pretty fast) when the k shows up release the power and input and press and hold channel -
            Hope this helps
            • c00lman
              • Jun 2021
              • 32
              Originally posted by nicholas1110
              To get into service mode on some sharp models it's not like the older ones. First plug in the power, then press volume - and input together and while holding those press the power button. Continue to hold until the tv powers on without the blink code ( should be pretty fast) when the k shows up release the power and input and press and hold channel -
              Hope this helps
              do we plug in the power first then press volume - and input together? when I plug in the power, the TV goes to the 1-1 blink
              i will try it again later
              thank you
              • nicholas1110
                • Aug 2012
                • 127
                • usa
                #47
                Hello, yes plug the tv in first. This procedure to enter service mode can be done even with the blink code
                1. Plug tv in.
                2. Press and hold volume - and input buttons, while holding them, press the power button.
                3. Tv will turn on, with the letter k on the screen.
                4. Press and hold volume - and channel down.
                5. Service menu will appear, you should see lamp error in the list, set to 0 if it is anything higher.
                • c00lman
                  • Jun 2021
                  • 32
                  1. Plug tv in.
                  hi, plugging the TV in goes immediately to that 1-1 blink then press and hold volume - and input buttons while pressing the power button does not do anything.. it continue to do the 1-1 blink LOL
                  • RDC55
                    • Dec 2017
                    • 180
                    Darn, I was hoping a firmware update along the way had made the entry into the service menu different than the service manual and that was going to work.
                    Logic seems to say then that the Main is not doing what it is supposed to do - ignore the fault and power up with a "K." Maybe I don't understand the process.
                    Where are these boards coming from, and do you trust the vendors? Didn't the first replacement have an overheating part?
                    This listing on Ebay is expensive, but worth every bit if it gets a 90 inch TV back in service. And, really good positive feedback at 100%.
                    https://www.ebay.com/itm/17412849480...IAAOSwJ2td-Ow2
                    • c00lman
                      • Jun 2021
                      • 32
                      Yeah. Was hoping there’s a back door trick into the service menu . Order it from the US not sure if we can put the URL here lol
                      Unfortunately. It’s hard to get parts within canada .
                      It’s nice to get this baby back in service but it might cost a lot more than just to give up
                      Just the main board alone is around $100 + shipping + import fees etc .
                      Wish we have stores like that here. Lol
                      • RDC55
                        • Dec 2017
                        • 180
                        Not the exact one but the Power Supply schematic is likely a close match using the same backlight controller ASIC - courtesy of member lotas.
                        https://www.badcaps.net/forum/showthread.php?t=97281
                        • c00lman
                          • Jun 2021
                          • 32
                          Thank you.. we'll see if I can trace something hahaha
                          • RDC55
                            • Dec 2017
                            • 180
                            It does solve one issue in that the STB pin on Sharp TV is associated with the backlight circuit and not a standby pin as common sense would dictate. What the acronym STB stands for is anyone's guess, but the Asian nomenclature for LED's seems to often be referred to as "beads."
                            Still iffy on the error signal, it would be nice to know if it could be tricked out in some way, but still not quite enough information to make a suggestion.
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • cheeky2
                              Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                              by cheeky2
                              For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                              See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                              01-08-2024, 05:56 AM
                            • EthanMai
                              DELL INSPIRON 15 3501 LA-K035P MAIN+EC (The startup is very slow, please help me cleaning,Thanks)
                              by EthanMai
                              SN : CNXRSD3
                              LA-K035P
                              Thanks...
                              07-22-2024, 07:07 PM
                            • cheeky2
                              by cheeky2
                              05-25-2024, 03:27 AM
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
